Software Archive
Read-only legacy content
17060 Discussions
build iOS with Enterprise Developer Account
Nguyen_N_
Hi All! :)
I'm from Vietnam
I had use Intel XDK to build my iOS app with Enterpris Developer Account(https://developer.apple.com/programs/enterprise/)
I had create App, and provision.... to build my app, but when building I can't build my app because the error: "
ERROR building one of the platforms: Error code 65 for command: xcodebuild with args: -xcconfig,..."
Could you help me fix this error
Thanks!
Elroy_A_Intel
Can you provide a link to view the detailed log or attach a text file? This is not enough information.
Nguyen_N_
Calling plugman.fetch on plugin ".../cachedPlugins.jL0gho.tmp/cache.7ZL5dw.pl/cordova-plugin-statusbar"
Copying plugin ".../cachedPlugins.jL0gho.tmp/cache.7ZL5dw.pl/cordova-plugin-statusbar" => ".../eOffice3s/plugins/cordova-plugin-statusbar"
Calling plugman.install on plugin ".../eOffice3s/plugins/cordova-plugin-statusbar" for platform "ios
Installing "cordova-plugin-statusbar" for ios
Running command: .../eOffice3s/platforms/ios/cordova/version
Command finished with error code 0: .../eOffice3s/platforms/ios/cordova/version
Install start for "cordova-plugin-statusbar" on ios.
Install complete for cordova-plugin-statusbar on ios.
Searching PlatformJson files for differences between project vs. platform installed plugins
No differences found between project and ios platform. Continuing...
Generating config.xml from defaults for platform "ios"
Wrote out iOS Bundle Identifier to "eoffice3s.evn.vn"
Wrote out iOS Bundle Version to "0.0.1"
Set IPHONEOS_DEPLOYMENT_TARGET to "8.0".
iOS Product Name has not changed (still "eOffice")
updated project successfully
Calling plugman.fetch on plugin ".../cachedPlugins.jL0gho.tmp/cache.GLwDco.pl/cordova-plugin-device"
Copying plugin ".../cachedPlugins.jL0gho.tmp/cache.GLwDco.pl/cordova-plugin-device" => ".../eOffice3s/plugins/cordova-plugin-device"
Calling plugman.install on plugin ".../eOffice3s/plugins/cordova-plugin-device" for platform "ios
Installing "cordova-plugin-device" for ios
Install start for "cordova-plugin-device" on ios.
Install complete for cordova-plugin-device on ios.
Calling plugman.fetch on plugin ".../cachedPlugins.jL0gho.tmp/cache.cQP7N3.pl/cordova-plugin-splashscreen"
Copying plugin ".../cachedPlugins.jL0gho.tmp/cache.cQP7N3.pl/cordova-plugin-splashscreen" => ".../eOffice3s/plugins/cordova-plugin-splashscreen"
Calling plugman.install on plugin ".../eOffice3s/plugins/cordova-plugin-splashscreen" for platform "ios
Installing "cordova-plugin-splashscreen" for ios
Install start for "cordova-plugin-splashscreen" on ios.
Install complete for cordova-plugin-splashscreen on ios.
Calling plugman.fetch on plugin ".../cachedPlugins.jL0gho.tmp/cache.AslIF1.pl/cordova-plugin-file-opener2"
Copying plugin ".../cachedPlugins.jL0gho.tmp/cache.AslIF1.pl/cordova-plugin-file-opener2" => ".../eOffice3s/plugins/cordova-plugin-file-opener2"
Calling plugman.install on plugin ".../eOffice3s/plugins/cordova-plugin-file-opener2" for platform "ios
Installing "cordova-plugin-file-opener2" for ios
Install start for "cordova-plugin-file-opener2" on ios.
Install complete for cordova-plugin-file-opener2 on ios.
