I use intel XDK version 1826 for the development of my project in ionic/angularjs/cordova. But every 15min/20min intel XDK crash.
I ask you if anyone have an issue ?
Best regards
- Tags:
- HTML5
- Intel® XDK
There is an updated version 1912 available, can u try that?
We fixed a lot of crash issues with the 1912 release. Please try that release. You should be getting a notification to upgrade, if you are not seeing that notification, you can download 1912 from the main site at http://xdk.intel.com.
Thanks for your comment but I already started my application on 1826 and i saw the recent version dont use the same library or not in the same repertory. So if I use a recent version I need to restart all my declaration of library or not ?
I'm not sure what you mean by "does not use the same library or repertory."
Your project does not change when you update to 1912, other than some project settings stored in the <project-name>.xdk file that is in the root of your project. Your source files do not change.
Any JavaScript libraries that you reference stay the same, assuming you are storing those JS files in your project and including them as part of your build. The newer version of the XDK will recommend that you use the 4.1.2 build system, but you can set it to use 3.5 if you wish to continue to use that build. The build system is cloud-based, so it is not linked directly to the XDK, so whether you are using 1826 or 1912 (now 1995, as of yesterday) you are using the same build system.
The main difference between each version of the XDK is what versions of the plugins are considered the "default" versions (which you can override), which features are present and what bugs have been fixed in the XDK. In all cases you are building a Cordova app, where the XDK build in the cloud is using a standard Cordova CLI to perform the build.
Thanks for your answer. I had download version 1912, but it's the same issue with crash ! Every 15 / 20min intel XDK crash ! And today i have download version 1995, but when I change project and I want emulate the current project, the emulator works only for the first project opened. Any issue ? And I have just 1 crash for the moment.
Hard to works with all problems, but if you have any suggestions, tell me.
Best regards.
After 1 day works with intel XDK 1995, I have 3 crash.
Can you provide more details?
- What are you doing when the XDK crashes? Using App Designer, using the Emulate tab, etc.
- Are you submitting the crash reports? Do you get a crash report?
- What kind of system are you using? Windows, Mac, etc. If Windows, are you using Windows XP? The XDK does not run on XP.
Every time I work normally, I didnt make a special thing when XDK crash. I use a ionic framework. I use Windows 7 Entreprise SP1 64bits.
I upload all crash reports.
This is one log:
xdk:client (1431933334982): memlim: 767557632
xdk:client (1431933334984): Setting NW crash dump to: C:\Users\ccantagrel\AppData\Local\XDK
xdk:client (1431933335122): Intel XDK: 1995
xdk:client (1431933335122): Platform: win32-ia32 (6.1.7601)
xdk:client (1431933335129): Error SyntaxError: Unexpected token loading components\client\app\locale\ru\text-content.json
xdk:client (1431933335159): Error SyntaxError: Unexpected token loading components\client\profiling\locale\ru\text-content.json
xdk:client (1431933335227): Starting client process initialization
xdk:client (1431933335243): NW Cache is up-to-date.
xdk:client (1431933343803): Component "client:iosdb" finished start()
xdk:client (1431933343803): Component "client:device-discovery" calling start()
xdk:client (1431933343805): Component "client:device-discovery" finished start()
xdk:client (1431933343805): Component "client:test-local-server" calling start()
xdk:client (1431933343806): Component "client:test-local-server" finished start()
xdk:client (1431933343806): Component "client:quick-tour" calling start()
xdk:client (1431933343806): Component "client:quick-tour" finished start()
xdk:client (1431933343806): Component "client:hot-keys" calling start()
xdk:client (1431933343807): Component "client:hot-keys" finished start()
xdk:client (1431933343807): Component "client:persistance" calling start()
xdk:client (1431933343808): Component "client:persistance" finished start()
xdk:client (1431933343808): Component "client:file-watcher" calling start()
xdk:client (1431933343808): Component "client:file-watcher" finished start()
xdk:client (1431933343808): Component "client:cordova" calling start()
xdk:client (1431933343810): Component "client:cordova" finished start()
xdk:client (1431933343810): Component "client:external-editors-runner" calling start()
xdk:client (1431933343812): Component "client:external-editors-runner" finished start()
xdk:client (1431933343814): Intel XDK is initialized now
client:navbar (1431933344155): pollForUpdates called
uib-client (1431933344242): gradeHTMLFile 2 /D/GIT clone/mapmytrip/src/mmt_1/www/templates/view2.html
xdk:client (1431933344986): memmrk: 39982580 71854976
client:navbar (1431933344991): polling up-to-date
xdk:server (1431933345568): memmrk: 30363768 78943616
xdk:client (1431933349987): memmrk: 50303152 91075712
client:emulator (1431933350425): Device Emulator :: Environment Warming Up (Tea. Earl Gray. Hot.)
xdk:server (1431933350568): memmrk: 44880740 85464448
client:emulator (1431933350599): appmobi_plus_cordova :: Emulator changing to project mmt_1
client:emulator (1431933350605): appmobi_plus_cordova :: _xdkLoad for project mmt_1
client:emulator (1431933350606): appmobi_plus_cordova :: Emulator changing to project mmt_1
client:emulator (1431933351273): appmobi_plus_cordova :: Initialization Finished (Make it so.)
server:emulator-webserver (1431933351531): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystemPaths.js
server:emulator-webserver (1431933351531): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystemPaths.js
client:emulator (1431933351544): appmobi_plus_cordova :: Native back button handler was detached.
xdk:client (1431933354990): memmrk: 52063584 88581248
xdk:server (1431933355570): memmrk: 56123140 87483648
xdk:server (1431933490617): memmrk: 24208084 33853952
xdk:client (1431933495042): memmrk: 46557864 60331392
xdk:server (1431933495618): memmrk: 24214424 33853952
client:emulator (1431933498989): Device Emulator :: Environment Warming Up (Tea. Earl Gray. Hot.)
client:emulator (1431933499133): appmobi_plus_cordova :: Emulator changing to project mmt_1
client:emulator (1431933499139): appmobi_plus_cordova :: _xdkLoad for project mmt_1
client:emulator (1431933499141): appmobi_plus_cordova :: Emulator changing to project mmt_1
client:emulator (1431933499370): appmobi_plus_cordova :: Initialization Finished (Make it so.)
server:emulator-webserver (1431933499373): emulator-webserver: got a request for userapp.
server:emulator-webserver (1431933499373): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/index.html
server:emulator-webserver (1431933499373): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-...
server:emulator-webserver (1431933508994): req.path = /http-services/emulator-webserver/ripple/userapp/C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map
server:emulator-webserver (1431933508995): Other file request, fullPath = C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map
server:emulator-webserver (1431933508999): Error testing path C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map; msg = ERROR: name must either start with slash or use base option
Error
at ComponentError (D:\xdk\core-modules\public\component-error.js:17:1122)
at new ServiceError (D:\xdk\core-modules\public\service-error.js:17:317)
at _ensureStartsWithSlashOrUsesBaseOption (D:\xdk\components\server\userfs\filter\sanitize.js:17:800)
at D:\xdk\components\server\userfs\filter\sanitize.js:17:1227
at Array.forEach (native)
at Function._.each._.forEach (D:\xdk\node_modules\underscore\underscore.js:79:11)
at D:\xdk\components\server\userfs\filter\sanitize.js:17:1120
at beforeFilter (D:\xdk\components\server\userfs\filter\sanitize.js:17:1082)
xdk:client (1431933510045): memmrk: 53552912 79074176
xdk:server (1431933510621): memmrk: 28186312 36954624
xdk:client (1431933515058): memmrk: 54059456 79074176
xdk:server (1431933515633): memmrk: 25558992 36954624
server:emulator-webserver (1431933519538): emulator-webserver: got a request for userapp.
server:emulator-webserver (1431933519538): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view2.html
server:emulator-webserver (1431933519538): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view2.html
server:emulator-webserver (1431933519542): HTML file doesn't look like entire document; skipping injection
xdk:client (1431933520058): memmrk: 55802088 80077696
xdk:server (1431933520633): memmrk: 25329920 33808896
xdk:client (1431933525058): memmrk: 56164272 80077696
xdk:server (1431933525634): memmrk: 25345456 33808896
server:emulator-webserver (1431933525858): emulator-webserver: got a request for userapp.
server:emulator-webserver (1431933525858): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view3.html
server:emulator-webserver (1431933525858): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view3.html
server:emulator-webserver (1431933525872): HTML file doesn't look like entire document; skipping injection
xdk:client (1431933530060): memmrk: 56978560 80077696
xdk:server (1431934515890): memmrk: 25815776 33853952
xdk:client (1431934520483): memmrk: 62314512 87138816
xdk:server (1431934520890): memmrk: 25822016 33853952
client:emulator (1431934524490): [emulator] file change restarted emulator /D/GIT clone/mapmytrip/src/mmt_4/www/js/app.js
client:emulator (1431934524497): appmobi_plus_cordova :: Emulator restarting mmt_1
client:emulator (1431934524513): appmobi_plus_cordova :: _xdkLoad for project mmt_1....erapp.
server:emulator-webserver (1431934526473): req.path = /http-services/emulator-webserver/ripple/userapp/C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map
server:emulator-webserver (1431934526474): Other file request, fullPath = C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map
server:emulator-webserver (1431934526476): Error testing path C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map; msg = ERROR: name must either start with slash or use base option
Error
xdk:server (1431934530891): memmrk: 27833768 42164608
xdk:client (1431934531457): memmrk: 67719716 89182336
xdk:client (1431935741915): memmrk: 58676876 71533184
Node Webkit Error log:
[9004:0518/091535:INFO:CONSOLE(17)] ""xdk:client (1431933335129): Error SyntaxError: Unexpected token \uFEFF loading components\\client\\app\\locale\\ru\\text-content.json"", source: D:\xdk\core-modules\private\logger.js (17)
[9004:0518/091535:INFO:CONSOLE(17)] ""xdk:client (1431933335159): Error SyntaxError: Unexpected token \uFEFF loading components\\client\\profiling\\locale\\ru\\text-content.json"", source: D:\xdk\core-modules\private\logger.js (17)
[9004:0518/091535:INFO:CONSOLE(989)] "" Unhandled rejection reasons (should be empty):" ["(no stack) [object Object]"]", source: file:///D:/xdk/node_modules/q/q.js (989)
[9004:0518/091543:INFO:CONSOLE(224)] ""NW proxy string: DIRECT"", source: /brackets.js (224)
[9004:0518/091543:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n at new jQuery.fn.init (/brackets.js:455:36)\n at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/camden.jshint/main.js:174:9\n at _callHandler (/utils/AppInit.js:94:13)\n at Object._dispatchReady (/utils/AppInit.js:114:13)\n at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[9004:0518/091543:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n at new jQuery.fn.init (/brackets.js:455:36)\n at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/camden.jshint/main.js:183:9\n at _callHandler (/utils/AppInit.js:94:13)\n at Object._dispatchReady (/utils/AppInit.js:114:13)\n at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[9004:0518/091543:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n at new jQuery.fn.init (/brackets.js:455:36)\n at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/intelxdk.xlint/main.js:366:9\n at _callHandler (/utils/AppInit.js:94:13)\n at Object._dispatchReady (/utils/AppInit.js:114:13)\n at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[9004:0518/091543:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n at new jQuery.fn.init (/brackets.js:455:36)\n at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/intelxdk.xlint/main.js:375:9\n at _callHandler (/utils/AppInit.js:94:13)\n at Object._dispatchReady (/utils/AppInit.js:114:13)\n at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[9004:0518/091544:INFO:CONSOLE(989)] "" Unhandled rejection reasons (should be empty):" ["(no stack) ERROR: no user is logged in\nError\n at new ComponentError (D:\\xdk\\core-modules\\public\\component-error.js:17:1122)\n at makeError (file:///D:/xdk/components/client/backend-service-utils/backend-service-utils.js:17:187)\n at file:///D:/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1258\n at _fulfilled (D:\\xdk\\node_modules\\q\\q.js:797:54)\n at self.promiseDispatch.done (D:\\xdk\\node_modules\\q\\q.js:826:30)\n at Promise.promise.promiseDispatch (D:\\xdk\\node_modules\\q\\q.js:759:13)\n at D:\\xdk\\node_modules\\q\\q.js:573:44\n at flush (D:\\xdk\\node_modules\\q\\q.js:108:17)\n at process._tickCallback (node.js:393:11)"]", source: D:\xdk\node_modules\q\q.js (989)
[9004:0518/091551:INFO:CONSOLE(23)] ""ROUTE"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (23)
[9004:0518/091551:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[9004:0518/091551:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[9004:0518/091551:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[9004:0518/091551:INFO:CONSOLE(8)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (8)
[9004:0518/091551:INFO:CONSOLE(10)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (10)
[9004:0518/091819:INFO:CONSOLE(23)] ""ROUTE"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (23)
[9004:0518/091819:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[9004:0518/091819:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[9004:0518/091819:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[9004:0518/091819:INFO:CONSOLE(8)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (8)
[9004:0518/091819:INFO:CONSOLE(10)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (10)
[9004:0518/091829:INFO:CONSOLE(989)] "" Unhandled rejection reasons (should be empty):" ["(no stack) ERROR: name must either start with slash or use base option\nError\n at ComponentError (D:\\xdk\\core-modules\\public\\component-error.js:17:1122)\n at new ServiceError (D:\\xdk\\core-modules\\public\\service-error.js:17:317)\n at _ensureStartsWithSlashOrUsesBaseOption (D:\\xdk\\components\\server\\userfs\\filter\\sanitize.js:17:800)\n at D:\\xdk\\components\\server\\userfs\\filter\\sanitize.js:17:1227\n at Array.forEach (native)\n at Function._.each._.forEach (D:\\xdk\\node_modules\\underscore\\underscore.js:79:11)\n at D:\\xdk\\components\\server\\userfs\\filter\\sanitize.js:17:1120\n at Array.forEach (native)\n at Function._.each._.forEach (D:\\xdk\\node_modules\\underscore\\underscore.js:79:11)\n at beforeFilter (D:\\xdk\\components\\server\\userfs\\filter\\sanitize.js:17:1082)"]", source: D:\xdk\node_modules\q\q.js (989)
[9004:0518/091839:INFO:CONSOLE(8)] ""Second service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service2.js (8)
[9004:0518/091839:INFO:CONSOLE(10)] ""Second controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller2.js (10)
[9004:0518/091845:INFO:CONSOLE(8)] ""Third service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (8)
[9004:0518/091845:INFO:CONSOLE(10)] ""Third controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller3.js (10)
[9004:0518/091845:INFO:CONSOLE(11)] ""service 3 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (11)
[9004:0518/093524:INFO:CONSOLE(24)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (24)
[9004:0518/093524:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[9004:0518/093524:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[9004:0518/093524:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[9004:0518/093524:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[9004:0518/093525:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[9004:0518/093525:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
XDK exit code & signal: 3221225477, null
Crash minidump not found in XDK data folder. Falling back to TEMP...
