Hello
There are two problems
1. Format of the video file is said h.264, but the file name what? I used mp4, h264, avi have to file, but they can not be opened will be displayed incorrectly formatted
2. How to achieve real-time video, now click on the button to display a screen can not be real-time display
private void button4_Click(object sender, EventArgs e)
// RecordORPlayback(@"C:\RecordTemp\" + DateTime.Now.ToString("yyyyMMddHHmmss") + ".h264", true);
RecordORPlayback(@"C:\RecordTemp\" + DateTime.Now.ToString("yyyyMMddHHmmss") + ".mp4", true);
void RecordORPlayback(String file, Boolean record)
PXCMSenseManager sm = PXCMSenseManager.CreateInstance();
sm.captureManager.SetFileName(file, record);
//sm.EnableStream(PXCMCapture.StreamType.STREAM_TYPE_COLOR, 640, 480, 0);
sm.EnableStream(PXCMCapture.StreamType.STREAM_TYPE_COLOR, 640, 480);
sm.captureManager.SetRealtime(true);
sm.Init();
//for (int i = 0; i < 300; i++)
//Console.WriteLine(i);
if (sm.AcquireFrame(true).IsError()) { }
PXCMCapture.Sample sample = sm.QuerySample();
PXCMImage image = sample.color;
PXCMImage dimage = sample.depth;
PXCMImage.ImageData data;
image.AcquireAccess(
PXCMImage.Access.ACCESS_READ,
PXCMImage.PixelFormat.PIXEL_FORMAT_RGB32,
out data);
Bitmap bm = data.ToBitmap(0,
image.info.width,
image.info.height);
pictureBox1.Image = bm;
sm.ReleaseFrame();
sm.Dispose();
video format is rssdk
but how to open this file ?
You have to use the SDK to view it. If you pass your RecordORPlayback method the filename of the video you saved and false, that should do it!
Yes i use RecordORPlayback method and change filename is .rssdk
RecordORPlayback(@"C:\RecordTemp\" + DateTime.Now.ToString("yyyyMMddHHmmss") + ".rssdk", true);
But how can I go to verify my video is correct? Or what I by reference the document?
If you call:
RecordORPlayback(@"C:\RecordTemp\%name of file already saved%.rssdk", false);
And run it, your app should play it back.
Alternatively, you could use the Raw Streams sample in Playback mode to view your video.
