Software Archive
Read-only legacy content
17060 Discussions
gdb-ia fails with SIG113 on mac os x
berg__erez
When I try to use gdb-ia on a fortran program compiled with ifort -g on mac os x, it fails with the following message:
(gdb) r
Starting program: /Users/erez/Documents/gfortran/test/test/a.out
During startup program terminated with signal SIG113, Real-time event 113.
(gdb)
Looking up this error online, I tried to run
set startup-with-shell off
(as suggested here, for instance), but it doesn't solve it.
Any suggestions would be appreciated... I'm sorry if the answer to this was posted in this forum, I couldn't find it.
I'm running on macOS Sierra 10.12.6.
Thank you,
Erez
Ibarra__Lander
Hi Erez,
Were you able to find a solution to this problem? I am currently facing the same problem with High Sierra 10.13.6. gdb-ia returns the following:
I was able to make the default gdb version work albeit not optimized for Intel Fortran. I tried to follow the same logic for gdb-ia I followed previously and add a certificate associated with the program. This didn't seem to work.
gdb-ia's version is:
GNU gdb (GDB) 7.8-8.0.137
whereas the gdb version that is working is:
GNU gdb (GDB) 8.0.1
Any help on this is appreciated.
Thank you.