Crash Minidump File: C:\Users\ccantagrel\AppData\Local\Temp\7b06a7aa-b3d4-48b0-9ee9-52f855bdfe02.dmp Mon May 18 2015 09:55:44 GMT+0200 (Romance Daylight Time)
Size in bytes: 501536
NW Crash Detected.
Best regards
Or another:
xdk:client (1431937128078): memlim: 767557632
xdk:client (1431937128080): Setting NW crash dump to: C:\Users\ccantagrel\AppData\Local\XDK
xdk:client (1431937128226): Intel XDK: 1995
....l" calling init()
xdk:client (1431937130873): Component "client:resource-util" finished initialization
xdk:client (1431937130876): Component "client:backend-services" calling init()
client:backend-services (1431937130876): Base url https://appcenter.html5tools-software.intel.com/, edition xdk
client:backend-services (1431937130877): Account paths: {
"login": "Account/xdklogin.aspx",
"logout": "csd/logout.aspx",
"register": "csd/Cloud-Services-Dashboard-Sign-Up.aspx",
"update": "csd/Account-Change.aspx",
"details": "csd/Account.aspx"
client:backend-services (1431937130877): Account urls: {
"login": "https://appcenter.html5tools-software.intel.com/Account/xdklogin.aspx?xdk=true&xdkvariant=xdk&xdkversion=release-2015-ww19",
"logout": "https://appcenter.html5tools-software.intel.com/csd/logout.aspx?xdk=true&xdkvariant=xdk&xdkversion=release-2015-ww19",
"register": "https://appcenter.html5tools-software.intel.com/csd/Cloud-Services-Dashboard-Sign-Up.aspx?xdk=true&xdkvariant=xdk&xdkversion=release-2015-ww19",
"update": "https://appcenter.html5tools-software.intel.com/csd/Account-Change.aspx?xdk=true&xdkvariant=xdk&xdkversion=release-2015-ww19",
"details": "https://appcenter.html5tools-software.intel.com/csd/Account.aspx?xdk=true&xdkvariant=xdk&xdkversion=release-2015-ww19"
client:backend-services (1431937130877): Service urls: {
"issue": "https://appcenter.html5tools-software.intel.com/xdkissue",
"certificate": "https://appcenter.html5tools-software.intel.com/xdk2/v2/api.asmx/gencert",
"projectRenderers": "https://appcenter.html5tools-software.intel.com/api/v2.0/redirect/projectrenderers/",
"updates": "https://appcenter.html5tools-software.intel.com/api/v2.0/redirect/updates/xdk/",
"curatedServices": "https://appcenter.html5tools-software.intel.com/api/v2.0/redirect/appservices/"
xdk:client (1431937130877): Component "client:backend-services" finished initialization
xdk:client (1431937130877): Component "client:backend-services-ext" calling init()
xdk:server (1431937148679): memmrk: 23364388 61677056
uib-client (1431937149850): gradeHTMLFile 1 /D/GIT clone/mapmytrip/src/mmt_4/www/index.html
uib-client (1431937151752): gradeHTMLFile 1 /D/GIT clone/mapmytrip/src/mmt_4/www/index.html
xdk:client (1431937153101): memmrk: 55670836 83478400
xdk:server (1431937153679): memmrk: 24077812 61677056
client:emulator (1431937156756): Device Emulator :: Environment Warming Up (Tea. Earl Gray. Hot.)
client:emulator (1431937156936): appmobi_plus_cordova :: Emulator changing to project mmt_1
client:emulator (1431937156941): appmobi_plus_cordova :: _xdkLoad for project mmt_1
server:emulator-webserver (1431943183005): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view_layout.html
server:emulator-webserver (1431943183013): HTML file doesn't look like entire document; skipping injection
xdk:server (1431943184376): memmrk: 29748716 41148928
xdk:server (1431943279368): memmrk: 24689444 32838272
xdk:client (1431943279686): memmrk: 83217032 112506496
client:emulator (1431943284015): [emulator] file change restarted emulator /D/GIT clone/mapmytrip/src/mmt_4/www/js/controllers/controller_layout.js
client:emulator (1431943284017): appmobi_plus_cordova :: Emulator restarting mmt_1
server:emulator-webserver (1431943288342): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view_login.html
server:emulator-webserver (1431943288342): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view_login.html
server:emulator-webserver (1431943288345): HTML file doesn't look like entire document; skipping injection
server:emulator-webserver (1431943289248): emulator-webserver: got a request for userapp.
server:emulator-webserver (1431943289248): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view_layout.html
server:emulator-webserver (1431943289249): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view_layout.html
server:emulator-webserver (1431943289253): HTML file doesn't look like entire document; skipping injection
xdk:server (1431943289369): memmrk: 28165868 36954624
xdk:client (1431943289688): memmrk: 84234676 113522176
xdk:server (1431943294370): memmrk: 28172228 36954624
xdk:server (1431943894392): memmrk: 25380748 32838272
xdk:client (1431943894903): memmrk: 93823144 119604096
client:emulator (1431943898282): Device Emulator :: Environment Warming Up (Tea. Earl Gray. Hot.)
client:emulator (1431943898453): appmobi_plus_cordova :: Emulator changing to project mmt_1
client:emulator (1431943898458): appmobi_plus_cordova :: _xdkLoad for project mmt_1
client:emulator (1431943898614): appmobi_plus_cordova :: Initialization Finished (Make it so.)
server:emulator-webserver (1431943898616): emulator-webserver: got a request for userapp.
server:emulator-webserver (1431943932954): emulator-webserver: got a request for userapp.
server:emulator-webserver (1431943932954): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view_layout.html
server:emulator-webserver (1431943932954): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view_layout.html
server:emulator-webserver (1431943932969): HTML file doesn't look like entire document; skipping injection
xdk:server (1431943934394): memmrk: 26418608 37958144
xdk:client (1431943934913): memmrk: 87405968 121659776
xdk:client (1431944029958): memmrk: 99644488 122675456
xdk:server (1431944034400): memmrk: 25278824 34935424
[6376:0518/101848:INFO:CONSOLE(17)] ""xdk:client (1431937128234): Error SyntaxError: Unexpected token \uFEFF loading components\\client\\app\\locale\\ru\\text-content.json"", source: D:\xdk\core-modules\private\logger.js (17)
[6376:0518/101848:INFO:CONSOLE(17)] ""xdk:client (1431937128265): Error SyntaxError: Unexpected token \uFEFF loading components\\client\\profiling\\locale\\ru\\text-content.json"", source: D:\xdk\core-modules\private\logger.js (17)
[6376:0518/101848:INFO:CONSOLE(989)] "" Unhandled rejection reasons (should be empty):" ["(no stack) [object Object]"]", source: file:///D:/xdk/node_modules/q/q.js (989)
[6376:0518/101854:INFO:CONSOLE(224)] ""NW proxy string: DIRECT"", source: /brackets.js (224)
[6376:0518/101854:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n at new jQuery.fn.init (/brackets.js:455:36)\n at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/camden.jshint/main.js:174:9\n at _callHandler (/utils/AppInit.js:94:13)\n at Object._dispatchReady (/utils/AppInit.js:114:13)\n at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[6376:0518/101854:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n at new jQuery.fn.init (/brackets.js:455:36)\n at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/camden.jshint/main.js:183:9\n at _callHandler (/utils/AppInit.js:94:13)\n at Object._dispatchReady (/utils/AppInit.js:114:13)\n at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[6376:0518/101854:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n at new jQuery.fn.init (/brackets.js:455:36)\n at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/intelxdk.xlint/main.js:366:9\n at _callHandler (/utils/AppInit.js:94:13)\n at Object._dispatchReady (/utils/AppInit.js:114:13)\n at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[6376:0518/101854:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n at new jQuery.fn.init (/brackets.js:455:36)\n at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/intelxdk.xlint/main.js:375:9\n at _callHandler (/utils/AppInit.js:94:13)\n at Object._dispatchReady (/utils/AppInit.js:114:13)\n at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[6376:0518/101854:INFO:CONSOLE(989)] "" Unhandled rejection reasons (should be empty):" ["(no stack) ERROR: no user is logged in\nError\n at new ComponentError (D:\\xdk\\core-modules\\public\\component-error.js:17:1122)\n at makeError (file:///D:/xdk/components/client/backend-service-utils/backend-service-utils.js:17:187)\n at file:///D:/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1258\n at _fulfilled (D:\\xdk\\node_modules\\q\\q.js:797:54)\n at self.promiseDispatch.done (D:\\xdk\\node_modules\\q\\q.js:826:30)\n at Promise.promise.promiseDispatch (D:\\xdk\\node_modules\\q\\q.js:759:13)\n at D:\\xdk\\node_modules\\q\\q.js:573:44\n at flush (D:\\xdk\\node_modules\\q\\q.js:108:17)\n at process._tickCallback (node.js:393:11)"]", source: D:\xdk\node_modules\q\q.js (989)
[6376:0518/101917:INFO:CONSOLE(3)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (3)
[6376:0518/101917:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/101917:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/101917:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/101917:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/101917:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/101917:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/101923:INFO:CONSOLE(8)] ""Second service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service2.js (8)
[6376:0518/101923:INFO:CONSOLE(10)] ""Second controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller2.js (10)
[6376:0518/101924:INFO:CONSOLE(8)] ""Third service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (8)
[6376:0518/101924:INFO:CONSOLE(10)] ""Third controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller3.js (10)
[6376:0518/101924:INFO:CONSOLE(11)] ""service 3 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (11)
[6376:0518/101925:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/101925:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/101926:INFO:CONSOLE(10)] ""Second controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller2.js (10)
[6376:0518/101927:INFO:CONSOLE(10)] ""Third controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller3.js (10)
[6376:0518/101927:INFO:CONSOLE(11)] ""service 3 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (11)
[6376:0518/102000:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/102000:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/102000:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/102000:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/102000:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/102000:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/102000:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/102005:INFO:CONSOLE(8)] ""Second service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service2.js (8)
[6376:0518/102005:INFO:CONSOLE(10)] ""Second controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller2.js (10)
[6376:0518/102006:INFO:CONSOLE(8)] ""Third service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (8)
[6376:0518/102006:INFO:CONSOLE(10)] ""Third controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller3.js (10)
[6376:0518/102006:INFO:CONSOLE(11)] ""service 3 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (11)
[6376:0518/102008:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/102008:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/103223:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/103223:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/103224:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/103224:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/103224:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/103224:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/103224:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/103357:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/103357:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/103357:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/103357:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/103357:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/103357:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/103357:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/110022:ERROR:dns_config_service_win.cc(739)] DNS config watch failed.
