Software Archive
Read-only legacy content
17060 Discussions
iOS app : Black background appears when slide down or up
Ozgur_O_
Hi All,
I developed an iOS application for use of iPads only.
When i was testing the app on my iPad , noticed a quirk behaviour.
When i slide down or up the page, a black gap is appearing on top or bottom.
How can i fix this issue?
PaulF_IntelCorp
I think I understand what you are talking about. There is a Cordova option you can set in the intelxdk.config.additions.xml file. If you don't have one of those files in your project, use:
  • Start a New Project
  • Templates
  • Blank
  • HTML5 + Cordova
to create a blank template. In that blank template you'll find an intelxdk.config.additions.xml file that you can copy into your project and then add this line:
    <preference name="DisallowOverscroll" value="true" />
Ozgur_O_
anyone? hello? :)
PaulF_IntelCorp
Not familiar with that quirk. Can you provide a simple project that duplicates it? ZIP the entire sample project and attach it to a post.
Ozgur_O_
I removed some unnecessary files. just sending the login page. you can see the problem there.like refreshing facebook page in the mobile by sliding down...
PaulF_IntelCorp
  • Templates
  • Blank
  • HTML5 + Cordova
Ozgur_O_
Yes that was what i exactly needed. Thanks for your help..