Calling plugman.fetch on plugin ".../cachedPlugins.jL0gho.tmp/cache.h1XuyC.pl/cordova-plugin-file"
Copying plugin ".../cachedPlugins.jL0gho.tmp/cache.h1XuyC.pl/cordova-plugin-file" => ".../eOffice3s/plugins/cordova-plugin-file"
Calling plugman.install on plugin ".../eOffice3s/plugins/cordova-plugin-file" for platform "ios
Installing "cordova-plugin-file" for ios
Install start for "cordova-plugin-file" on ios.
Install complete for cordova-plugin-file on ios.
The Android Persistent storage location now defaults to "Internal". Please check this plugins README to see if you application needs any changes in its config.xml.
If this is a new application no changes are required.
If this is an update to an existing application that did not specify an "AndroidPersistentFileLocation" you may need to add:
      "<preference name="AndroidPersistentFileLocation" value="Compatibility" />"
to config.xml in order for the application to find previously stored files.
Calling plugman.fetch on plugin ".../cachedPlugins.jL0gho.tmp/cache.0YCaCs.pl/cordova-plugin-file-transfer"
Copying plugin ".../cachedPlugins.jL0gho.tmp/cache.0YCaCs.pl/cordova-plugin-file-transfer" => ".../eOffice3s/plugins/cordova-plugin-file-transfer"
Calling plugman.install on plugin ".../eOffice3s/plugins/cordova-plugin-file-transfer" for platform "ios
Installing "cordova-plugin-file-transfer" for ios
Dependencies detected, iterating through them...
Dependent plugin "cordova-plugin-file" already fetched, using that version.
Dependent plugin "cordova-plugin-file" already installed on ios.
Install start for "cordova-plugin-file-transfer" on ios.
Install complete for cordova-plugin-file-transfer on ios.
Calling plugman.fetch on plugin ".../cachedPlugins.jL0gho.tmp/cache.Qgsxm5.pl/cordova-plugin-filepath"
Copying plugin ".../cachedPlugins.jL0gho.tmp/cache.Qgsxm5.pl/cordova-plugin-filepath" => ".../eOffice3s/plugins/cordova-plugin-filepath"
Calling plugman.install on plugin ".../eOffice3s/plugins/cordova-plugin-filepath" for platform "ios
Installing "cordova-plugin-filepath" for ios
Install start for "cordova-plugin-filepath" on ios.
Install complete for cordova-plugin-filepath on ios.
Calling plugman.fetch on plugin ".../cachedPlugins.jL0gho.tmp/cache.4lAWZm.pl/cordova-plugin-inappbrowser"
Copying plugin ".../cachedPlugins.jL0gho.tmp/cache.4lAWZm.pl/cordova-plugin-inappbrowser" => ".../eOffice3s/plugins/cordova-plugin-inappbrowser"
Calling plugman.install on plugin ".../eOffice3s/plugins/cordova-plugin-inappbrowser" for platform "ios
Installing "cordova-plugin-inappbrowser" for ios
Install start for "cordova-plugin-inappbrowser" on ios.
Install complete for cordova-plugin-inappbrowser on ios.
Calling plugman.fetch on plugin ".../cachedPlugins.jL0gho.tmp/cache.jfQWDp.pl/cordova-plugin-network-information"
Copying plugin ".../cachedPlugins.jL0gho.tmp/cache.jfQWDp.pl/cordova-plugin-network-information" => ".../eOffice3s/plugins/cordova-plugin-network-information"
Calling plugman.install on plugin ".../eOffice3s/plugins/cordova-plugin-network-information" for platform "ios
Installing "cordova-plugin-network-information" for ios
Install start for "cordova-plugin-network-information" on ios.
Install complete for cordova-plugin-network-information on ios.
Calling plugman.fetch on plugin ".../cachedPlugins.jL0gho.tmp/cache.VqGVG8.pl/cordova-plugin-dialogs"
Copying plugin ".../cachedPlugins.jL0gho.tmp/cache.VqGVG8.pl/cordova-plugin-dialogs" => ".../eOffice3s/plugins/cordova-plugin-dialogs"
Calling plugman.install on plugin ".../eOffice3s/plugins/cordova-plugin-dialogs" for platform "ios
Installing "cordova-plugin-dialogs" for ios
Install start for "cordova-plugin-dialogs" on ios.