[6376:0518/112310:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/112310:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/112310:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/112310:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/112310:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/112310:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/112310:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/112314:INFO:CONSOLE(8)] ""Second service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service2.js (8)
[6376:0518/112314:INFO:CONSOLE(10)] ""Second controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller2.js (10)
[6376:0518/112316:INFO:CONSOLE(8)] ""Third service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (8)
[6376:0518/112316:INFO:CONSOLE(10)] ""Third controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller3.js (10)
[6376:0518/112316:INFO:CONSOLE(11)] ""service 3 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (11)
[6376:0518/112317:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/112317:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/113305:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/113305:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/113305:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/113305:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/113305:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/113305:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/113305:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/113316:INFO:CONSOLE(114)] ""Error: [ng:areq] http://errors.angularjs.org/1.2.12/ng/areq?p0=SecondCtrl&p1=not%20a%20function%2C%20got%20undefined\n ; at Error (native)\n at http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:35:450\n ; at tb (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:47:360)\n at Pa (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:47:447)\n at http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:91:17\n ; at d (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:321:17502)\n at b (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:321:17903)\n at h.$broadcast (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:134:155)\n at t.transition.N.then.t.transition.t.transition (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:298:10007)\n at A (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:122:5)"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js (114)
[6376:0518/113317:INFO:CONSOLE(8)] ""Third service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (8)
[6376:0518/113317:INFO:CONSOLE(10)] ""Third controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller3.js (10)
[6376:0518/113317:INFO:CONSOLE(11)] ""service 3 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (11)
[6376:0518/113318:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/113318:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/113318:INFO:CONSOLE(114)] ""Error: [ng:areq] http://errors.angularjs.org/1.2.12/ng/areq?p0=SecondCtrl&p1=not%20a%20function%2C%20got%20undefined\n ; at Error (native)\n at http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:35:450\n ; at tb (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:47:360)\n at Pa (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:47:447)\n at http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:91:17\n ; at d (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:321:17502)\n at b (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:321:17903)\n at h.$broadcast (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:134:155)\n at t.transition.N.then.t.transition.t.transition (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:298:10007)\n at A (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:122:5)"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js (114)
[6376:0518/113409:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/113409:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/113409:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/113409:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/113409:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/113409:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/113409:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/113414:INFO:CONSOLE(8)] ""Login service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_login.js (8)
[6376:0518/113414:INFO:CONSOLE(10)] ""Login controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_login.js (10)
[6376:0518/113416:INFO:CONSOLE(8)] ""Third service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (8)
[6376:0518/113416:INFO:CONSOLE(10)] ""Third controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller3.js (10)
[6376:0518/113416:INFO:CONSOLE(11)] ""service 3 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (11)
[6376:0518/113417:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/113417:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/114552:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/114552:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/114552:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/114552:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/114552:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/114552:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/114552:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/114736:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/114736:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/114736:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/114736:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/114736:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/114736:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/114736:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/114742:INFO:CONSOLE(8)] ""Login service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_login.js (8)
[6376:0518/114742:INFO:CONSOLE(10)] ""Login controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_login.js (10)
[6376:0518/114743:INFO:CONSOLE(8)] ""Third service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (8)
[6376:0518/114743:INFO:CONSOLE(10)] ""Third controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller3.js (10)
[6376:0518/114743:INFO:CONSOLE(11)] ""service 3 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (11)
[6376:0518/114744:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/114744:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/114745:INFO:CONSOLE(10)] ""Login controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_login.js (10)
[6376:0518/114746:INFO:CONSOLE(10)] ""Third controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller3.js (10)
[6376:0518/114746:INFO:CONSOLE(11)] ""service 3 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (11)
[6376:0518/114747:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/114747:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/115546:INFO:CONSOLE(59)] "Uncaught Error: [$injector:modulerr] http://errors.angularjs.org/1.2.12/$injector/modulerr?p0=mmt&p1=Error%3A%20%5B%24injector%3Amodulerr%5D%20http%3A%2F%2Ferrors.angularjs.org%2F1.2.12%2F%24injector%2Fmodulerr%3Fp0%3Dmmt.controller3%26p1%3DError%253A%2520%255B%2524injector%253Anomod%255D%2520http%253A%252F%252Ferrors.angularjs.org%252F1.2.12%252F%2524injector%252Fnomod%253Fp0%253Dmmt.controller3%250A%2520%2520%2520%2520at%2520Error%2520(native)%250A%2520%2520%2520%2520at%2520http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A35%253A450%250A%2520%2520%2520%2520at%2520http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A49%253A260%250A%2520%2520%2520%2520at%2520http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A50%253A262%250A%2520%2520%2520%2520at%2520http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A58%253A175%250A%2520%2520%2520%2520at%2520Array.forEach%2520(native)%250A%2520%2520%2520%2520at%2520q%2520(http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A36%253A280)%250A%2520%2520%2520%2520at%2520e%2520(http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A58%253A115)%250A%2520%2520%2520%2520at%2520http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A58%253A192%250A%2520%2520%2520%2520at%2520Array.forEach%2520(native)%0A%20%20%20%20at%20Error%20(native)%0A%20%20%20%20at%20http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A35%3A450%0A%20%20%20%20at%20http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A59%3A1%0A%20%20%20%20at%20Array.forEach%20(native)%0A%20%20%20%20at%20q%20(http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A36%3A280)%0A%20%20%20%20at%20e%20(http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A58%3A115)%0A%20%20%20%20at%20http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A58%3A192%0A%20%20%20%20at%20Array.forEach%20(native)%0A%20%20%20%20at%20q%20(http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A36%3A280)%0A%20%20%20%20at%20e%20(http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A58%3A115)", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js (59)
[6376:0518/115907:INFO:CONSOLE(59)] "Uncaught Error: [$injector:modulerr] http://errors.angularjs.org/1.2.12/$injector/modulerr?p0=mmt&p1=Error%3A%20%5B%24injector%3Amodulerr%5D%20http%3A%2F%2Ferrors.angularjs.org%2F1.2.12%2F%24injector%2Fmodulerr%3Fp0%3Dmmt.controller_layout%26p1%3DError%253A%2520%255B%2524injector%253Amodulerr%255D%2520http%253A%252F%252Ferrors.angularjs.org%252F1.2.12%252F%2524injector%252Fmodulerr%253Fp0%253Dmmt.service_layout%2526p1%253DError%25253A%252520%25255B%252524injector%25253Anomod%25255D%252520http%25253A%25252F%25252Ferrors.angularjs.org%25252F1.2.12%25252F%252524injector%25252Fnomod%25253Fp0%25253Dmmt.service_layout%25250A%252520%252520%252520%252520at%252520Error%252520(native)%25250A%252520%252520%252520%252520at%252520http%25253A%25252F%25252F127.0.0.1%25253A58889%25252Fhttp-services%25252Femulator-webserver%25252Fripple%25252Fuserapp%25252F%25252FC%25252FUsers%25252Fccantagrel%25252FAppData%25252FLocal%25252FXDK%25252Fxdk-scratchdir%25252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%25252Fplatforms%25252Fios%25252Fwww%25252Flib%25252Fionicframework%25252Fionic.bundle.min.js%25253A35%25253A450%25250A%252520%252520%252520%252520at%252520http%25253A%25252F%25252F127.0.0.1%25253A58889%25252Fhttp-services%25252Femulator-webserver%25252Fripple%25252Fuserapp%25252F%25252FC%25252FUsers%25252Fccantagrel%25252FAppData%25252FLocal%25252FXDK%25252Fxdk-scratchdir%25252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%25252Fplatforms%25252Fios%25252Fwww%25252Flib%25252Fionicframework%25252Fionic.bundle.min.js%25253A49%25253A260%25250A%252520%252520%252520%252520at%252520http%25253A%25252F%25252F127.0.0.1%25253A58889%25252Fhttp-services%25252Femulator-webserver%25252Fripple%25252Fuserapp%25252F%25252FC%25252FUsers%25252Fccantagrel%25252FAppData%25252FLocal%25252FXDK%25252Fxdk-scratchdir%25252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%25252Fplatforms%25252Fios%25252Fwww%25252Flib%25252Fionicframework%25252Fionic.bundle.min.js%25253A50%25253A262%25250A%252520%252520%252520%252520at%252520http%25253A%25252F%25252F127.0.0.1%25253A58889%25252Fhttp-services%25252Femulator-webserver%25252Fripple%25252Fuserapp%25252F%25252FC%25252FUsers%25252Fccantagrel%25252FAppData%25252FLocal%25252FXDK%25252Fxdk-scratchdir%25252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%25252Fplatforms%25252Fios%25252Fwww%25252Flib%25252Fionicframework%25252Fionic.bundle.min.js%25253A58%25253A175%25250A%252520%252520%252520%252520at%252520Array.forEach%252520(native)%25250A%252520%252520%252520%252520at%252520q%252520(http%25253A%25252F%25252F127.0.0.1%25253A58889%25252Fhttp-services%25252Femulator-webserver%25252Fripple%25252Fuserapp%25252F%25252FC%25252FUsers%25252Fccantagrel%25252FAppData%25252FLocal%25252FXDK%25252Fxdk-scratchdir%25252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%25252Fplatforms%25252Fios%25252Fwww%25252Flib%25252Fionicframework%25252Fionic.bundle.min.js%25253A36%25253A280)%25250A%252520%252520%252520%252520at%252520e%252520(http%25253A%25252F%25252F127.0.0.1%25253A58889%25252Fhttp-services%25252Femulator-webserver%25252Fripple%25252Fuserapp%25252F%25252FC%25252FUsers%25252Fccantagrel%25252FAppData%25252FLocal%25252FXDK%25252Fxdk-scratchdir%25252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%25252Fplatforms%25252Fios%25252Fwww%25252Flib%25252Fionicframework%25252Fionic.bundle.min.js%25253A58%25253A115)%25250A%252520%252520%252520%252520at%252520http%25253A%25252F%25252F127.0.0.1%25253A58889%25252Fhttp-services%25252Femulator-webserver%25252Fripple%25252Fuserapp%25252F%25252FC%25252FUsers%25252Fccantagrel%25252FAppData%25252FLocal%25252FXDK%25252Fxdk-scratchdir%25252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%25252Fplatforms%25252Fios%25252Fwww%25252Flib%25252Fionicframework%25252Fionic.bundle.min.js%25253A58%25253A192%25250A%252520%252520%252520%252520at%252520Array.forEach%252520(native)%250A%2520%2520%2520%2520at%2520Error%2520(native)%250A%2520%2520%2520%2520at%2520http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A35%253A450%250A%2520%2520%2520%2520at%2520http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A59%253A1%250A%2520%2520%2520%2520at%2520Array.forEach%2520(native)%250A%2520%2520%2520%2520at%2520q%2520(http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A36%253A280)%250A%2520%2520%2520%2520at%2520e%2520(http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A58%253A115)%250A%2520%2520%2520%2520at%2520http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A58%253A192%250A%2520%2520%2520%2520at%2520Array.forEach%2520(native)%250A%2520%2520%2520%2520at%2520q%2520(http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A36%253A280)%250A%2520%2520%2520%2520at%2520e%2520(http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A58%253A115)%0A%20%20%20%20at%20Error%20(native)%0A%20%20%20%20at%20http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A35%3A450%0A%20%20%20%20at%20http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A59%3A1%0A%20%20%20%20at%20Array.forEach%20(native)%0A%20%20%20%20at%20q%20(http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A36%3A280)%0A%20%20%20%20at%20e%20(http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A58%3A115)%0A%20%20%20%20at%20http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A58%3A192%0A%20%20%20%20at%20Array.forEach%20(native)%0A%20%20%20%20at%20q%20(http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A36%3A280)%0A%20%20%20%20at%20e%20(http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A58%3A115)", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js (59)
