Software Archive
Read-only legacy content
17060 Discussions
how to add multiples marker to the google map widget of intel xdk
nicolas_r_
hi im new at intel XDK and i would like to use her widget of google maps and add some markers with icon and info windows i tried modifying the widget but i get confused by her code, and tutorial or  guide i will apriciate a lot
Chris_P_Intel
Take a look at the services and maps tutorial. It might help. https://software.intel.com/en-us/videos/service-results-as-markers-on-a-google-map
Though, if you want to really work intensely with Google Maps, you'll have to dive into the Google Maps API and write your own JS code. The widget can get help set up a map and the basic JS for you, but for anything complicated it's BYO.
nicolas_r_
I tried ussing Google Maps API with JS but i get stucked into a problem tath the maps shows full grey and i have to rotate the screen to fix tath but i don't know how to fick from the code
John_H_Intel2
Not sure if this will work for you or not, but its a snippet of code I used a long time ago to fix the issue you are describing.
    function triggerMap()   // called on div load. dont need to call from another function
        google.maps.event.trigger(_map, 'resize');
        _map.panTo(new google.maps.LatLng(40.328359,-76.785390));
<div title="Location" id="ourLocation" class="panel" data-load="triggerMap" style="height:100%" scrolling="no">
        <div><header>stuff can go here </div>
            <div id="map_canvas" style="min-height:100%;height:100%;"></div>
    </div>
nicolas_r_
so i have to add the function triiger on top of my js file? and the data load on the div where is the page of the map? im new on this sorry
John_H_Intel2
Correct, that should do it for you.
nicolas_r_
can pls sendme a code of the map with her div like to edit and start from tath