Install complete for cordova-plugin-dialogs on ios.
************* Processing the main config.xml file (after_prepare)  *****************
App Directory = [.../eOffice3s]
Will process and update the following config files:
    Config.xml = [.../eOffice3s/config.xml]
Namespaces:
    prefix/uri ''/'http://www.w3.org/ns/widgets'
    prefix/uri 'intelxdk'/'http://xdk.intel.com/ns/v1'
Name of the app is [eOffice]
Updating full app name to [eOffice]
Processing preference permissions
Updating the versionCode
Setting [CFBundleVersion] to eoffice3s.evn.vn
Updating the versionName
Setting [CFBundleShortVersionString] to 0.0.1
Processing debuggable
Processing config file values
Saving config.xml to [.../eOffice3s/config.xml]
Saving info.plist to [.../eOffice3s/platforms/ios/eOffice/eOffice-Info.plist]
************* Completed processing the main config.xml file (after_prepare)  *****************
Building project  : .../eOffice3s/platforms/ios/eOffice.xcodeproj
	Configuration : Release
	Platform      : device
Build settings from command line:
    ARCHS = armv7 arm64
    CONFIGURATION_BUILD_DIR = .../eOffice3s/platforms/ios/build/device
    SDKROOT = iphoneos9.2
    SHARED_PRECOMPS_DIR = .../eOffice3s/platforms/ios/build/sharedpch
    VALID_ARCHS = armv7 arm64
Build settings from configuration file '.../eOffice3s/platforms/ios/cordova/build-release.xcconfig':
    CLANG_ALLOW_NON_MODULAR_INCLUDES_IN_FRAMEWORK_MODULES = YES
    CODE_SIGN_IDENTITY = iPhone Distribution
    ENABLE_BITCODE = NO
    HEADER_SEARCH_PATHS = "$(TARGET_BUILD_DIR)/usr/local/lib/include" "$(OBJROOT)/UninstalledProducts/include" "$(OBJROOT)/UninstalledProducts/$(PLATFORM_NAME)/include" "$(BUILT_PRODUCTS_DIR)"
    IPHONEOS_DEPLOYMENT_TARGET = 8.0
    OTHER_LDFLAGS = -ObjC
    PROVISIONING_PROFILE =
    SWIFT_OBJC_BRIDGING_HEADER = $(PROJECT_DIR)/$(PROJECT_NAME)/Bridging-Header.h
    TARGETED_DEVICE_FAMILY = 1,2
=== BUILD TARGET CordovaLib OF PROJECT CordovaLib WITH CONFIGURATION Release ===
Check dependencies
Write auxiliary files
write-file .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova.hmap
write-file .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap
write-file .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap
/bin/mkdir -p .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7
write-file .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/Cordova.LinkFileList
/bin/mkdir -p .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64
write-file .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/Cordova.LinkFileList
write-file .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-non-framework-target-headers.hmap
/bin/mkdir -p .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti
write-file .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch.pch.hash-criteria
/bin/mkdir -p .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf
write-file .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch.pch.hash-criteria
write-file .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap
write-file .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap
CpHeader Classes/Public/CDV.h .../eOffice3s/platforms/ios/build/device/include/Cordova/CDV.h
    cd .../eOffice3s/platforms/ios/CordovaLib
    export PATH="/Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../usr/bin:/Applications/Xcode.app/Contents.../usr/bin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/tools:/platform-tools"
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDV.h .../eOffice3s/platforms/ios/build/device/include/Cordova
CpHeader Classes/Public/CDVWebViewEngineProtocol.h .../eOffice3s/platforms/ios/build/device/include/Cordova/CDVWebViewEngineProtocol.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVWebViewEngineProtocol.h .../eOffice3s/platforms/ios/build/device/include/Cordova
CpHeader Classes/Public/CDVScreenOrientationDelegate.h .../eOffice3s/platforms/ios/build/device/include/Cordova/CDVScreenOrientationDelegate.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVScreenOrientationDelegate.h .../eOffice3s/platforms/ios/build/device/include/Cordova
CpHeader Classes/Public/CDVCommandDelegateImpl.h .../eOffice3s/platforms/ios/build/device/include/Cordova/CDVCommandDelegateImpl.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVCommandDelegateImpl.h .../eOffice3s/platforms/ios/build/device/include/Cordova
CpHeader Classes/Public/CDVWhitelist.h .../eOffice3s/platforms/ios/build/device/include/Cordova/CDVWhitelist.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVWhitelist.h .../eOffice3s/platforms/ios/build/device/include/Cordova
CpHeader Classes/Public/CDVCommandQueue.h .../eOffice3s/platforms/ios/build/device/include/Cordova/CDVCommandQueue.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVCommandQueue.h .../eOffice3s/platforms/ios/build/device/include/Cordova
CpHeader Classes/Public/CDVPlugin+Resources.h .../eOffice3s/platforms/ios/build/device/include/Cordova/CDVPlugin+Resources.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVPlugin+Resources.h .../eOffice3s/platforms/ios/build/device/include/Cordova
CpHeader Classes/Public/CDVAppDelegate.h .../eOffice3s/platforms/ios/build/device/include/Cordova/CDVAppDelegate.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVAppDelegate.h .../eOffice3s/platforms/ios/build/device/include/Cordova
