Can anyone help?
I am trying to convert f77 language to f90 with a convert program. When I run it I get a severe error (29) file not found. But the file is in the DSP subdirectory and I even tried typing in the whole path.
The program is a console application. The convert program is in f90. I am wondering are there any Project settings that should be set or any other settings on operating system files that should be set?
Comments Please?
Ken
Comments Please?
Ken
A File Not Found error has nothing to do with F77-F90 nor with project or OS settings. It is simply that the file you are asking Fortran to open is not where it is specified, with the name you gave.
When you get the error message, it should give the path it was using to open the file. What is it? (If you have ERR= or IOSTAT= on the OPEN, take them off so that you see the full error.)
Steve
Steve
I discovered that the convert program can only read a .f extension and not a .for
Thanks for the comment!
If anyone is interested the convert program is found at this link:
http://www.fortran.com/fort ran/market.html
Ken
Ken
Here's a much simpler F77-F90 conversion program:
No "conversion" is necessary - any valid Fortran 77 program is a valid Fortran 90 program, and CVF supports Fortran 77 and many extensions.
Steve
program convert end
Steve
