Software Archive
Read-only legacy content
17060 Discussions
comman line compile vs. Studio compile
Intel_C_Intel
I run dfvars.bat first, and use df to compile from command line, using exactly same flags shown in MS Studio. How come the .obj has a different size? .exe also has a different size.
And command line compiled .exe causes run time errors while built from MS studio, it works fine. Anyone experienced the same problem?
dpp
The options probably aren't exactly the same - look in the Project Options box to see what compiler options will be used.
Also, you don't say what the run-time errors are.
Steve