CpHeader Classes/Public/CDVAvailability.h .../eOffice3s/platforms/ios/build/device/include/Cordova/CDVAvailability.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVAvailability.h .../eOffice3s/platforms/ios/build/device/include/Cordova
CpHeader Classes/Public/NSMutableArray+QueueAdditions.h .../eOffice3s/platforms/ios/build/device/include/Cordova/NSMutableArray+QueueAdditions.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/NSMutableArray+QueueAdditions.h .../eOffice3s/platforms/ios/build/device/include/Cordova
CpHeader Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.h .../eOffice3s/platforms/ios/build/device/include/Cordova/CDVUIWebViewDelegate.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../eOffice3s/platforms/ios/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.h .../eOffice3s/platforms/ios/build/device/include/Cordova
CpHeader Classes/Public/CDVPluginResult.h .../eOffice3s/platforms/ios/build/device/include/Cordova/CDVPluginResult.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVPluginResult.h .../eOffice3s/platforms/ios/build/device/include/Cordova
CpHeader Classes/Public/CDVInvokedUrlCommand.h .../eOffice3s/platforms/ios/build/device/include/Cordova/CDVInvokedUrlCommand.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVInvokedUrlCommand.h .../eOffice3s/platforms/ios/build/device/include/Cordova
CpHeader Classes/Public/NSDictionary+CordovaPreferences.h .../eOffice3s/platforms/ios/build/device/include/Cordova/NSDictionary+CordovaPreferences.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/NSDictionary+CordovaPreferences.h .../eOffice3s/platforms/ios/build/device/include/Cordova
CpHeader Classes/Public/CDVPlugin.h .../eOffice3s/platforms/ios/build/device/include/Cordova/CDVPlugin.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVPlugin.h .../eOffice3s/platforms/ios/build/device/include/Cordova
CpHeader Classes/Public/CDVURLProtocol.h .../eOffice3s/platforms/ios/build/device/include/Cordova/CDVURLProtocol.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVURLProtocol.h .../eOffice3s/platforms/ios/build/device/include/Cordova
CpHeader Classes/Public/CDVCommandDelegate.h .../eOffice3s/platforms/ios/build/device/include/Cordova/CDVCommandDelegate.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVCommandDelegate.h .../eOffice3s/platforms/ios/build/device/include/Cordova
CpHeader Classes/Public/CDVAvailabilityDeprecated.h .../eOffice3s/platforms/ios/build/device/include/Cordova/CDVAvailabilityDeprecated.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVAvailabilityDeprecated.h .../eOffice3s/platforms/ios/build/device/include/Cordova
CpHeader Classes/Public/CDVUserAgentUtil.h .../eOffice3s/platforms/ios/build/device/include/Cordova/CDVUserAgentUtil.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVUserAgentUtil.h .../eOffice3s/platforms/ios/build/device/include/Cordova
CpHeader Classes/Public/CDVTimer.h .../eOffice3s/platforms/ios/build/device/include/Cordova/CDVTimer.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVTimer.h .../eOffice3s/platforms/ios/build/device/include/Cordova
CpHeader Classes/Public/CDVConfigParser.h .../eOffice3s/platforms/ios/build/device/include/Cordova/CDVConfigParser.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVConfigParser.h .../eOffice3s/platforms/ios/build/device/include/Cordova
CpHeader Classes/Public/CDVViewController.h .../eOffice3s/platforms/ios/build/device/include/Cordova/CDVViewController.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVViewController.h .../eOffice3s/platforms/ios/build/device/include/Cordova
ProcessPCH .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch.pch CordovaLib_Prefix.pch normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    export LANG=en_US.US-ASCII
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c-header -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -MD -MT dependencies -MF .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch.d -c .../eOffice3s/platforms/ios/CordovaLib/CordovaLib_Prefix.pch -o .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch.pch --serialize-diagnostics .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch.dia
ProcessPCH .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch.pch CordovaLib_Prefix.pch normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c-header -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -MD -MT dependencies -MF .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch.d -c .../eOffice3s/platforms/ios/CordovaLib/CordovaLib_Prefix.pch -o .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch.pch --serialize-diagnostics .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch.dia
