I'm making a single dll which starts off in c++, then calls some subroutines in fortran which in turn call a c++ function and when I link it I get:
sbsday.obj : error LNK2001: unresolved external symbol _addsbsoutputrecord
(and it obviously doesn't link)
sbsday is a fortran subroutine and addSbsOutputRecord is a c++ function which has been defined as:
extern "C" void addsbsoutputrecord(char lulc[], int hru, int gis, int sub, int mgt, int mon, double area, double otherValues[]);
in a c++ header file. It also has the necessary interface defined for it in a fortran mod file.
If I make the project an exe instead of a dll then it links properly and works fine. I have tried defining the c++ function "addSbsOutputRecord" several different ways and in several different files (never at the same time though) and it still doesn't work.
Any help would be greatly appreciated.
You didn't show us Fortran INTERFACE. Since I have to guess, two possible causes come to my mind:
1)
2) Don't forget REFERENCE attribute for lulc[] argument.
Well, this is the way I'd write prototype and caller:
Of course, if lulc should be an array of BYTE, not a string, you should declare it as
HTH
Jugoslav
1)
!DEC$ATTRIBUTES C implies name mangling: lowercase. However, IIRC in MSVC++ default name mangling is "as-is", so you should probably need an alias. It's unclear from your post whether the name is lowercase in .h and mixed-case in .cpp; I'd suggest keeping declaration (.h) and definition (.cpp) identical2) Don't forget REFERENCE attribute for lulc[] argument.
!=.cpp and .h============ extern "C" void addSbsOutputRecord(char lulc[], int hru, int gis, int sub, int mgt, int mon, double area, double otherValues[]) ; !=.f90 interface subroutine addSbsOutputRecord(lulc, hru, gis, sub, mgt, mon, area, otherValues) !DEC$ATTRIBUTES C, ALIAS: "_addSbsOutputRecord":: addSbsOutputRecord !DEC$ATTRIBUTES REFERENCE:: lulc character(*):: lulc integer:: hru, gis, sub, mgt, mon real(8):: area, otherValues(*) end subroutine end interface
byte:: lulc(*). In that case, REFERENCE is not needed (but doesn't do harm either). HTH
Jugoslav
...I'd just add a tip: when in doubt about name exports/imports, open .obj files of caller and callee in a text editor. Although most of it would be garbage, you'd be able to find exact mangling of exported/imported names and conclude where the problem lies.
