Software Archive
Read-only legacy content
17060 Discussions
error notification
ali_khatami
hello
i,m using plugin onesignal
it work plugin
but, after reciving notification, application error & stop
see picture error:
https://uploads.intercomcdn.com/i/o/11550396/68a9547ef0e74942b6617e8e/Screenshot_20161010-231608.png
help me thanks
PaulF_IntelCorp
I recommend you use the debugger to determine what is wrong. The issue you're running into is outside the scope of the help we are able to provide. You can try using the Debug tab. If that does not help, you'll have to debug a built app using this technique > https://software.intel.com/en-us/xdk/docs/intel-xdk-debug-and-test-overview#RemoteChromeDevTools < You may also have to monitor the Android console, which requires tools outside of the XDK.
ali_khatami
PaulF_IntelCorp
If Debug tab does not work, you'll have to debug a built app using this technique > https://software.intel.com/en-us/xdk/docs/intel-xdk-debug-and-test-overv... < You may also have to monitor the Android console, which requires tools outside of the XDK.