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.o Classes/Public/CDVViewController.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVViewController.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+CordovaPreferences.o Classes/Public/NSDictionary+CordovaPreferences.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+CordovaPreferences.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+CordovaPreferences.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/NSDictionary+CordovaPreferences.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+CordovaPreferences.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVAppDelegate.o Classes/Public/CDVAppDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVAppDelegate.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVAppDelegate.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVAppDelegate.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVAppDelegate.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewDelegate.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewDelegate.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewDelegate.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewDelegate.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.o Classes/Public/CDVCommandDelegateImpl.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVCommandDelegateImpl.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.o Classes/Private/CDVJSON_private.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Private/CDVJSON_private.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.o Classes/Public/CDVWhitelist.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVWhitelist.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.o Classes/Public/CDVInvokedUrlCommand.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVInvokedUrlCommand.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.o Classes/Public/CDVTimer.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVTimer.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.o Classes/Public/CDVUserAgentUtil.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVUserAgentUtil.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.o Classes/Public/CDVConfigParser.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVConfigParser.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVGestureHandler.o Classes/Private/Plugins/CDVGestureHandler/CDVGestureHandler.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVGestureHandler.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVGestureHandler.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Private/Plugins/CDVGestureHandler/CDVGestureHandler.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVGestureHandler.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.o Classes/Private/Plugins/CDVHandleOpenURL/CDVHandleOpenURL.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Private/Plugins/CDVHandleOpenURL/CDVHandleOpenURL.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewNavigationDelegate.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewNavigationDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    cd .../eOffice3s/platforms/ios/CordovaLib
    export PATH="/Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../usr/bin:/Applications/Xcode.app/Contents.../usr/bin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/tools:/platform-tools"
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewNavigationDelegate.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewNavigationDelegate.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewNavigationDelegate.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewNavigationDelegate.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.o Classes/Public/NSMutableArray+QueueAdditions.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/NSMutableArray+QueueAdditions.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.o Classes/Public/CDVCommandQueue.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVCommandQueue.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.o Classes/Public/CDVPluginResult.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVPluginResult.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin+Resources.o Classes/Public/CDVPlugin+Resources.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    export LANG=en_US.US-ASCII
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin+Resources.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin+Resources.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVPlugin+Resources.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin+Resources.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.o Classes/Public/CDVURLProtocol.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVURLProtocol.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewEngine.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewEngine.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewEngine.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewEngine.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewEngine.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewEngine.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.o Classes/Public/CDVPlugin.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVPlugin.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.o Classes/Private/Plugins/CDVLocalStorage/CDVLocalStorage.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Private/Plugins/CDVLocalStorage/CDVLocalStorage.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVIntentAndNavigationFilter.o Classes/Private/Plugins/CDVIntentAndNavigationFilter/CDVIntentAndNavigationFilter.