Software Archive
Read-only legacy content
17060 Discussions
installing Intel cilk++
newport_j
I am installling cilk_8503-i686.release.tar.gz which I have previouslty downloaded. My OS is Ubuntu 11.04.
When I was following the prompts it said that I have an unsupported OS. I have previously installed Intel Cilk++ and there was no problem. I ignored the message and directed the installer to treat it like a Debian install. It gave the option to go on and I did.
I am at the stage where I have to give the command
source install-dir/bin/compilervars.sh ia32
I have a bash shell. I cannot find the files. The subdirectory is loaded with *.rpm files which of course I do not want.
What happened? I do not remember such a complicated install when I did this in 2010. I cannot find
the /bin/ directory that the command refers to.
I have a lot of *.rpm files which I do not need. The software did say installation was successful so I guess something went correctly. I just cannot perform the last command.
I may have to uninstall and start agin - how do I uninstall? I think it is the only thing left. Maybe, I can save the install if I can find compilervar.sh and the right /bin/ directory. I am using 32 bit Ubuntu 11.04.
This was easier in 2010.
Any help appreciated. Thanks in advance.
Newport_j
newport_j
Okay, ignore most of what I wrote above. I found the compilervars.sh file. It was in
/opt/intel/bin/
I must have installedas root. Anyway by running the command
./source install-dir/bin/compilervars.sh ia32
using sudo and not using sudo to prefix it. I got
/opt/intel/composerxe-2011/tbb/bin/tbbvars.sh: 38 [[: not found
and
/opt/intel/composerxe-2011/mkl/bin/mkvars.sh: bad substitution
How do I get rid of these errors? It seems to have a problem when I run the above command:
Thanks in advance.
Newport_j
newport_j
Alright I can answer my own question. I should use
souce install-dir/compilervars.sh ia32
It installed. Please excuse the clumsiness.
newport_j
Barry_T_Intel
As long as you found your answer it's not a problem. :o) However, in the future, please try to differentiate between "Intel Cilk Plus" and "Cilk++".
"Intel Cilk Plus" is the supported implementation of Cilk and array annotations that is contained in the Intel C/C++ compiler (Intel Composer). Support for Intel Cilk Plus is provided in this forum. An implementation of Intel Cilk Plus is also available in the "cilkplus" branch of gcc 4.7.
"Intel Cilk++" is the "WhatIf" kit version of the Cilk++ product originally from Cilk Arts. Questions about Cilk++ belong in the Intel Cilk++ forum. Cilk++ is not supported.
-- Barry
