Software Archive
Read-only legacy content
17060 Discussions
failed_to_extract_archive
Script47
I uninstalled Intel XDK because of an issue I was having, however now when I try to install it again it gives me the following error,
I allowed through the firewall, I closed everything then run it as administrator and still I am getting the above error.
Giselle_G_Intel
When you uninstalled the old XDK that was having problems, did you delete everything and then pull this installer from the Intel® website? Try to delete the current installer you have and pull again from the following link > https://software.intel.com/en-us/intel-xdk <
Also, follow the instructions here to completely remove everything from the old version of XDK if you still are having issues. It could be that there are some residuals left of the old XDK that are causing problems with your current install. >https://software.intel.com/en-us/xdk/faqs/general#uninstall-xdk <
Let me know if you continue to have problems.
