Software Archive
Read-only legacy content
17060 Discussions
error while loading shared libraries: libudev.so.0: cannot open shared object file: No such file or directory
Leonardo_S_4
Downloaded intel XDK today.
running fedora 23 64 bits
got this error
any help is welcome
PaulF_IntelCorp
Leonardo -- are you submitting these crash logs? Please do, engineering does review them.
In the meantime, I can't promise that an easy workaround can be identified. We test only against Ubuntu, if you are unable to get this working on Fedora I recommend you create a new machine based on Ubuntu or run Ubuntu in a VM on your Fedora machine and run the XDK inside that Ubuntu VM.
Leonardo_S_4
Paul F. (Intel) wrote:
See if this helps > https://software.intel.com/en-us/xdk/faqs/general#xdk-on-fedora <
Hi Paul, it helped however XDK always opens the crash report window:
error report
https://www.dropbox.com/s/8f5kmt3i8j3h11m/Captura%20de%20tela%20de%202016-06-25%2011-37-34.png?dl=0
this is what my XDK folder looks like now:
[sombriks@sephiroth XDK]$ ls -la
total 92
drwxr-xr-x. 6 sombriks sombriks  4096 Jun 25 11:32 .
drwxr-xr-x. 4 sombriks sombriks  4096 Jun 24 22:44 ..
drwxrwxr-x. 8 sombriks sombriks  4096 Jun 25 11:36 bin
-rwxr-xr-x. 1 sombriks sombriks 22097 Jun  3 17:25 CHANGELOG.md
lrwxrwxrwx. 1 sombriks sombriks    23 Jun 25 11:32 libudev.so.0 -> /usr/lib64/libudev.so.1
-rwxr-xr-x. 1 sombriks sombriks    16 Jun  3 17:25 nw-version.txt
-rwxr-xr-x. 1 sombriks sombriks  6183 Jun  3 17:25 revision.txt
drwxr-xr-x. 2 sombriks sombriks  4096 Jun 24 22:43 .scripts
drwxr-xr-x. 6 sombriks sombriks  4096 Jun 24 22:43 uninstall
-rwxr-xr-x. 1 sombriks sombriks   182 Jun  3 17:27 uninstall_GUI.sh
-rwxr-xr-x. 1 sombriks sombriks 21806 Jun  3 17:27 uninstall.sh
drwxrwxr-x. 8 sombriks sombriks  4096 Jun 24 22:43 xdk
-rwxr-xr-x. 1 sombriks sombriks   201 Jun 24 22:47 xdk.sh
for your time thak you.
PaulF_IntelCorp
Leonardo_S_4
Hello Paul,
indeed i'm sending the reports.
i'll try to figure something on different setups and see what happens.
Thanks for the advices.
