Software Archive
Read-only legacy content
17060 Discussions
iOS build fails using WKWebView
Giorgio_B_1
Good morning,
i tried on XDK 1621 + cordova 3.5 and XDK 1995 + cordova 4.1.3 following this guide
https://software.intel.com/en-us/xdk/docs/building-cordova-ios-app-with-wkwebview
but the build fails :( what am i doing wrong?
John_H_Intel2
The author changed the plugin recently and looks like it has issues with dependencies. I tried to build with it and looking at the logs I found this (not sure if its helpful or not).
Fetching plugin "cordova-plugin-webserver" via plugin registry
npm http GET http://registry.cordova.io/cordova-plugin-webserver
npm http 404 http://registry.cordova.io/cordova-plugin-webserver
Failed to install 'com.telerik.plugins.wkwebview':Error: 404 Not Found: cordova-plugin-webserver
    at RegClient.<anonymous> (/Developer/cordova/4.1.2/node_modules/cordova/node_modules/cordova-lib/node_modules/npm/node_modules/npm-registry-client/lib/request.js:268:14)
    at Request.self.callback (/Developer/cordova/4.1.2/node_modules/cordova/node_modules/cordova-lib/node_modules/npm/node_modules/request/index.js:148:22)
    at Request.EventEmitter.emit (events.js:98:17)
    at Request.<anonymous> (/Developer/cordova/4.1.2/node_modules/cordova/node_modules/cordova-lib/node_modules/npm/node_modules/request/index.js:876:14)
    at Request.EventEmitter.emit (events.js:117:20)
    at IncomingMessage.<anonymous> (/Developer/cordova/4.1.2/node_modules/cordova/node_modules/cordova-lib/node_modules/npm/node_modules/request/index.js:827:12)
    at IncomingMessage.EventEmitter.emit (events.js:117:20)
    at _stream_readable.js:919:16
    at process._tickCallback (node.js:419:13)
Looking more I found
<plugin xmlns="http://apache.org/cordova/ns/plugins/1.0" id="com.telerik.plugins.wkwebview" version="0.4.0">
<dependency id="cordova-plugin-webserver" />
Expecting NPM and CLI 5.0
That version of the plugin
So the dependency is not found (a guess, but it’s not on cordova io.. if it was, it would be cordova.plugin.webserver
Its possible that a previous version of this plugin will work, but you will need to try it out.
Giorgio_B_1
How can i embed a previous version of the plugin, say 0.3.8 ? The tutorial above does not explain it.
John_H_Intel2
You can either download the previous version of the plugin and install it locally or when you specify the .git url when adding the plugin, add the version you want to include such as this:
https://github.com/katzer/cordova-plugin-local-notifications.git@0.7.7
PaulF_IntelCorp
Minor correction, use this notation to do what John is recommending:
https://github.com/katzer/cordova-plugin-local-notifications.git#0.7.7
You get the number from the "branch: master" pulldown, under the list of "tags" or from the "releases" list. The string after the hash (#) must match exactly what is in the repo. If the tag in the repo says "a-Brand-new-version" then you would do it like this:
https://github.com/katzer/cordova-plugin-local-notifications.git#a-Brand-new-version
Giorgio_B_1
building continue to fail, no matter which combination of versions i use :(
PaulF_IntelCorp
I've asked one of my colleagues who has worked with that plugin to reply to this thread.
Rakshith_K_Intel
I just tried adding with version 0.3.8, it works, add the plugin with this git url:
https://github.com/Telerik-Verified-Plugins/WKWebView.git#0.3.8
Giorgio_B_1
Thank you a lot, using version 0.3.8 of WKWebView and version 4.1.2 of cordova i was able to build (i'm using XDK 1621).
0.3.8 is the last version without the "cordova-plugin-webserver" dependency, but the strange thing is that looking at the latest "cordova-plugin-webserver" (2.3.1) "plugin.xml" the plugin seems compatible with cordova 4.0.0+ so i can't figure out why using WKWebView 3.9.0 or 4.0.0 the build fails.
Other two questions:
- XDK 1621 seems to not support cordova 5.0.0+, am i wrong? Do more recent XDK versions support it?
- Is there an easy way to know which versions of XDK support wihch versions of cordova? The only method i found is set a version, try to build and see if it was really built with the requested version.
PaulF_IntelCorp
@giorio -- the problem with the later versions of that plugin is the addition in the plugin ID of the dependent plugin requirement, this line in the plugin.xml file:
That dependency ID is only recognized by CLI 5+, does not work with CLI 4. This is a major PIA that the Apache Cordova project caused when they decided to change the ID format in order to be consistent with NPM names. Note that the old naming scheme would have worked with NPM, but they felt that it would be better to change the ID naming conventions, thinking it would be a minor thing. Unfortunately, it is turning into a major problem for this very reason.
We are aware of this problem and our doing our best to help make the transition smooth, but this is not an easy one to make transparent, so it's going to cause troubles for lots of developers as these plugin IDs get updated by the plugin authors.
Your solution is a good one, during this transition period, and I'm glad to see that is worked!