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gndsxhtxbtjolxgcqweqrsosskaf/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVIntentAndNavigationFilter.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVIntentAndNavigationFilter.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Private/Plugins/CDVIntentAndNavigationFilter/CDVIntentAndNavigationFilter.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVIntentAndNavigationFilter.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.o Classes/Public/CDVViewController.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVViewController.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+CordovaPreferences.o Classes/Public/NSDictionary+CordovaPreferences.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+CordovaPreferences.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+CordovaPreferences.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/NSDictionary+CordovaPreferences.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+CordovaPreferences.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVAppDelegate.o Classes/Public/CDVAppDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVAppDelegate.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVAppDelegate.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVAppDelegate.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVAppDelegate.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewDelegate.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewDelegate.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewDelegate.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewDelegate.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.o Classes/Public/CDVCommandDelegateImpl.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVCommandDelegateImpl.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.o Classes/Private/CDVJSON_private.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Private/CDVJSON_private.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.o Classes/Public/CDVWhitelist.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVWhitelist.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.o Classes/Public/CDVInvokedUrlCommand.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVInvokedUrlCommand.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.o Classes/Public/CDVTimer.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    cd .../eOffice3s/platforms/ios/CordovaLib
    export PATH="/Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../usr/bin:/Applications/Xcode.app/Contents.../usr/bin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/tools:/platform-tools"
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVTimer.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.o Classes/Public/CDVUserAgentUtil.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVUserAgentUtil.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.o Classes/Public/CDVConfigParser.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVConfigParser.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVGestureHandler.o Classes/Private/Plugins/CDVGestureHandler/CDVGestureHandler.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVGestureHandler.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVGestureHandler.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Private/Plugins/CDVGestureHandler/CDVGestureHandler.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVGestureHandler.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.o Classes/Private/Plugins/CDVHandleOpenURL/CDVHandleOpenURL.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Private/Plugins/CDVHandleOpenURL/CDVHandleOpenURL.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewNavigationDelegate.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewNavigationDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    export LANG=en_US.US-ASCII
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewNavigationDelegate.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewNavigationDelegate.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewNavigationDelegate.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewNavigationDelegate.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.o Classes/Public/NSMutableArray+QueueAdditions.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/NSMutableArray+QueueAdditions.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.o Classes/Public/CDVCommandQueue.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVCommandQueue.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.o Classes/Public/CDVPluginResult.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVPluginResult.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin+Resources.o Classes/Public/CDVPlugin+Resources.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin+Resources.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin+Resources.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVPlugin+Resources.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin+Resources.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.o Classes/Public/CDVURLProtocol.