Software Archive
Read-only legacy content
17060 Discussions
crosswalk package name validation bug
amir_b_
as I reported in the old forum, the crosswalk package name validation has serius bug which does not allows apps id with number in the first part to be build.
for example: you cant build app with the latest crosswalk with id of example111.net has the first part has number.
I just found the bug source and gave a simple solution which the cordova team is using.. I opend a pr but nobody looking so I dont know where the right place to tell about the bug, maybe somehwere here can show it to the developrs.
here the pr on github:
https://github.com/crosswalk-project/crosswalk-cordova-android/pull/162
here is the pr opened in the cordova github reop:
https://github.com/apache/cordova-android/pull/174
pls its very easy fix and it will help you with a lots of unknowns builds fails.
would love to know if it will get merged
amir_b_
this bug also exists on the latest intel xdk cordova build (i think 4.1.2)
John_H_Intel2
Thank you for the info. We (the XDK team) do not maintain the Crosswalk project. The Crosswalk team will need to pull the fix, incorporate it into the project and then the fix will come to the XDK. You should follow up with them to try to get the fix incorporated.
amir_b_
I understand that you not maintain crosswalk, but its somehow related to you as if crosswalk have bugs, you have bugs and we just cant build our projects, I think nobody is looking at theire github and its so easy fix.
would love if you can give some help contacting them, thanks :)
