Software Archive
Read-only legacy content
17060 Discussions
image gallery fatal error problem solution
Tuncay_KAYIKCI
      When added to the image gallery, you need to make changes in the CSS file so that you get the fatal error warning. galleria / galleria.classic.css .galleri-stage section height: 100% width: 100% or just add a constant value. But when you add each image gallery into index.html file that CSS style code or reset solved the problem if you write another CSS file.
Olushola_O_
Sir, this didn't solve the issue in my XDK and please lets help each other, your tutorial was not toooo clear for newbies. But thanks though awesome post !1
