Software Archive
Read-only legacy content
17060 Discussions
get error when try to show busy indicator
fabrizio_d_
i added notification cordova plugin but still get the error "Uncaught TypeError: Cannot read property 'showBusyIndicator' of undefined index_user_scripts.js:13(anonymous function) index_user_scripts.js:13x.event.dispatch jquery.min.js:5v.handle" when triyng to show busy indicator.
this is the javascript:
 $(document).on("change","#sel_produttori", function(evt)
        intel.xdk.notification.showBusyIndicator();
Elroy_A_Intel
I recommend using the Apache Cordova equivalent plugins instead of intel xdk plugins. Currently intel xdk plugins are not being maintained. You can find the Cordova* Notification plugin in the Core Plugins section under the Plugins Management dialog on the Projects Tab.
PaulF_IntelCorp
By "system busy indicator" I assume you are referring to the Android LED? If so, please read this SO post > http://stackoverflow.com/questions/6169291/changing-led-color-for-notifications -- if that is not what you mean, please clarify.
PaulF_IntelCorp
Fabrizio -- our IT blocks access to some sites. The site you are using to show an image of your issue is blocked, so I can't see the image. Can you simply attach the image to your post using the "Attach Media" button below the edit window?
fabrizio_d_
just attached the image.
Anusha_M_Intel1
@Fabrizio. I noticed you issue was resolved here: http://stackoverflow.com/questions/34182122/how-to-show-showbusyindicator-into-xdk-html5-hybrid-application
fabrizio_d_
yes i know, the only problem is that it does'nt work in emulator.
Also i dont understood if it is working only on android or other so too, i've no one to test.
PaulF_IntelCorp
Fabrizio -- testing it in the Emulate tab will not be a confirmation that your app runs properly on real devices, the Emulate tab does not represent real devices, it is simply a "Cordova API simulator." Getting an app to work in the Emulate tab does not mean it will work on a real device. Please see this doc page > https://software.intel.com/en-us/xdk/docs/intel-xdk-dev-emulator-limitations
