Software Archive
Read-only legacy content
installation problem on Linux platform for Intel Parallel Studio XE
Saikat_S_Intel
Is there any issue with installing 'Intel Parallel Studio XE Composer Edition for C++ Linux' as non-root?
When I tried to run the install script, first it complained about unsupported OS version (which is SuSE gcc version 4.1.2 on my machine) for which I chose the 'ignore' option, but eventually installation failed with "no disk space" error. I have ~200 GB space on the partition where I am trying to install!
When I do retry installation, the user interface seems to be broken as it constantly takes me through repeated questions when I select "repair" option?
I have valid license file and product key. Any idea what the problem might be? Do I need to install as root - this is an EC supported machine, so to install as 'root' I will need their help. I am primarily interested in using MKL library, but it is bundled with the full Parallel Studio.
Thanks for any help/suggestion...
-Roy
Hubert_H_Intel
Roy,
"no disk space" may also refer to /tmp which is being used for extracting filesets and creating temporary files. If you cannot clear /tmp and create some free space you can specify an alternative temp dir for installation
install.sh --tmp-dir <tempdir>
Hubert..
Saikat_S_Intel
Thanks, Hubert.
I uninstalled the partial installation done earlier, but now when I try to reinstall (with -tmp-dir option set), the installation does not recognize the previous product serial number that I rcvd.
Is there any way to reset, or get another valid key?
-Roy
Hubert_H_Intel
Roy,
I'll provide your SN which is valid and should work via a private message. If remote activation with SN doesn't work, use alternative activation and use the license file I've sent you.
Hubert.
