Software Archive
Read-only legacy content
17060 Discussions
create obj file using raw streams
Arun_D_
I want to create a obj file(i.e. a 3d model) using the raw stream values(depth and color) from the realsense camera. Is it possible to create that obj file and use it in unity?
Amit_M_Intel
Hi Arun,
We do not offer a built-in solution at the moment to create 3D object files from the depth data. If you happen to create it yourself, there is no problem using it in Unity as Unity supports obj files.
Amit
