Software Archive
Read-only legacy content
17060 Discussions
errors when running a program using _Cilk
TK
I mostly have in my program _Cilk_shared for structs, global variables, and functions. When I run my program I get the following errors:
HOST--ERROR:myoiScifGetRecvID: Call recv() Header Failed! for source: 1, errno = 104
HOST--ERROR:myoiScifSend: Call send() Failed! errno = 104
HOST--ERROR:myoiSend: Fail to send message!
HOST--ERROR:_myoiWatchdogDaemon: could not send to target: 1
offload error: process on device 0 was terminated by signal 11 (SIGSEGV)
Other times when I run my program I get the following kind of lines (a lot of them) followed by the above HOST--ERROR lines:
CARD--ERROR:1 myoiPageFaultHandler: 0x5827ec0 Out of Range!
CARD--ERROR:1 _myiPageFaultHandler: 0x5827ec0 switch to default signal handle
My icc -V prints as follows:
Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel (R) 64, Version 13.1.1.163 Build 20130313
Why do I get these errors? Thanks.
Frances_R_Intel
If I understand you correctly, sometimes when you run your program you see the CARD-ERROR messages and sometimes you do not see them but you always see the HOST-ERROR messages? What is different between the two runs?
Also - are you using _Offload_shared_malloc to allocate your memory? are you trying to use STL?
TK
I just run ./a.out, sometimes it gives the CARD--ERROR+HOST--ERROR, and sometimes it gives only HOST--ERROR messages.
Yes, I am using the _Offload_shared_malloc to allocate the memory. Thanks.
TK
I forgot to allocate one of the arrays of struct using _Offload_shared_malloc, it was doing it with malloc. Changed that and it worked fine. Thanks.
Frances_R_Intel
I'm glad it's working now.