[6376:0518/115937:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/115937:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/115937:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/115937:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/115937:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/115937:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/115937:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/115942:INFO:CONSOLE(8)] ""Login service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_login.js (8)
[6376:0518/115942:INFO:CONSOLE(10)] ""Login controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_login.js (10)
[6376:0518/115943:INFO:CONSOLE(114)] ""Error: [$injector:unpr] http://errors.angularjs.org/1.2.12/$injector/unpr?p0=ThirdServiceProvider%20%3C-%20ThirdService\n ; at Error (native)\n at http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:35:450\n ; at http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:61:125\n ; at Object.c [as get] (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:59:200)\n at http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:61:193\n ; at c (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:59:200)\n at d (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:59:417)\n at Object.instantiate (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:60:80)\n at http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:91:33\n ; at d (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:321:17502)"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js (114)
[6376:0518/120124:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/120124:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/120124:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/120124:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/120124:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/120124:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/120124:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/120128:INFO:CONSOLE(8)] ""Login service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_login.js (8)
[6376:0518/120128:INFO:CONSOLE(10)] ""Login controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_login.js (10)
[6376:0518/120129:INFO:CONSOLE(8)] ""Layout service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_layout.js (8)
[6376:0518/120129:INFO:CONSOLE(10)] ""Layout controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_layout.js (10)
[6376:0518/120129:INFO:CONSOLE(11)] ""service layout called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_layout.js (11)
[6376:0518/120130:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/120130:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/121138:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/121138:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/121138:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/121138:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/121138:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/121138:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/121138:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/121153:INFO:CONSOLE(8)] ""Login service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_login.js (8)
[6376:0518/121153:INFO:CONSOLE(10)] ""Login controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_login.js (10)
[6376:0518/121154:INFO:CONSOLE(8)] ""Layout service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_layout.js (8)
[6376:0518/121154:INFO:CONSOLE(10)] ""Layout controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_layout.js (10)
[6376:0518/121154:INFO:CONSOLE(11)] ""service layout called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_layout.js (11)
[6376:0518/121156:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/121156:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/121157:INFO:CONSOLE(10)] ""Login controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_login.js (10)
[6376:0518/121158:INFO:CONSOLE(10)] ""Layout controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_layout.js (10)
[6376:0518/121158:INFO:CONSOLE(11)] ""service layout called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_layout.js (11)
[6376:0518/121204:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/121204:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/121204:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/121204:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/121204:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/121205:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/121205:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/121211:INFO:CONSOLE(8)] ""Login service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_login.js (8)
[6376:0518/121211:INFO:CONSOLE(10)] ""Login controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_login.js (10)
[6376:0518/121212:INFO:CONSOLE(8)] ""Layout service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_layout.js (8)
[6376:0518/121212:INFO:CONSOLE(10)] ""Layout controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_layout.js (10)
[6376:0518/121212:INFO:CONSOLE(11)] ""service layout called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_layout.js (11)
[6376:0518/121214:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/121214:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/121216:INFO:CONSOLE(10)] ""Login controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_login.js (10)
XDK exit code & signal: 3221225477, null
Crash minidump not found in XDK data folder. Falling back to TEMP...
Crash Minidump File: C:\Users\ccantagrel\AppData\Local\Temp\2215c8ed-f84e-4d1e-852b-f36fde874fb0.dmp Mon May 18 2015 12:13:54 GMT+0200 (Romance Daylight Time)
Size in bytes: 520465
NW Crash Detected.
another one :
xdk:client (1432047263674): memlim: 767557632
xdk:client (1432047263679): Setting NW crash dump to: C:\Users\ccantagrel\AppData\Local\XDK
xdk:client (1432047263843): Intel XDK: 1995
xdk:client (1432047263843): Platform: win32-ia32 (6.1.7601)
xdk:client (1432047263851): Error SyntaxError: Unexpected token loading components\client\app\locale\ru\text-content.json
xdk:client (1432047263883): Error SyntaxError: Unexpected token loading components\client\profiling\locale\ru\text-content.json
xdk:client (1432047263959): Starting client process initialization
xdk:client (1432047263979): NW Cache is up-to-date.
xdk:server (1432047264314): memlim: 767557632
xdk:server (1432047264316): Setting NW crash dump to: C:\Users\ccantagrel\AppData\Local\XDK
xdk:server (1432047264463): Starting server process initialization
xdk:server (1432047264540): Http server started on the standard port 58889
xdk:server (1432047265600): Component "core:assert" starting import
xdk:server (1432047265601): Component "core:assert" finished initialization
xdk:server (1432047265601): Component "core:component-error" starting import
xdk:server (1432047265601): Component "core:component-error" finished initialization
xdk:server (1432047265601): Component "core:command-line-options" starting import
xdk:server (1432047265602): Component "core:command-line-options" finished initialization
xdk:server (1432047265602): Component "core:service-error" starting import
xdk:server (1432047265602): Component "core:service-error" finished initialization
xdk:server (1432047265602): Component "core:buffer" starting import
xdk:server (1432047265607): Component "core:buffer" finished initialization
xdk:server (1432047265607): Component "core:signaler" starting import
xdk:server (1432047265610): Component "core:signaler" finished initialization
xdk:server (1432047265610): Component "core:signaler-group" starting import
xdk:server (1432047265613): Component "core:signaler-group" finished initialization
xdk:server (1432047265613): Component "core:logger" starting import
xdk:server (1432047265614): Component "core:logger" finished initialization
xdk:server (1432047265614): Component "core:http-request" starting import
xdk:server (1432047265617): Component "core:http-request" finished initialization
xdk:server (1432047265617): Component "core:database" starting import
xdk:server (1432047265619): Component "core:database" finished initialization
xdk:server (1432047265619): Component "core:version" starting import
xdk:server (1432047265619): Component "core:version" finished initialization
xdk:server (1432047265619): Component "core:userfs-name-converter" starting import
xdk:server (1432047265620): Component "core:userfs-name-converter" finished initialization
xdk:server (1432047265620): Component "core:crash-handler" starting import
xdk:server (1432047265621): Component "core:crash-handler" finished initialization
xdk:server (1432047265621): Component "core:i18n-support" starting import
xdk:server (1432047265621): Component "core:i18n-support" finished initialization
xdk:server (1432047265621): Component "core:theme" starting import
xdk:server (1432047265664): Component "core:theme" finished initialization
xdk:server (1432047265666): Component "server:userfs" starting import
xdk:server (1432047265670): Component "server:userfs" calling init()
xdk:server (1432047265698): Component "server:userfs" finished initialization
xdk:server (1432047265698): Component "server:user-profile" starting import
xdk:server (1432047265700): Component "server:user-profile" calling init()
xdk:server (1432047265701): Component "server:user-profile" finished initialization
xdk:server (1432047265701): Component "server:ui-builder" starting import
xdk:server (1432047265750): Component "server:ui-builder" calling init()
xdk:server (1432047265752): Component "server:ui-builder" finished initialization
xdk:server (1432047265752): Component "server:emulator-notification" starting import
xdk:server (1432047265755): Component "server:emulator-notification" calling init()
xdk:server (1432047265755): Component "server:emulator-notification" finished initialization
xdk:server (1432047265755): Component "server:emulator-webserver" starting import
xdk:server (1432047265756): Component "server:emulator-webserver" calling init()
xdk:server (1432047265757): Component "server:emulator-webserver" finished initialization
xdk:server (1432047265757): Component "server:new-project-creator" starting import
xdk:server (1432047265760): Component "server:new-project-creator" calling init()
xdk:server (1432047265760): Component "server:new-project-creator" finished initialization
xdk:server (1432047265760): Component "server:zip-util" starting import
xdk:server (1432047265763): Component "server:zip-util" calling init()
xdk:server (1432047265763): Component "server:zip-util" finished initialization
xdk:server (1432047265763): Component "server:uuid-server" starting import
xdk:server (1432047265765): Component "server:uuid-server" calling init()
xdk:server (1432047265766): Component "server:uuid-server" finished initialization
xdk:server (1432047265766): Component "server:app-starter" starting import
xdk:server (1432047265772): Component "server:app-starter" calling init()
xdk:server (1432047265773): Component "server:app-starter" finished initialization
xdk:server (1432047265773): Component "server:force-download" starting import
xdk:server (1432047265776): Component "server:force-download" calling init()
xdk:server (1432047265776): Component "server:force-download" finished initialization
xdk:server (1432047265776): Component "server:updater" starting import
xdk:server (1432047265781): Component "server:updater" calling init()
server:updater (1432047265781): config.base-auto
server:updater (1432047265781): url=auto
xdk:server (1432047265782): Component "server:updater" finished initialization
xdk:server (1432047265782): Component "server:editor-node" starting import
xdk:server (1432047265802): Component "server:editor-node" calling init()
xdk:server (1432047265802): Component "server:editor-node" waiting for delayed initialization
xdk:server (1432047265802): Component "server:cordova-lib" starting import
xdk:server (1432047265846): Component "server:cordova-lib" calling init()
xdk:server (1432047265956): Component "server:cordova-lib" finished initialization
xdk:server (1432047265956): Component "server:api-explorer" starting import
xdk:server (1432047265959): Component "server:api-explorer" calling init()
xdk:server (1432047265978): Component "server:api-explorer" finished initialization
xdk:server (1432047265978): Component "server:plugin-listener" starting import
xdk:server (1432047265980): Component "server:plugin-listener" calling init()
xdk:server (1432047265980): Component "server:plugin-listener" finished initialization
server:editor-node (1432047265981): Starting Brackets node process D:\bin\node.exe D:\bin\node-core
xdk:server (1432047265992): NW Cache is up-to-date.
