Software Archive
Read-only legacy content
17060 Discussions
configuration of external bridge network
Satoshi_Ohshima
Hi, all.
I'm trying to configure external bridge network using examples from MPSS_Users_Guide.
I want to access host CPU and MIC from other PCs at the same subnet network.
Then, I wrote ifcfg-br0 file as follows
DEVICE=br0
BOOTPROTO=none
ONBOOT=yes
IPADDR=<IP_A>
NETMASK=255.255.255.0
TYPE=Bridge
MTF=9000
and executed following commands
micctrl --addbridge=br0 --type=external --ip=<IP_A> --netbits=16 mic0
micctrl --network=static --bridge=br0 --ip=<IP_B>
(micctrl --network=static --bridge=br0 --ip=<IP_B> --netbits=16 mic0 cause warning and the same incorrect result is obtained)
After that, network and mpss services are restarted.
Then, IP address of each network interfaces are as follows
# ifconfig | grep -e "Link " -e "inet "
br0       Link encap:Ethernet  HWaddr xx:xx:xx:xx:xx:xx
          inet addr:<IP_A>  Bcast:<IP_A_Bcast>  Mask:255.255.255.0
eth0      Link encap:Ethernet  HWaddr xx:xx:xx:xx:xx:xx
          inet addr:<IP_C>  Bcast:<IP_A_Ccast>  Mask:255.255.0.0
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
mic0      Link encap:Ethernet  HWaddr xx:xx:xx:xx:xx:xx
As a result, I confirmed that I can login to CPU and MIC by ssh from host CPU.
However, from other PCs, I can login to CPU but I can't login to MIC.
Would you show me the correct procedures of network configuration ?
Kind regards
Bsc_Cns
Hi Satoshi,
It sounds like forwarding is not enabled in your system. Can you check the output of the following command?
/sbin/sysctl net.ipv4.ip_forward
If return value is 0, then enable forwarding by executing the following:
/sbin/sysctl -w net.ipv4.ip_forward=1
If it still doesn't work, please check your firewall settings, in particular, the FORWARD CHAIN policy. Forwarding between the host and the mic should be allowed.
Hope it helps.
Best regards.
Satoshi_Ohshima
Thank you for your comment.
It was true that I didn't configure the net.ipv4.ip_forward parameter. Then, I modified the parameter and tried to configure mic. However, I still can not login to mic0.
Here is my current IP configurations:
          inet addr:<IP_A>  Bcast:<IP_A_BCAST>  Mask:<IP_A_MASK>
          inet addr:<IP_C>  Bcast:<IP_C_BCAST>  Mask:<IP_C_MASK>
While I think I can login to mic by connecting <IP_A>, I accessed the host CPU.
Do you have any solutions?
Thanks, Satohshi OHSHIMA
FYI, these are of my ifcfg-* files:
# cat ifcfg-mic0
DEVICE=mic0
ONBOOT=yes
NM_CONTROLLED="no"
BRIDGE=br0
# cat ifcfg-br0
DEVICE=br0
BOOTPROTO=none
ONBOOT=yes
IPADDR=<IP_A>
NETMASK=<IP_A_MASK>
TYPE=Bridge
MTF=9000
This is my iptables rules. Do I need to configure some rules? (There are no rules on MPSS_Users_Guide.)
# iptables -L
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Bsc_Cns
I think you should connect straight to the mic console to see if the network configuration is ok. First of all ensure your mic is online:
micctrtl -s mic0
After, connect via minicom software to device /dev/ttyMIC0 with Bps/Par/bits = 57600 8N1 (this works for me) and try to do an ifconfig to see if the network interface is properly configured.
Satoshi_Ohshima
Thank you Bsc, but this problem was my stupid mistake! I forgot to re-configure the user account after using micctrl --initdefaults. My network configuration has no problem. In addition, I confirmed that net.ipv4.ip_forward=1 is NOT required when only I login to mic by ssh, and it is required when mounting external nfs directory.
Anyway, thanks for your help!
Sally_H_
Hi - I think I went through the same problems in an earlier topic - 490138.  I tried to leave a comment yesterday, but maybe it doesn't like URLs.  If you check that topic, you will see that we did solve it and it all works for us now - with limitations on commands you can use.  Have a look at my comments in that topic - you will need to specify the correct gateway on the phi co-pros themselves...they default to zero.  Tho' it was all tested on MPSS 3.1.
