Software Archive
Read-only legacy content
iframe ?
MATRIX_R_
i use contruct 2 and a iframe plugin ... to show my website on iframe via construct 2
i would like to know if it's possible to call cordova api (admob banner , interstitial etc ...) from the website that is iframed (and not directly from the cordova project)
thanks
Chris_P_Intel
I believe that is doable.
The standard and safest way to do that is via the postMessage API.  ( https://developer.mozilla.org/en-US/docs/Web/API/Window/postMessage ) With Google you can find several tutorials, stack overflow questions, etc. that will help set this up.
The unsafe way is to simply have the code in the iframe  access the plugin via window.parent  (  window.parent.some_cordova_plugin.foo() ). That may work since the parent "window" is not served, and so you might be able to skip any cross-domain access problems. But I wouldn't count on it. It would not surprise me to see that working in older Android and not newer, Windows phone, but not iPhone ( just as an example).
So "postMessage" is the best way to proceed.
MATRIX_R_
thanks for the great explaination ...
the only thing is that my app is on ios :(
MATRIX_R_
and i will be thankfull if you provide us an example
did search but did not understand as well
Chris_P_Intel
I googled "postMessage iframe tutorial" and got some good results.  Try these:
http://javascript.info/tutorial/cross-window-messaging-with-postmessage
http://robertnyman.com/html5/postMessage/postMessage.html
good luck!
MATRIX_R_
good luck!
so the idea is that i send message (or for example javascript call of admob) from iframe to the main page (the index.html of cordova)
right ?
Chris_P_Intel
The sample at should be useful. http://javascript.info/tutorial/cross-window-messaging-with-postmessage
and the example in https://developer.mozilla.org/en-US/docs/Web/API/Window/postMessage is very good as well.
In the first sample, the parent window sends a message to the iframe. But you want the reverse.  It's not any harder, just make the parent window the receiver and the iframe as the sender.
In the iframe you would have something like this:
<script>
function tell_parent()
  window.parent.postMessage("hello");
</script>
and in the parent window you'll have something like this:
<script>
 function receiveMessage(event)
   alert(event.data); // --event.data will be "hello"
 window.addEventListener("message", receiveMessage, false);
</script>
MATRIX_R_
ok so let's say the javascript to call admob interstitial in the main window is show();
so i put in the main window (index.html of my cordova / intel xdk project)
1 <script>
2  function receiveMessage(event)
3 {
4    show();
5 }
6  window.addEventListener("message", receiveMessage, false);
7 </script>
and on iframe
1 <script>
2 function tell_parent()
3 {
4   window.parent.postMessage("hello");
5 }
6 </script>
right ?
Chris_P_Intel
Yes, that is correct.  And the tell_parent() function will have to be called by something in the iframe.
