Software Archive
Read-only legacy content
17060 Discussions
compilation order
larryscheier
I love DVF but I have one problem. The linker does not seem to know the proper order in which to compile dependent mod files. If I do a re-build all, for example, I would expect the linker to compile all the mod files first, starting with those which are nested within other mod files. Is there a way to force the linker to compile these first? Otherwise, I get all sorts of error about Mymod.mod file not found when a source file with a USE Mymod is encountered.
Larry Scheier
SEI Associates
[email protected]
I assume that by "linker" you really mean "compiler". Try doing Build..Update dependencies and see if that cures the problem. If it doesn't, send a ZIP file of your workspace, and a description of the problem, to us at [email protected] and we'll look at it. Normally, the build system DOES know how to build files in the proper order.
Steve
larryscheier
Thanks, Steve. That seems to do the job.
Larry Scheier
SEI Associates