server:editor-node (1432047266101): Brackets node is running on port 64357
xdk:server (1432047266102): Component "server:editor-node" finished delayed initialization
xdk:server (1432047266102): Component "server:ui-builder" calling start()
xdk:server (1432047266105): Component "server:ui-builder" finished start()
xdk:server (1432047266105): Component "server:emulator-webserver" calling start()
xdk:server (1432047266105): Component "server:emulator-webserver" finished start()
xdk:server (1432047266105): Component "server:editor-node" calling start()
xdk:server (1432047266105): Component "server:editor-node" finished start()
xdk:server (1432047266107): Intel XDK is initialized now
xdk:server (1432047266108): Writing to the server data file
xdk:server (1432047266109): Wrote server data to "C:\Users\ccantagrel\AppData\Local\XDK\server-data.txt"
xdk:client (1432047266227): Successfully read server data file
xdk:client (1432047266360): Component "core:assert" starting import
xdk:client (1432047266360): Component "core:assert" finished initialization
xdk:client (1432047266360): Component "core:component-error" starting import
xdk:client (1432047266361): Component "core:component-error" finished initialization
xdk:client (1432047266361): Component "core:command-line-options" starting import
xdk:client (1432047266361): Component "core:command-line-options" finished initialization
xdk:client (1432047266361): Component "core:service-error" starting import
xdk:client (1432047266361): Component "core:service-error" finished initialization
xdk:client (1432047266361): Component "core:buffer" starting import
xdk:client (1432047266361): Component "core:buffer" finished initialization
xdk:client (1432047266361): Component "core:signaler" starting import
xdk:client (1432047266362): Component "core:signaler" finished initialization
xdk:client (1432047266362): Component "core:signaler-group" starting import
xdk:client (1432047266363): Component "core:signaler-group" finished initialization
xdk:client (1432047266363): Component "core:logger" starting import
xdk:client (1432047266364): Component "core:logger" finished initialization
xdk:client (1432047266364): Component "core:http-request" starting import
xdk:client (1432047266365): Component "core:http-request" finished initialization
xdk:client (1432047266365): Component "core:version" starting import
xdk:client (1432047266366): Component "core:version" finished initialization
xdk:client (1432047266366): Component "core:exit-notifier" starting import
xdk:client (1432047266366): Component "core:exit-notifier" finished initialization
xdk:client (1432047266366): Component "core:userfs-name-converter" starting import
xdk:client (1432047266366): Component "core:userfs-name-converter" finished initialization
xdk:client (1432047266366): Component "core:crash-handler" starting import
xdk:client (1432047266367): Component "core:crash-handler" finished initialization
xdk:client (1432047266367): Component "core:analytics" starting import
xdk:client (1432047266367): Component "core:analytics" finished initialization
xdk:client (1432047266367): Component "core:i18n-support" starting import
xdk:client (1432047266367): Component "core:i18n-support" finished initialization
xdk:client (1432047266367): Component "core:theme" starting import
xdk:client (1432047266400): Component "core:theme" finished initialization
xdk:client (1432047266410): Analytics ID: 4e26d75a-e1ab-4dbf-8f64-cee264ad6395
xdk:client (1432047266417): Component "client:app" starting import
xdk:client (1432047266417): Component "client:help-helper" starting import
xdk:client (1432047266417): Component "client:nativefs" starting import
xdk:client (1432047266417): Component "client:document-manager" starting import
xdk:client (1432047266417): Component "client:project-manager" starting import
xdk:client (1432047266417): Component "client:aa-controller" starting import
xdk:client (1432047266417): Component "client:projects-renderers" starting import
xdk:client (1432047266417): Component "client:projects-renderers-jsapp" starting import
xdk:client (1432047266417): Component "client:projects-renderers-webapp" starting import
xdk:client (1432047266417): Component "client:projects-renderers-iotapp" starting import
xdk:client (1432047266417): Component "client:active-sync" starting import
xdk:client (1432047266417): Component "client:apk-installer" starting import
xdk:client (1432047266417): Component "client:appcenter-options" starting import
xdk:client (1432047266417): Component "client:resource-manager" starting import
xdk:client (1432047266417): Component "client:resource-cocos2d" starting import
xdk:client (1432047266417): Component "client:resource-cocos2djs" starting import
xdk:client (1432047266417): Component "client:resource-phaser" starting import
xdk:client (1432047266417): Component "client:resource-pixi" starting import
xdk:client (1432047266417): Component "client:resource-easeljs" starting import
xdk:client (1432047266417): Component "client:resource-plain" starting import
xdk:client (1432047266417): Component "client:resource-render-frame" starting import
xdk:client (1432047266417): Component "client:resource-util" starting import
xdk:client (1432047266417): Component "client:services-tab" starting import
xdk:client (1432047266417): Component "client:editor" starting import
xdk:client (1432047266417): Component "client:live-preview" starting import
xdk:client (1432047266417): Component "client:backend-services" starting import
xdk:client (1432047266417): Component "client:backend-services-ext" starting import
xdk:client (1432047266417): Component "client:backend-service-utils" starting import
xdk:client (1432047266417): Component "client:app-starter" starting import
xdk:client (1432047266417): Component "client:ui-builder-client" starting import
xdk:client (1432047266417): Component "client:project-meta" starting import
xdk:client (1432047266418): Component "client:contenttype-registry" starting import
xdk:client (1432047266418): Component "client:editor-registry" starting import
xdk:client (1432047266418): Component "client:platform-registry" starting import
xdk:client (1432047266418): Component "client:projecttype-registry" starting import
xdk:client (1432047266418): Component "client:library-registry" starting import
xdk:client (1432047266418): Component "client:cordova-registry" starting import
xdk:client (1432047266418): Component "client:service-method" starting import
xdk:client (1432047266418): Component "client:settings-db" starting import
xdk:client (1432047266418): Component "client:adb" starting import
xdk:client (1432047266418): Component "client:iosdb" starting import
xdk:client (1432047266418): Component "client:device" starting import
xdk:client (1432047266418): Component "client:device-discovery" starting import
xdk:client (1432047266418): Component "client:dialog-box" starting import
xdk:client (1432047266418): Component "client:test-local-server" starting import
xdk:client (1432047266418): Component "client:quick-tour" starting import
xdk:client (1432047266418): Component "client:hot-keys" starting import
xdk:client (1432047266418): Component "client:persistance" starting import
xdk:client (1432047266418): Component "client:tabs" starting import
xdk:client (1432047266418): Component "client:hash-utils" starting import
xdk:client (1432047266418): Component "client:file-watcher" starting import
xdk:client (1432047266418): Component "client:tool-tip" starting import
xdk:client (1432047266418): Component "client:cordova" starting import
xdk:client (1432047266418): Component "client:settings-ui" starting import
xdk:client (1432047266418): Component "client:external-links" starting import
xdk:client (1432047266418): Component "client:external-editors-runner" starting import
xdk:client (1432047266452): Component "client:help-helper" finished initialization
xdk:client (1432047266452): Component "client:nativefs" finished initialization
xdk:client (1432047266461): Component "client:active-sync" calling init()
xdk:client (1432047266461): Component "client:active-sync" finished initialization
xdk:client (1432047266462): Component "client:apk-installer" calling init()
xdk:client (1432047266462): Component "client:apk-installer" finished initialization
xdk:client (1432047266468): Component "client:resource-easeljs" calling init()
xdk:client (1432047266469): Component "client:resource-easeljs" finished initialization
xdk:client (1432047266470): Component "client:resource-util" calling init()
xdk:client (1432047266470): Component "client:resource-util" finished initialization
xdk:client (1432047266472): Component "client:resource-render-frame" calling init()
xdk:client (1432047266472): Component "client:resource-render-frame" waiting for delayed initialization
xdk:client (1432047266474): Component "client:backend-services" calling init()
client:backend-services (1432047266474): Base url https://appcenter.html5tools-software.intel.com/, edition xdk
client:backend-services (1432047266475): Account paths: {
"login": "Account/xdklogin.aspx",
"logout": "csd/logout.aspx",
"register": "csd/Cloud-Services-Dashboard-Sign-Up.aspx",
"update": "csd/Account-Change.aspx",
"details": "csd/Account.aspx"
client:backend-services (1432047266475): Account urls: {
"login": "https://appcenter.html5tools-software.intel.com/Account/xdklogin.aspx?xdk=true&xdkvariant=xdk&xdkversion=release-2015-ww19",
"logout": "https://appcenter.html5tools-software.intel.com/csd/logout.aspx?xdk=true&xdkvariant=xdk&xdkversion=release-2015-ww19",
"register": "https://appcenter.html5tools-software.intel.com/csd/Cloud-Services-Dashboard-Sign-Up.aspx?xdk=true&xdkvariant=xdk&xdkversion=release-2015-ww19",
"update": "https://appcenter.html5tools-software.intel.com/csd/Account-Change.aspx?xdk=true&xdkvariant=xdk&xdkversion=release-2015-ww19",
"details": "https://appcenter.html5tools-software.intel.com/csd/Account.aspx?xdk=true&xdkvariant=xdk&xdkversion=release-2015-ww19"
client:backend-services (1432047266475): Service urls: {
"issue": "https://appcenter.html5tools-software.intel.com/xdkissue",
"certificate": "https://appcenter.html5tools-software.intel.com/xdk2/v2/api.asmx/gencert",
"projectRenderers": "https://appcenter.html5tools-software.intel.com/api/v2.0/redirect/projectrenderers/",
"updates": "https://appcenter.html5tools-software.intel.com/api/v2.0/redirect/updates/xdk/",
"curatedServices": "https://appcenter.html5tools-software.intel.com/api/v2.0/redirect/appservices/"
xdk:client (1432047266475): Component "client:backend-services" finished initialization
xdk:client (1432047266475): Component "client:backend-services-ext" calling init()
xdk:client (1432047266476): Component "client:backend-services-ext" finished initialization
xdk:client (1432047266476): Component "client:backend-service-utils" finished initialization
xdk:client (1432047266478): Component "client:project-meta" calling init()
xdk:client (1432047266478): Component "client:project-meta" finished initialization
xdk:client (1432047266482): Component "client:service-method" finished initialization
xdk:client (1432047266483): Component "client:adb" calling init()
xdk:client (1432047266494): Component "client:adb" waiting for delayed initialization
xdk:client (1432047266495): Component "client:settings-db" calling init()
xdk:client (1432047266495): Component "client:settings-db" waiting for delayed initialization
xdk:client (1432047266495): Component "client:iosdb" calling init()
xdk:client (1432047266496): Component "client:iosdb" finished initialization
xdk:client (1432047266497): Component "client:device" finished initialization
xdk:client (1432047266501): Component "client:persistance" calling init()
xdk:client (1432047266501): Component "client:persistance" waiting for delayed initialization
xdk:client (1432047266503): Component "client:file-watcher" calling init()
xdk:client (1432047266503): Component "client:file-watcher" finished initialization
xdk:client (1432047266505): Component "client:external-links" finished initialization
xdk:client (1432047266506): Component "client:external-editors-runner" calling init()
xdk:client (1432047266506): Component "client:external-editors-runner" finished initialization
xdk:client (1432047266509): Component "client:resource-render-frame" finished delayed initialization
xdk:client (1432047266517): Component "client:tool-tip" finished initialization
xdk:client (1432047266521): Component "client:app-starter" finished initialization
xdk:client (1432047266523): Component "client:ui-builder-client" calling init()
xdk:client (1432047266523): Component "client:ui-builder-client" finished initialization
xdk:client (1432047266524): Component "client:dialog-box" finished initialization
xdk:client (1432047266524): Component "client:hot-keys" calling init()
xdk:client (1432047266524): Component "client:hot-keys" finished initialization
xdk:client (1432047266526): Component "client:settings-ui" finished initialization
xdk:client (1432047266527): Component "client:document-manager" calling init()
xdk:client (1432047266528): Component "client:document-manager" finished initialization
xdk:client (1432047266542): Component "client:aa-controller" calling init()
