Software Archive
Read-only legacy content
17060 Discussions
debug mode importing external javascript failed
Davide_G_
Intel xdk 2893 installed on windows 10 PC
Smartphone used for test: Samsung galaxy s3 with android 4.3
IN ENGLISH
I'm testing the exhample included in Intel sdk the "geolocation-sample": https://software.intel.com/en-us/xdk/article/intel-xdk-geolocation-sample
when I upload it to the server(using the test tab) and then I run into my sansung galaxy S3 by using the "intel app preview" work perfeclty.
But if I try to use in debug mode I get this javascript error and the app won' t work
Failed to load resource: the server responded with a status of 404 (Not Found)     http://maps.google.com/maps/api/js?sensor=false
Thank you,
Davide
IN ITALIAN
Buongiorno a tutti sto testando l' esempio di geolocalizzazione incluso in intel sdk ho riscontrato alcuni problemi:https://software.intel.com/en-us/xdk/article/intel-xdk-geolocation-sample
In pratica se uso il tab "TEST" e carico il file sui vostri server e poi lo eseguo sul cellulare tramite "intel app preview" funziona perfettamente.
Mentre provo ad eseguire il debug mode non riesce a caricare il file esterno di google maps mi restituisce questo errore:
Grazie,
Saluti Davide
Elroy_A_Intel
This appears to be an issue with you application's ability to access the following URL at http://maps.google.com/maps/api/js?sensor=false. Have you tried to evaluate your application with the Debug tab and the Build tab with the Android build target as well as Crosswalk for Android?
Davide_G_
Hi, If I build the app (both android or android crosswalk). The map don' t load correctly but load only the map button.
I also tried to add in whitelist(with no results) maps.google.com, http://maps.google.com/ and http://maps.google.com/*
In attachement all the project
recapping:
- In emulate and using the test "tab" to push the file and open the app via app preview work perfectly
- In debug "tab" i have the error to load google.maps.com and I saw on the screen of the smartphone only the message "Determining Your Location"
- If I build the app both crosswalnk or android I saw on the screen an empty google maps with only the control.
Thank you very much
Davide
