Software Archive
Read-only legacy content
17060 Discussions
cilkprof failing to compile
leoferres
 Within the Makefile I only changed the var CXX = icpc to CXX = g++. All else is equal.
/usr/bin/ld: ../../3rdparty/pintool/intel64/lib/libpin.a(util_host_ia32e.os): relocation R_X86_64_PC32 against symbol `DoXsave' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: final link failed: Bad value collect2: error: ld returned 1 exit status make: *** [linux64/cilkprof.so] Error 1
What could be going on?
Barry_T_Intel
I'm not sure. I'd run into that before, but put it aside since I'd had other things to worry about and compiling with icpc worked correctly. I'll see if I can puzzle it out this week. - Barry
leoferres
Thanks for your reply, Barry. It's not critical, but I'm dying to know! Please let me know if I can be of any assistance... I can reproduce the error... always :) Leo
Barry_T_Intel
I've reproduced it. As far as I can tell, everything we compile uses the -fPIC option. The offending module seems to be in libpin.a, so I've forwarded it to the PIN developers. - Barry