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVURLProtocol.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewEngine.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewEngine.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewEngine.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewEngine.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewEngine.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewEngine.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.o Classes/Private/Plugins/CDVLocalStorage/CDVLocalStorage.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Private/Plugins/CDVLocalStorage/CDVLocalStorage.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.o Classes/Public/CDVPlugin.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Public/CDVPlugin.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVIntentAndNavigationFilter.o Classes/Private/Plugins/CDVIntentAndNavigationFilter/CDVIntentAndNavigationFilter.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/rw/_495hd6j3916_ym16xfkvchr0000gp/C/org.llvm.clang/ModuleCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../eOffice3s/platforms/ios/build/device/include -I.../eOffice3s/platforms/ios/build/device/usr/local/lib/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/include -I.../eOffice3s/platforms/ios/CordovaLib/build/UninstalledProducts/iphoneos/include -I.../eOffice3s/platforms/ios/build/device -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../eOffice3s/platforms/ios/build/device -include .../eOffice3s/platforms/ios/build/sharedpch/CordovaLib_Prefix-gociuoxynqdmwxeyoahlwyakllti/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVIntentAndNavigationFilter.d --serialize-diagnostics .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVIntentAndNavigationFilter.dia -c .../eOffice3s/platforms/ios/CordovaLib/Classes/Private/Plugins/CDVIntentAndNavigationFilter/CDVIntentAndNavigationFilter.m -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVIntentAndNavigationFilter.o
Libtool build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova.a normal arm64
    export IPHONEOS_DEPLOYMENT_TARGET=8.0
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/libtool -static -arch_only arm64 -syslibroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -L.../eOffice3s/platforms/ios/build/device -filelist .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/Cordova.LinkFileList -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova.a
Libtool build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/libCordova.a normal armv7
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/libtool -static -arch_only armv7 -syslibroot /Applications/Xcode.app/Contents.../Platforms/iPhoneOS.platform.../SDKs/iPhoneOS9.2.sdk -L.../eOffice3s/platforms/ios/build/device -filelist .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/Cordova.LinkFileList -o .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/libCordova.a
CreateUniversalBinary .../eOffice3s/platforms/ios/build/device/libCordova.a normal armv7\ arm64
    /Applications/Xcode.app/Contents.../Toolchains/XcodeDefault.xctoolchain/usr/bin/libtool -static .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/libCordova.a .../eOffice3s/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova.a -o .../eOffice3s/platforms/ios/build/device/libCordova.a
=== BUILD TARGET eOffice OF PROJECT eOffice WITH CONFIGURATION Release ===
Check dependencies
Code Sign error: No codesigning identities found: No codesigning identities (i.e. certificate and private key pairs) that match the provisioning profile specified in your build settings (“eOffice3sDistributionProvision”) were found.
** BUILD FAILED **
The following build commands failed:
	Check dependencies
(1 failure)
ERROR building one of the platforms: Error code 65 for command: xcodebuild with args: -xcconfig,.../eOffice3s/platforms/ios/cordova/build-release.xcconfig,-project,eOffice.xcodeproj,ARCHS=armv7 arm64,-target,eOffice,-configuration,Release,-sdk,iphoneos,build,VALID_ARCHS=armv7 arm64,CONFIGURATION_BUILD_DIR=.../eOffice3s/platforms/ios/build/device,SHARED_PRECOMPS_DIR=.../eOffice3s/platforms/ios/build/sharedpch
You may not have the required environment or OS to build this project
Error: Error code 65 for command: xcodebuild with args: -xcconfig,.../eOffice3s/platforms/ios/cordova/build-release.xcconfig,-project,eOffice.xcodeproj,ARCHS=armv7 arm64,-target,eOffice,-configuration,Release,-sdk,iphoneos,build,VALID_ARCHS=armv7 arm64,CONFIGURATION_BUILD_DIR=.../eOffice3s/platforms/ios/build/device,SHARED_PRECOMPS_DIR=.../eOffice3s/platforms/ios/build/sharedpch
Swati_S_Intel1
There is an issue with your certificate. Please follow this thread : https://software.intel.com/en-us/forums/intel-xdk/topic/630377
Nguyen_N_
I build succsess with development provision profile but when I create distribution provision profile I had got this error!
Could you help me?
PaulF_IntelCorp
Nguyen -- you need to import the matching P12 for your distribution provision file. They come in pairs. You can import multiple certificates into the cert management. Once you have multiple certs imported, you must then select the one that matches your provisioning file.