xdk:client (1432047266542): Component "client:aa-controller" finished initialization
xdk:client (1432047266565): Component "client:contenttype-registry" calling init()
xdk:client (1432047266566): Component "client:contenttype-registry" finished initialization
xdk:client (1432047266572): Component "client:editor-registry" finished initialization
xdk:client (1432047266574): Component "client:library-registry" calling init()
xdk:client (1432047266574): Component "client:library-registry" finished initialization
xdk:client (1432047266576): Component "client:cordova-registry" calling init()
xdk:client (1432047266576): Component "client:cordova-registry" waiting for delayed initialization
xdk:client (1432047266578): Component "client:device-discovery" calling init()
xdk:client (1432047266578): Component "client:device-discovery" waiting for delayed initialization
xdk:client (1432047266579): Component "client:hash-utils" finished initialization
xdk:client (1432047266595): Component "client:cordova" calling init()
xdk:client (1432047266595): Component "client:cordova" finished initialization
xdk:client (1432047266598): Component "client:device-discovery" finished delayed initialization
xdk:client (1432047266610): Component "client:resource-manager" calling init()
xdk:client (1432047266610): Component "client:resource-manager" waiting for delayed initialization
xdk:client (1432047266615): Component "client:resource-cocos2djs" calling init()
xdk:client (1432047266615): Component "client:resource-cocos2djs" finished initialization
xdk:client (1432047266616): Component "client:resource-phaser" calling init()
xdk:client (1432047266616): Component "client:resource-phaser" finished initialization
xdk:client (1432047266617): Component "client:resource-pixi" calling init()
xdk:client (1432047266617): Component "client:resource-pixi" finished initialization
xdk:client (1432047266618): Component "client:resource-plain" calling init()
xdk:client (1432047266618): Component "client:resource-plain" finished initialization
xdk:client (1432047266622): Component "client:appcenter-options" calling init()
xdk:client (1432047266623): Component "client:appcenter-options" waiting for delayed initialization
xdk:client (1432047266623): Component "client:services-tab" calling init()
xdk:client (1432047266624): Component "client:services-tab" finished initialization
xdk:client (1432047266625): Component "client:test-local-server" calling init()
xdk:client (1432047266644): Component "client:test-local-server" finished initialization
xdk:client (1432047266644): Component "client:tabs" finished initialization
xdk:client (1432047266647): Component "client:app" calling init()
xdk:client (1432047266654): Component "client:app" finished initialization
xdk:client (1432047266663): Component "client:quick-tour" calling init()
xdk:client (1432047266663): Component "client:quick-tour" finished initialization
xdk:client (1432047266670): Component "client:project-manager" calling init()
xdk:client (1432047266670): Component "client:project-manager" waiting for delayed initialization
xdk:client (1432047266673): Component "client:projects-renderers" calling init()
xdk:client (1432047266673): Component "client:projects-renderers" waiting for delayed initialization
xdk:client (1432047266673): Component "client:projects-renderers-iotapp" calling init()
xdk:client (1432047266673): Component "client:projects-renderers-iotapp" finished initialization
xdk:client (1432047266679): Component "client:resource-cocos2d" calling init()
xdk:client (1432047266679): Component "client:resource-cocos2d" waiting for delayed initialization
xdk:client (1432047266683): Component "client:platform-registry" calling init()
xdk:client (1432047266684): Component "client:platform-registry" finished initialization
xdk:client (1432047266685): Component "client:projecttype-registry" calling init()
xdk:client (1432047266685): Component "client:projecttype-registry" finished initialization
xdk:client (1432047266686): Component "client:navbar" starting import
xdk:client (1432047266686): Component "client:tweets" starting import
xdk:client (1432047266686): Component "client:projects-tab" starting import
xdk:client (1432047266686): Component "client:test-tab" starting import
xdk:client (1432047266686): Component "client:profilingTab" starting import
xdk:client (1432047266686): Component "client:emulator" starting import
xdk:client (1432047266686): Component "client:remote-tab" starting import
xdk:client (1432047266686): Component "client:build-tab" starting import
xdk:client (1432047266686): Component "client:editor-tab" starting import
xdk:client (1432047266686): Component "client:account" starting import
xdk:client (1432047266686): Component "client:project-selector" starting import
xdk:client (1432047266692): Component "client:cordova-registry" finished delayed initialization
xdk:client (1432047266692): Component "client:resource-cocos2d" finished delayed initialization
xdk:client (1432047266702): Component "client:projects-renderers-jsapp" calling init()
xdk:client (1432047266702): Component "client:projects-renderers-jsapp" finished initialization
xdk:client (1432047266702): Component "client:projects-renderers-webapp" calling init()
xdk:client (1432047266703): Component "client:projects-renderers-webapp" finished initialization
xdk:client (1432047266720): Component "client:projects-renderers" finished delayed initialization
xdk:client (1432047266726): Component "client:settings-db" finished delayed initialization
xdk:client (1432047266738): Component "client:editor" calling init()
xdk:client (1432047266739): Component "client:editor" finished initialization
xdk:client (1432047266739): Component "client:live-preview" calling init()
xdk:client (1432047266739): Component "client:live-preview" finished initialization
xdk:client (1432047266739): Component "client:editor-tab" getting UI region for "develop"
xdk:client (1432047266739): Component "client:editor-tab" calling init()
xdk:client (1432047266747): Component "client:editor-tab" waiting for delayed initialization
xdk:client (1432047266777): Component "client:account" getting UI region for "account"
xdk:client (1432047266777): Component "client:account" calling init()
xdk:client (1432047266779): Component "client:account" finished initialization
xdk:client (1432047266780): Component "client:project-selector" getting UI region for "project-selector"
xdk:client (1432047266780): Component "client:project-selector" calling init()
xdk:client (1432047266780): Component "client:project-selector" finished initialization
xdk:client (1432047266781): Component "client:tweets" finished initialization
xdk:client (1432047266782): Component "client:projects-tab" getting UI region for "project"
xdk:client (1432047266782): Component "client:projects-tab" calling init()
xdk:client (1432047266782): Component "client:projects-tab" waiting for delayed initialization
xdk:client (1432047266784): Component "client:test-tab" getting UI region for "test"
xdk:client (1432047266784): Component "client:test-tab" calling init()
xdk:client (1432047266794): Component "client:test-tab" finished initialization
xdk:client (1432047266796): Component "client:emulator" getting UI region for "emulate"
xdk:client (1432047266796): Component "client:emulator" calling init()
xdk:client (1432047266797): Component "client:emulator" finished initialization
xdk:client (1432047266798): Component "client:build-tab" getting UI region for "build"
xdk:client (1432047266798): Component "client:build-tab" calling init()
xdk:client (1432047266801): Component "client:build-tab" finished initialization
xdk:client (1432047266808): Component "client:navbar" getting UI region for "navbar-common"
xdk:client (1432047266808): Component "client:navbar" calling init()
client:navbar (1432047266809): navbar options: {"common":{"servicesVersion":"release-2015-ww19","xdkVariant":"xdk"},"updatePollingInterval":1800,"forceUpdate":false}
xdk:client (1432047266809): Component "client:navbar" finished initialization
xdk:client (1432047266828): Component "client:remote-tab" getting UI region for "debug"
xdk:client (1432047266828): Component "client:remote-tab" calling init()
xdk:client (1432047266937): Component "client:remote-tab" finished initialization
client:adb (1432047266950): Using existing adb at "D:\bin\adb\adb.exe"
xdk:client (1432047266984): Component "client:profilingTab" getting UI region for "profile"
xdk:client (1432047266985): Component "client:profilingTab" calling init()
xdk:client (1432047266986): Component "client:profilingTab" finished initialization
xdk:client (1432047266989): Component "client:adb" finished delayed initialization
client:appcenter-options (1432047267173): Fetch Status: 1, Message: Feched latest appcenter-options info because network is available.
xdk:client (1432047267174): Component "client:appcenter-options" finished delayed initialization
xdk:client (1432047268180): Component "client:project-manager" finished delayed initialization
xdk:client (1432047268192): Component "client:resource-manager" finished delayed initialization
xdk:client (1432047268192): Component "client:projects-tab" finished delayed initialization
xdk:client (1432047268192): Component "client:projects-list" starting import
xdk:client (1432047268192): Component "client:projects-info" starting import
xdk:client (1432047268192): Component "client:projects-create-list" starting import
xdk:client (1432047268192): Component "client:projects-create-info" starting import
xdk:client (1432047268230): Component "client:projects-list" getting UI region for "existing-list"
xdk:client (1432047268230): Component "client:projects-list" calling init()
xdk:client (1432047268231): Component "client:projects-list" finished initialization
xdk:client (1432047268281): Component "client:projects-info" getting UI region for "existing-info"
xdk:client (1432047268281): Component "client:projects-info" calling init()
xdk:client (1432047268282): Component "client:projects-info" finished initialization
xdk:client (1432047268290): Component "client:projects-create-info" getting UI region for "create-info"
xdk:client (1432047268290): Component "client:projects-create-info" calling init()
xdk:client (1432047268290): Component "client:projects-create-info" finished initialization
xdk:client (1432047268293): Component "client:projects-create-list" getting UI region for "create-list"
xdk:client (1432047268294): Component "client:projects-create-list" calling init()
xdk:client (1432047268294): Component "client:projects-create-list" finished initialization
xdk:client (1432047268808): memmrk: 44366052 62750336
xdk:server (1432047269315): memmrk: 27104440 43419136
xdk:client (1432047269680): Component "client:editor-tab" finished delayed initialization
xdk:client (1432047273792): memmrk: 65235500 89572480
xdk:server (1432047274315): memmrk: 54832556 77241344
xdk:client (1432047278792): memmrk: 71186128 92607360
xdk:server (1432047279315): memmrk: 55289408 77241344
xdk:client (1432047283006): Component "client:persistance" finished delayed initialization
xdk:client (1432047283007): Component "client:app" calling start()
xdk:client (1432047283028): Component "client:app" finished start()
xdk:client (1432047283028): Component "client:navbar" calling start()
xdk:client (1432047283039): Component "client:navbar" finished start()
xdk:client (1432047283039): Component "client:project-manager" calling start()
xdk:client (1432047283039): Component "client:project-manager" finished start()
xdk:client (1432047283039): Component "client:aa-controller" calling start()
xdk:client (1432047283040): Component "client:aa-controller" finished start()
xdk:client (1432047283040): Component "client:projects-tab" calling start()
xdk:client (1432047283047): Component "client:projects-tab" finished start()
xdk:client (1432047283047): Component "client:projects-list" calling start()
xdk:client (1432047283050): Component "client:projects-list" finished start()
xdk:client (1432047283050): Component "client:projects-info" calling start()
xdk:client (1432047283153): Component "client:projects-info" finished start()
xdk:client (1432047283154): Component "client:projects-create-list" calling start()
xdk:client (1432047283165): Component "client:projects-create-list" finished start()
xdk:client (1432047283165): Component "client:projects-create-info" calling start()
xdk:client (1432047283169): Component "client:projects-create-info" finished start()
xdk:client (1432047283169): Component "client:test-tab" calling start()
xdk:client (1432047283172): Component "client:test-tab" finished start()
xdk:client (1432047283172): Component "client:profilingTab" calling start()
xdk:client (1432047283206): Component "client:profilingTab" finished start()
xdk:client (1432047283206): Component "client:emulator" calling start()
xdk:client (1432047283207): Component "client:emulator" finished start()
xdk:client (1432047283207): Component "client:remote-tab" calling start()
xdk:client (1432047283210): Component "client:remote-tab" finished start()
xdk:client (1432047283210): Component "client:build-tab" calling start()
xdk:client (1432047283212): Component "client:build-tab" finished start()
