Software Archive
Read-only legacy content
17060 Discussions
ifort error #10310: flexnet error code 1075813536
Jordan
I am trying to compile using ifort in Abaqus and come across this error code when it tries to compile.
I am running on Windows 7, 64 bit.
Here is the file contents:__________________
Abaqus JOB std_user
Abaqus 6.13-4
Abaqus License Manager checked out the following licenses:
Abaqus/Standard checked out 5 tokens.
<40 out of 45 licenses remain available>.
Begin Compiling Abaqus/Standard User Subroutines
5/25/2017 9:25:15 AM
ifort: error #10310: Failed to enable trusted storage check for licensing: WARNING: Enable Trusted Storage failed (flexnet error code 1075813536). Trusted Storage based license could not be supported
Abaqus Error: Problem during compilation - std_user.for
Abaqus/Analysis exited with errors
_______
I have seen this issue on the forums, but all have a simple flexnet error code. I cannot find any background on this code I am receiving.
Thanks in advance.
Jordan
This error went away after I changed abq6134.bat. I attempted to add a line, similar to this, but it did not work.
"C:\Program Files
(x86)\Intel\Compiler\11.0\072\fortran\Bin\intel64\ifortvars_intel64.bat"
set FORTRAN_VARS_SET=1
I deleted my addition and resaved the .bat file. Then the error went away.
Anyone have any insight of why this issue may occur for others?
