Software Archive
Read-only legacy content
17060 Discussions
derived type
Intel_C_Intel
I have composed a code(below) using CVF 6.5A(Intel Windows NT 4.0)
At compiling, several error messages were printed.
But could not find out, the problems.
Is there anyone to help me ?
*** source code ***
module Common
type T_Type0
real*8, pointer :: Coef(:)
integer*4, pointer :: Indx(:)
end type
type T_Type1
type (T_Type0), pointer :: Type1(:)
end type
type T_Type2
type (T_Type1) :: Type2
end type
type (T_Type2) :: Type3
end module
use Common
implicit real*8 (a-h, o-z), integer*4 (i-n)
if(not(associated(Type3.Type2.Type1))) &
allocate(Type3.Type2.Type1(10))
if(not(associated(Type3.Type2.Type1(1).Indx))) &
allocate(Type3.Type2.Type1(1).Indx(100))
do i = 1, 100
Type3.Type2.Type1(1).Indx(i) = i
write(*,*) i, Type3.Type2.Type1(1).Indx(i)
end do
stop
end
*** error message ***
Compaq Visual Fortran Optimizing Compiler Version 6.5 (Update A)
Copyright 2001 Compaq Computer Corp. All rights reserved.
dum.f90
dum.f90(25) : Error: Syntax error, found '.' when expecting one of: ( , )
dum.f90(28) : Error: Syntax error, found '.' when expecting one of: ( , )
dum.f90(25) : Error: An allocate/deallocate object must have the ALLOCATABLE or
POINTER attribute. [TYPE2]
dum.f90(25) : Error: An allocate-shape-spec-list is required for this allocate o
bject. [TYPE2]
POINTER attribute. [TYPE1]
dum.f90(25) : Error: The rank of the allocate-shape-spec-list differs from the r
ank of the allocate-object. [TYPE1]
dum.f90(28) : Error: An allocate/deallocate object must have the ALLOCATABLE or
dum.f90(28) : Error: An allocate-shape-spec-list is required for this allocate o
bject. [TYPE2]
dum.f90(28) : Error: This name has not been declared as an array. [TYPE1]
Steven_L_Intel1
Replace the . component separators with the standard % - then it will compile. The dots should work - we'll look at that.
Please note that our free support address is [email protected] I see that you asked here and in comp.lang.fortran, but not at our support address.
Steve
Intel_C_Intel
Ok !!
It works fine.
Thanks Steve.