xdk:client (1432047283212): Component "client:active-sync" calling start()
xdk:client (1432047283212): Component "client:active-sync" finished start()
xdk:client (1432047283212): Component "client:apk-installer" calling start()
xdk:client (1432047283212): Component "client:apk-installer" finished start()
xdk:client (1432047283213): Component "client:resource-manager" calling start()
xdk:client (1432047283213): Component "client:resource-manager" finished start()
xdk:client (1432047283213): Component "client:resource-cocos2d" calling start()
xdk:client (1432047283213): Component "client:resource-cocos2d" finished start()
xdk:client (1432047283213): Component "client:resource-cocos2djs" calling start()
xdk:client (1432047283214): Component "client:resource-cocos2djs" finished start()
xdk:client (1432047283214): Component "client:resource-phaser" calling start()
xdk:client (1432047283214): Component "client:resource-phaser" finished start()
xdk:client (1432047283214): Component "client:resource-pixi" calling start()
xdk:client (1432047283214): Component "client:resource-pixi" finished start()
xdk:client (1432047283214): Component "client:resource-easeljs" calling start()
xdk:client (1432047283214): Component "client:resource-easeljs" finished start()
xdk:client (1432047283214): Component "client:resource-plain" calling start()
xdk:client (1432047283214): Component "client:resource-plain" finished start()
xdk:client (1432047283214): Component "client:resource-render-frame" calling start()
xdk:client (1432047283214): Component "client:resource-render-frame" finished start()
xdk:client (1432047283214): Component "client:resource-util" calling start()
xdk:client (1432047283214): Component "client:resource-util" finished start()
xdk:client (1432047283214): Component "client:editor" calling start()
xdk:client (1432047283214): Component "client:editor" finished start()
xdk:client (1432047283214): Component "client:editor-tab" calling start()
xdk:client (1432047283232): Component "client:editor-tab" finished start()
xdk:client (1432047283232): Component "client:live-preview" calling start()
xdk:client (1432047283232): Component "client:live-preview" finished start()
xdk:client (1432047283232): Component "client:account" calling start()
xdk:client (1432047283232): Component "client:account" finished start()
xdk:client (1432047283232): Component "client:project-selector" calling start()
xdk:client (1432047283235): Component "client:project-selector" finished start()
xdk:client (1432047283235): Component "client:app-starter" calling start()
xdk:client (1432047283235): Component "client:app-starter" finished start()
xdk:client (1432047283235): Component "client:ui-builder-client" calling start()
xdk:client (1432047283236): Component "client:ui-builder-client" finished start()
xdk:client (1432047283236): Component "client:project-meta" calling start()
xdk:client (1432047283236): Component "client:project-meta" finished start()
xdk:client (1432047283236): Component "client:cordova-registry" calling start()
xdk:client (1432047283236): Component "client:cordova-registry" finished start()
xdk:client (1432047283236): Component "client:adb" calling start()
xdk:client (1432047283236): Component "client:adb" finished start()
xdk:client (1432047283236): Component "client:iosdb" calling start()
xdk:client (1432047283237): Component "client:iosdb" finished start()
xdk:client (1432047283237): Component "client:device-discovery" calling start()
xdk:client (1432047283239): Component "client:device-discovery" finished start()
xdk:client (1432047283239): Component "client:test-local-server" calling start()
xdk:client (1432047283239): Component "client:test-local-server" finished start()
xdk:client (1432047283239): Component "client:quick-tour" calling start()
xdk:client (1432047283239): Component "client:quick-tour" finished start()
xdk:client (1432047283239): Component "client:hot-keys" calling start()
xdk:client (1432047283241): Component "client:hot-keys" finished start()
xdk:client (1432047283241): Component "client:persistance" calling start()
xdk:client (1432047283242): Component "client:persistance" finished start()
xdk:client (1432047283242): Component "client:file-watcher" calling start()
xdk:client (1432047283242): Component "client:file-watcher" finished start()
xdk:client (1432047283242): Component "client:cordova" calling start()
xdk:client (1432047283243): Component "client:cordova" finished start()
xdk:client (1432047283243): Component "client:external-editors-runner" calling start()
xdk:client (1432047283243): Component "client:external-editors-runner" finished start()
xdk:client (1432047283245): Intel XDK is initialized now
client:navbar (1432047283278): pollForUpdates called
xdk:client (1432047284226): memmrk: 49314008 100720640
client:navbar (1432047284263): polling up-to-date
xdk:server (1432047284317): memmrk: 57870600 77241344
xdk:client (1432047289227): memmrk: 51700960 100720640
xdk:server (1432047289317): memmrk: 25929432 63696256
xdk:client (1432047294228): memmrk: 52150960 100720640
xdk:server (1432047294317): memmrk: 25942456 63696256
xdk:client (1432047299229): memmrk: 52438156 100720640
xdk:server (1432047299318): memmrk: 20117384 35791616
xdk:client (1432047304229): memmrk: 52856800 100720640
xdk:server (1432047304319): memmrk: 19233256 27702656
xdk:client (1432047309230): memmrk: 53127924 100720640
xdk:server (1432047309319): memmrk: 19242000 27702656
xdk:client (1432047314231): memmrk: 53546412 100720640
xdk:server (1432047314319): memmrk: 17948748 27702656
xdk:client (1432047319249): memmrk: 56078172 100720640
xdk:server (1432047319321): memmrk: 17958324 27702656
xdk:client (1432047324248): memmrk: 56650976 100720640
xdk:server (1432047324320): memmrk: 17573728 24679936
xdk:client (1432047329248): memmrk: 59550036 100720640
xdk:server (1432047329320): memmrk: 17543008 25728512
xdk:client (1432047334250): memmrk: 60465152 100720640
xdk:server (1432047334322): memmrk: 17072820 25728512
xdk:client (1432047339263): memmrk: 61980900 100720640
xdk:server (1432047339322): memmrk: 17079724 25728512
xdk:client (1432047344263): memmrk: 57480576 100720640
xdk:server (1432047344322): memmrk: 17086120 25728512
xdk:client (1432047349263): memmrk: 58607468 100720640
xdk:server (1432047349322): memmrk: 17092516 25728512
xdk:client (1432047354264): memmrk: 60191892 100720640
xdk:server (1432047354324): memmrk: 17098912 25728512
xdk:client (1432047359314): memmrk: 61095260 100720640
xdk:server (1432047359324): memmrk: 17104384 25728512
xdk:client (1432047364315): memmrk: 62848084 100720640
xdk:server (1432047364324): memmrk: 17110780 25728512
xdk:client (1432047369318): memmrk: 61380528 101736320
xdk:server (1432047369325): memmrk: 17117172 25728512
xdk:client (1432047374317): memmrk: 62751384 101736320
xdk:server (1432047374326): memmrk: 17123568 25728512
xdk:client (1432047379317): memmrk: 63574788 101736320
xdk:server (1432047379326): memmrk: 17129964 25728512
xdk:client (1432047384321): memmrk: 64883104 101736320
xdk:server (1432047384329): memmrk: 17136360 25728512
xdk:client (1432047389322): memmrk: 44480960 99241856
xdk:server (1432047389330): memmrk: 17142756 25728512
xdk:client (1432047394323): memmrk: 44969272 99241856
xdk:server (1432047394331): memmrk: 17149152 25728512
xdk:client (1432047399323): memmrk: 45261888 99241856
xdk:server (1432047399331): memmrk: 17155548 25728512
xdk:client (1432047404324): memmrk: 41799768 63272576
xdk:server (1432047404332): memmrk: 17161944 25728512
xdk:client (1432047409325): memmrk: 42078644 63272576
xdk:server (1432047409332): memmrk: 17168340 25728512
xdk:client (1432047414325): memmrk: 43727288 66418304
xdk:server (1432047414333): memmrk: 17174736 25728512
xdk:client (1432047419325): memmrk: 44323164 66418304
xdk:server (1432047419333): memmrk: 17181132 25728512
xdk:client (1432047424327): memmrk: 43387876 66418304
xdk:server (1432047424334): memmrk: 17187528 25728512
xdk:client (1432047429327): memmrk: 43925780 66418304
xdk:server (1432047429335): memmrk: 17195228 25728512
xdk:server (1432047434335): memmrk: 17202868 25728512
xdk:client (1432047434337): memmrk: 45988424 66418304
client:emulator (1432047439129): Device Emulator :: Environment Warming Up (Tea. Earl Gray. Hot.)
client:emulator (1432047439314): appmobi_plus_cordova :: Emulator changing to project mmt_1
xdk:server (1432047439336): memmrk: 18466080 26744192
client:emulator (1432047439320): appmobi_plus_cordova :: _xdkLoad for project mmt_1
xdk:client (1432047439355): memmrk: 54694312 73647488
client:emulator (1432047442602): appmobi_plus_cordova :: Initialization Finished (Make it so.)
server:emulator-webserver (1432047442607): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442608): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/index.html
server:emulator-webserver (1432047442608): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/index.html
client:emulator (1432047442602): appmobi_plus_cordova :: frame appended to document
server:emulator-webserver (1432047442731): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442732): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
server:emulator-webserver (1432047442732): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
server:emulator-webserver (1432047442733): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442733): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js
server:emulator-webserver (1432047442734): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js
server:emulator-webserver (1432047442736): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442736): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js
server:emulator-webserver (1432047442736): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js
server:emulator-webserver (1432047442738): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442738): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js
server:emulator-webserver (1432047442738): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js
server:emulator-webserver (1432047442745): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442745): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js
server:emulator-webserver (1432047442745): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js
server:emulator-webserver (1432047442750): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442750): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/login_controller.js
server:emulator-webserver (1432047442751): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/login_controller.js
server:emulator-webserver (1432047442754): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442754): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/layout_controller.js
server:emulator-webserver (1432047442754): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/layout_controller.js
server:emulator-webserver (1432047442758): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442758): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js
server:emulator-webserver (1432047442759): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js
server:emulator-webserver (1432047442765): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442765): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/login_service.js
server:emulator-webserver (1432047442765): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/login_service.js
server:emulator-webserver (1432047442767): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442767): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/layout_service.js
server:emulator-webserver (1432047442767): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/layout_service.js
server:emulator-webserver (1432047442768): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442768): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/routing_service.js
server:emulator-webserver (1432047442769): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/routing_service.js
server:emulator-webserver (1432047442773): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442773): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/cordova.js
server:emulator-webserver (1432047442774): Send cordova.js from D:\xdk\components\server\emulator\resources\cordova.js
server:emulator-webserver (1432047442776): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442776): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/xhr.js
server:emulator-webserver (1432047442776): xhr.js request fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/xhr.js
server:emulator-webserver (1432047442777): sending empty contents for missing xhr.js file
server:emulator-webserver (1432047443442): emulator-webserver: got a request for userapp.
client:emulator (1432047443442): appmobi_plus_cordova :: Emulation frame loaded
server:emulator-webserver (1432047443442): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view1.html
server:emulator-webserver (1432047443442): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view1.html
server:emulator-webserver (1432047443444): HTML file doesn't look like entire document; skipping injection
client:emulator (1432047443446): appmobi_plus_cordova :: fired appMobi.device.ready event!
