Software Archive
Read-only legacy content
17060 Discussions
iOS Cordova version
Alessandro_S_
I notice that setting the CLI version to 3.5.1 many problems of 3rd party plugin ( facebookconnectplugin included) are solved.
This is because this CLI version (3.5.1) doesn't use cordova 3.7.0 that has some bug. The problem is that apps built with this CLI version won't be supported in a short time. What's the solution? I tried to move to CLI 5.1.1 but errors while building.
Amrita_C_Intel
I  tried to recreate this issue by including Facebook connect plugin and using CLI 5.1.1 version and the built was successful for ios.
Alessandro_S_
I got error. What version of xdk you're using?
Alessandro_S_
Sorry I made a mistake. Ios build 5.1.1 is ok. Same project fails in android with 5.1.1. Unfortunately I can no longer use crosswalk build: since september 18: even a simple project with this plugin crashes at runtime when I call plugin login function. Try yourself, add this code to the project that You've just built for iOs with CordovaFacebookPlugin
function TestMe()
var fbLoginSuccess = function (userData) {
    alert("UserInfo: " + JSON.stringify(userData));
//facebookConnectPlugin.browserInit("829140770512386");
facebookConnectPlugin.login(["public_profile"],
    fbLoginSuccess,
    function (error) { alert("" + error) }
and call TestMe. If you build crosswalk You'll notice that your app will crash. The same project built by me 3/4 days ago of course worked.
speachless...what's happened to intel xdk environment? I opened a post 3 days ago but still no answers from Intel (upset).
https://software.intel.com/en-us/forums/intel-xdk/topic/593939
 That's why I tried to build a no crosswalk version: CLI 4.1.2 is veri unstable, app crashes on close, graphical leaks and so on...so I thought that 5.1.1 would be better but building with CLI 5.1.1 fails!
Please help me, forward the crosswalk issue to engineer or I don't know where but please give me an answer. I need my crosswalk app back because I used to deploy that one, more stable and working!
Thank you
Amrita_C_Intel
send your project via PM.
