Software Archive
Read-only legacy content
cannot connect registration center while installing
roddur
I have made a new registration in intel for non-commercial license of Parallel Studio XE 2013 SP1 Update 1 for Linux.
while I tried to install via the online installer, I get:
Checking Intel(R) Software Development Products Registration Center availability... [failed]
and asks me to check connection, proxy and firewall port 80 and 443.
As far as I understand, 80 and 443 is open, otherwise, I cant post this to the forum :D
I have also  tried offline installer(oops, thats really HUGE), that prompts:
Installation program failed to establish internet connection for activation. You
will now be taken to offline activation steps.
and directs me to  https://registrationcenter.intel.com/RegCenter/remoteactivation.aspx , where it says
"Thank you for your purchase of Intel® Software Development Products"!!!
Oops! I don't want to BUY it, as I am completely eligible for non-commercial use.
Any help please?
Andrea_P_2
I have the same problem from yesterday, i can not activate the products.It seems that theIntelRegistration Centersiteisunreachable.Thisis the errorit gives me:
Server Error in '/RegCenter' Application. Runtime Error Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off".
<!-- Web.Config Configuration File --> <configuration> <system.web> <customErrors mode="Off"/> </system.web> </configuration>
Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL.
<!-- Web.Config Configuration File --> <configuration> <system.web> <customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/> </system.web> </configuration>
Google Traduttore per il Business:Translator ToolkitTraduttore di siti webStrumento a supporto dell'export
James_T_Intel
Please try again today.  We had a downtime this weekend.  If problems continue, please let me know.
Sincerely,
James Tullos
Technical Consulting Engineer
Intel® Cluster Tools
roddur
Hi James,
This is what I am experiencing today. I have just tested after receiving your comment and it is still same.
James_T_Intel
The Intel® Registration Center indicates that you bought it, even though this is a non-commercial license.  Have you tried installing with the license file?  I'm resending that to you in case you don't have it handy.
roddur
Hi James,
I got the mail you send, but without any attachment (what we used to have as a .lic file).
And, I have not BOUGHT it, just downloaded without paying anything. May be this is equivalent?
roddur
Oops, posted too soon.
If, buying non-commercial license (which is free) is equivalent of purchasing it,  may I try generating an activation code from the link I posted above?
James_T_Intel
Yes, as I said, the text says that you bought it, obtaining a non-commercial license is equivalent.
roddur
ok...thanks
roddur
Just found that ofline installer is working fine, without requiring the code. license key is enough, as it should be.
James_T_Intel
Great!  I'm glad it's working now.
Anupam_J_
Dear all
I have download the student version of parallel_studio_xe_2015_update3 from the link provided by intel through mail ([email protected]). I am getting the following error when I am trying to install that package after giving the provided serial no-
"Installation program failed to establish internet connection for activation."
I have tried several times from last 20days.
Kindly provide the solution.
Hubert_H_Intel
I've sent you the license file which you can use for product activation when not having an active internet connection.. Pls. choose option 'Alternative activation... > Use license file'.
Regards, Hubert.
Santiago_I_
I'm having the same problem. I'm behind an HTTP proxy and not able to activate using my serial number.
How could I download a license file for offline activation?
Cheers,
Santiago.
Devorah_H_Intel
Hello Santiago,
License file was sent. Please use it for it for Alternative activation.
Devorah
Intel®Developer Support
Charles_C_1
I share the same situation with Santiago I.. The host server only has access to the Internet via an HTTP proxy, but I find it is not able to activate the parallel studio.
Could you please sent me the license file for offline activation? Thanks!
Regards.
Charles
James_T_Intel
Charles, I sent your license file via private message.
bruno_l_1
I have qualified for student version of  Parallel Studio XE Cluster Edition 2016. I'm having the same problem as Santiago and Charles with activation of the product since I have also Internet connection via an HTTP proxy.
Is it possible to get the license file for offline activation? Many thanks!
Bruno L.
Light_Intel
If you are able to connect to the Intel Registration Center, you may be able to download your own license file. Log in with your credentials, identify the product in the product list, select it and click on Manage to find and download your license file.
However, if you have a new 2016 named user license, you will have to generate the license file manually. Please refer to: https://software.intel.com/en-us/articles/how-do-i-get-a-license-file-for-an-offline-installation-of-intel-parallel-studio-xe-2016
If you still need help, please post a private message with your email address and serial number.
Noga
Intel Developer Support
Light_Intel
This issue had been resolved. If you have a similar issue please start a new thread to ensure you will be helped in a timely manner.
Noga
