Software Archive
Read-only legacy content
17060 Discussions
error installing Fortran Compiler 10.0 on Ubuntu...
roohishokri
I get the following error after entering my serial number:
"The Intel Software Setup Assistant may attempt to connect to the
Intel Software Development Products Registration Center to validate your Serial Number.
This may take several minutes depending on your network. Please wait...
You may press Ctrl+C to cancel.
secore.new: relocation error: /lib32/libresolv.so.2: symbol strlen, version GLIBC_2.0 not defined in file libc.so.6 with link time reference"
I should mention that I got a serial number for Non-comercial version of Fortran Composer XE for Linux. But I needed an older version so I went for downloading the older ones. Therefore I used that serial No. for the older one as well (because the website does not provide me a separate serial No. for the older one).
Any help would be much appreciated.
Thank you.
Nikolay_L_Intel
The release you used is quite old and install client was linked with very old glibc, version 2.0. It was done for backward compatibility purposes.
There are two workarounds available:
1) Please try to install older version of GLIBC, 2.0-2.1, and restart installation
2) The product RPM files are available in /data/intel-*.rpm. Please install it manually using rpm2cpio, alien or other install tools delivering RPM files to Ubuntu systems.
I have subscribed to this topic, so please feel free to contact mehere for any help.
Thank you,
- Nikolay
