Software Archive
Read-only legacy content
17060 Discussions
error while loading shared libraries libmpifort.so.12 on MIC
Wentao_Z_
I was trying to run my executable natively on MIC but obtained the following error:
[wzhang80@xpacc-serv-03-mic0 plascomcm]$ ./bin/plascomcm.mic
./bin/plascomcm.mic: error while loading shared libraries: libmpifort.so.12: cannot open shared object file: No such file or directory
I realized that the runtime libraries should be copied to the MIC cards. I did that and added the location of the library to the PATH:
[wzhang80@xpacc-serv-03-mic0 plascomcm]$ echo $PATH
/usr/bin:/usr/sbin:/bin:/sbin:/home/wzhang80/impi/5.0.2.044/mic/lib/
[wzhang80@xpacc-serv-03-mic0 plascomcm]$ which libmpifort.so.12
/home/wzhang80/impi/5.0.2.044/mic/lib/libmpifort.so.12
But I still got the same error:
Ant suggestions? Thanks!
    Wentao
Wentao_Z_
This issue is solved by setting the locations of library in LD_LIBRARY_PATH.
    Wentao