client:emulator (1432047443616): appmobi_plus_cordova :: tinyHipposLoaded cleared _loading/_delayedproject
server:emulator-webserver (1432047443616): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443616): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/cordova_plugins.js
client:emulator (1432047443617): appmobi_plus_cordova :: [emulator] file watcher started
server:emulator-webserver (1432047443616): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/cordova_plugins.js
server:emulator-webserver (1432047443685): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443685): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/Acceleration.js
server:emulator-webserver (1432047443685): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/Acceleration.js
server:emulator-webserver (1432047443686): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443686): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/accelerometer.js
server:emulator-webserver (1432047443687): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/accelerometer.js
server:emulator-webserver (1432047443687): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443687): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraConstants.js
server:emulator-webserver (1432047443688): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraConstants.js
server:emulator-webserver (1432047443689): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443689): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraPopoverOptions.js
server:emulator-webserver (1432047443689): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraPopoverOptions.js
server:emulator-webserver (1432047443698): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443699): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/Camera.js
server:emulator-webserver (1432047443699): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/Camera.js
server:emulator-webserver (1432047443700): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443700): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/ios/CameraPopoverHandle.js
server:emulator-webserver (1432047443700): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/ios/CameraPopoverHandle.js
server:emulator-webserver (1432047443704): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443704): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureAudioOptions.js
server:emulator-webserver (1432047443704): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureAudioOptions.js
server:emulator-webserver (1432047443706): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443706): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureImageOptions.js
server:emulator-webserver (1432047443707): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureImageOptions.js
server:emulator-webserver (1432047443714): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443714): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureVideoOptions.js
server:emulator-webserver (1432047443714): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureVideoOptions.js
server:emulator-webserver (1432047443715): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443715): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureError.js
server:emulator-webserver (1432047443715): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureError.js
server:emulator-webserver (1432047443720): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443720): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFileData.js
server:emulator-webserver (1432047443720): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFileData.js
server:emulator-webserver (1432047443723): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443723): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFile.js
server:emulator-webserver (1432047443723): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFile.js
server:emulator-webserver (1432047443725): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443726): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/capture.js
server:emulator-webserver (1432047443726): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/capture.js
server:emulator-webserver (1432047443727): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443727): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassError.js
server:emulator-webserver (1432047443727): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassError.js
server:emulator-webserver (1432047443734): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443734): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassHeading.js
server:emulator-webserver (1432047443734): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassHeading.js
server:emulator-webserver (1432047443737): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443737): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/compass.js
server:emulator-webserver (1432047443737): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/compass.js
server:emulator-webserver (1432047443739): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443739): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/network.js
server:emulator-webserver (1432047443740): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/network.js
server:emulator-webserver (1432047443742): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443743): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/Connection.js
server:emulator-webserver (1432047443743): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/Connection.js
server:emulator-webserver (1432047443751): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443751): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/contacts.js
server:emulator-webserver (1432047443752): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/contacts.js
server:emulator-webserver (1432047443755): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443755): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/Contact.js
server:emulator-webserver (1432047443755): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/Contact.js
server:emulator-webserver (1432047443759): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443759): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactAddress.js
server:emulator-webserver (1432047443760): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactAddress.js
server:emulator-webserver (1432047443761): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443762): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactError.js
server:emulator-webserver (1432047443762): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactError.js
server:emulator-webserver (1432047443771): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443771): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactField.js
server:emulator-webserver (1432047443772): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactField.js
server:emulator-webserver (1432047443779): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443779): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFindOptions.js
server:emulator-webserver (1432047443780): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFindOptions.js
server:emulator-webserver (1432047443782): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443782): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactName.js
server:emulator-webserver (1432047443782): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactName.js
server:emulator-webserver (1432047443784): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443784): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactOrganization.js
server:emulator-webserver (1432047443784): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactOrganization.js
server:emulator-webserver (1432047443787): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443787): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFieldType.js
server:emulator-webserver (1432047443788): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFieldType.js
server:emulator-webserver (1432047443796): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443796): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/contacts.js
server:emulator-webserver (1432047443797): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/contacts.js
server:emulator-webserver (1432047443798): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443798): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/Contact.js
server:emulator-webserver (1432047443798): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/Contact.js
server:emulator-webserver (1432047443799): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443799): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device/www/device.js
server:emulator-webserver (1432047443799): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device/www/device.js
server:emulator-webserver (1432047443804): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443804): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.battery-status/www/battery.js
server:emulator-webserver (1432047443804): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.battery-status/www/battery.js
server:emulator-webserver (1432047443809): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443809): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransferError.js
server:emulator-webserver (1432047443810): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransferError.js
server:emulator-webserver (1432047443811): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443811): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransfer.js
server:emulator-webserver (1432047443811): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransfer.js
server:emulator-webserver (1432047443812): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443812): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Coordinates.js
server:emulator-webserver (1432047443812): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Coordinates.js
server:emulator-webserver (1432047443823): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443823): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/PositionError.js
server:emulator-webserver (1432047443823): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/PositionError.js
server:emulator-webserver (1432047443828): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443828): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Position.js
server:emulator-webserver (1432047443829): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Position.js
server:emulator-webserver (1432047443832): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443832): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/geolocation.js
server:emulator-webserver (1432047443833): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/geolocation.js
server:emulator-webserver (1432047443834): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443834): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/GlobalizationError.js
server:emulator-webserver (1432047443834): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/GlobalizationError.js
server:emulator-webserver (1432047443838): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443838): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/globalization.js
server:emulator-webserver (1432047443838): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/globalization.js
server:emulator-webserver (1432047443842): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443842): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.inappbrowser/www/inappbrowser.js
server:emulator-webserver (1432047443843): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.inappbrowser/www/inappbrowser.js
server:emulator-webserver (1432047443846): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443846): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/MediaError.js
server:emulator-webserver (1432047443847): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/MediaError.js
server:emulator-webserver (1432047443848): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443848): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/Media.js
server:emulator-webserver (1432047443849): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/Media.js
server:emulator-webserver (1432047443853): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443853): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.dialogs/www/notification.js
server:emulator-webserver (1432047443854): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.dialogs/www/notification.js
server:emulator-webserver (1432047443857): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443857): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.vibration/www/vibration.js
server:emulator-webserver (1432047443862): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.vibration/www/vibration.js
server:emulator-webserver (1432047443872): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443872): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.splashscreen/www/splashscreen.js
server:emulator-webserver (1432047443872): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.splashscreen/www/splashscreen.js
server:emulator-webserver (1432047443874): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443874): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.statusbar/www/statusbar.js
server:emulator-webserver (1432047443874): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.statusbar/www/statusbar.js
server:emulator-webserver (1432047443878): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443878): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryEntry.js
server:emulator-webserver (1432047443878): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryEntry.js
server:emulator-webserver (1432047443881): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443881): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryReader.js
server:emulator-webserver (1432047443882): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryReader.js
server:emulator-webserver (1432047443884): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443884): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Entry.js
server:emulator-webserver (1432047443885): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Entry.js
server:emulator-webserver (1432047443886): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443886): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/File.js
server:emulator-webserver (1432047443886): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/File.js
server:emulator-webserver (1432047443891): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443891): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileEntry.js
server:emulator-webserver (1432047443891): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileEntry.js
server:emulator-webserver (1432047443892): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443892): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileError.js
server:emulator-webserver (1432047443893): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileError.js
server:emulator-webserver (1432047443897): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443897): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileReader.js
server:emulator-webserver (1432047443898): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileReader.js
server:emulator-webserver (1432047443899): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443899): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileSystem.js
server:emulator-webserver (1432047443899): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileSystem.js
server:emulator-webserver (1432047443905): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443905): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadOptions.js
server:emulator-webserver (1432047443906): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadOptions.js
server:emulator-webserver (1432047443907): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443907): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadResult.js
server:emulator-webserver (1432047443908): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadResult.js
server:emulator-webserver (1432047443915): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443915): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileWriter.js
server:emulator-webserver (1432047443915): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileWriter.js
server:emulator-webserver (1432047443920): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443920): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Flags.js
server:emulator-webserver (1432047443920): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Flags.js
server:emulator-webserver (1432047443921): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443921): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/LocalFileSystem.js
server:emulator-webserver (1432047443922): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/LocalFileSystem.js
server:emulator-webserver (1432047443922): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443922): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Metadata.js
server:emulator-webserver (1432047443923): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Metadata.js
server:emulator-webserver (1432047443926): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443926): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ProgressEvent.js
server:emulator-webserver (1432047443927): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ProgressEvent.js
server:emulator-webserver (1432047443930): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443930): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems.js
server:emulator-webserver (1432047443931): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems.js
server:emulator-webserver (1432047443934): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443934): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/requestFileSystem.js
server:emulator-webserver (1432047443934): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/requestFileSystem.js
server:emulator-webserver (1432047443937): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443937): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/resolveLocalFileSystemURI.js
server:emulator-webserver (1432047443937): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/resolveLocalFileSystemURI.js
server:emulator-webserver (1432047443940): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443940): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ios/FileSystem.js
server:emulator-webserver (1432047443940): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ios/FileSystem.js
server:emulator-webserver (1432047443942): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443942): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems-roots.js
server:emulator-webserver (1432047443943): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems-roots.js
server:emulator-webserver (1432047443946): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443946): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystemPaths.js
server:emulator-webserver (1432047443947): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystemPaths.js
xdk:server (1432047444339): memmrk: 42774688 57638656
xdk:client (1432047444582): memmrk: 110167600 131804416
client:emulator (1432047444604): appmobi_plus_cordova :: Native back button handler was detached.
xdk:server (1432047449339): memmrk: 42781684 57638656
xdk:client (1432047449568): memmrk: 116776416 136882816
server:emulator-webserver (1432047451580): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047451580): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
server:emulator-webserver (1432047451580): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
server:emulator-webserver (1432047451584): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047451584): req.path = /http-services/emulator-webserver/ripple/userapp/C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map
server:emulator-webserver (1432047451584): Other file request, fullPath = C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map
server:emulator-webserver (1432047451591): Error testing path C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map; msg = ERROR: name must either start with slash or use base option
Error
at ComponentError (D:\xdk\core-modules\public\component-error.js:17:1122)
at new ServiceError (D:\xdk\core-modules\public\service-error.js:17:317)
at _ensureStartsWithSlashOrUsesBaseOption (D:\xdk\components\server\userfs\filter\sanitize.js:17:800)
at D:\xdk\components\server\userfs\filter\sanitize.js:17:1227
at Array.forEach (native)
at Function._.each._.forEach (D:\xdk\node_modules\underscore\underscore.js:79:11)
at D:\xdk\components\server\userfs\filter\sanitize.js:17:1120
at beforeFilter (D:\xdk\components\server\userfs\filter\sanitize.js:17:1082)
xdk:server (1432047454339): memmrk: 37727676 58654336
client:emulator (1432047454390): appmobi_plus_cordova :: Emulator restarting mmt_1
client:emulator (1432047454397): appmobi_plus_cordova :: _xdkLoad for project mmt_1
xdk:client (1432047454568): memmrk: 48891716 83076096
client:emulator (1432047456547): appmobi_plus_cordova :: Initialization Finished (Make it so.)
server:emulator-webserver (1432047456551): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456551): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/index.html
server:emulator-webserver (1432047456551): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/index.html
client:emulator (1432047456549): appmobi_plus_cordova :: frame appended to document
server:emulator-webserver (1432047456669): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456669): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
server:emulator-webserver (1432047456669): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
server:emulator-webserver (1432047456670): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456670): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js
server:emulator-webserver (1432047456671): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js
server:emulator-webserver (1432047456680): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456680): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js
server:emulator-webserver (1432047456680): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js
server:emulator-webserver (1432047456681): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456681): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js
server:emulator-webserver (1432047456682): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js
server:emulator-webserver (1432047456683): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456683): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js
server:emulator-webserver (1432047456683): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js
server:emulator-webserver (1432047456691): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456691): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/login_controller.js
server:emulator-webserver (1432047456691): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/login_controller.js
server:emulator-webserver (1432047456695): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456695): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/layout_controller.js
server:emulator-webserver (1432047456695): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/layout_controller.js
server:emulator-webserver (1432047456696): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456696): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js
server:emulator-webserver (1432047456696): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js
server:emulator-webserver (1432047456697): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456697): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/login_service.js
server:emulator-webserver (1432047456698): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/login_service.js
server:emulator-webserver (1432047456703): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456703): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/layout_service.js
server:emulator-webserver (1432047456703): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/layout_service.js
server:emulator-webserver (1432047456706): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456706): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/routing_service.js
server:emulator-webserver (1432047456706): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/routing_service.js
server:emulator-webserver (1432047456709): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456709): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/cordova.js
server:emulator-webserver (1432047456711): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456711): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/xhr.js
server:emulator-webserver (1432047456712): xhr.js request fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/xhr.js
server:emulator-webserver (1432047456713): Send cordova.js from D:\xdk\components\server\emulator\resources\cordova.js
server:emulator-webserver (1432047456714): sending empty contents for missing xhr.js file
server:emulator-webserver (1432047457458): emulator-webserver: got a request for userapp.
client:emulator (1432047457458): appmobi_plus_cordova :: Emulation frame loaded
server:emulator-webserver (1432047457458): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view1.html
server:emulator-webserver (1432047457458): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view1.html
server:emulator-webserver (1432047457460): HTML file doesn't look like entire document; skipping injection
client:emulator (1432047457461): appmobi_plus_cordova :: fired appMobi.device.ready event!
client:emulator (1432047457502): appmobi_plus_cordova :: tinyHipposLoaded cleared _loading/_delayedproject
client:emulator (1432047457504): appmobi_plus_cordova :: [emulator] file watcher started
server:emulator-webserver (1432047457518): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457518): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/cordova_plugins.js
server:emulator-webserver (1432047457518): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/cordova_plugins.js
server:emulator-webserver (1432047457621): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457621): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/Acceleration.js
server:emulator-webserver (1432047457621): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/Acceleration.js
server:emulator-webserver (1432047457622): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457622): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/accelerometer.js
server:emulator-webserver (1432047457622): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/accelerometer.js
server:emulator-webserver (1432047457627): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457627): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraConstants.js
server:emulator-webserver (1432047457627): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraConstants.js
server:emulator-webserver (1432047457635): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457635): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraPopoverOptions.js
server:emulator-webserver (1432047457644): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraPopoverOptions.js
server:emulator-webserver (1432047457655): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457655): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/Camera.js
server:emulator-webserver (1432047457656): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/Camera.js
server:emulator-webserver (1432047457666): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457666): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/ios/CameraPopoverHandle.js
server:emulator-webserver (1432047457667): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/ios/CameraPopoverHandle.js
server:emulator-webserver (1432047457668): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457668): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureAudioOptions.js
server:emulator-webserver (1432047457669): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureAudioOptions.js
server:emulator-webserver (1432047457676): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457676): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureImageOptions.js
server:emulator-webserver (1432047457677): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureImageOptions.js
server:emulator-webserver (1432047457679): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457679): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureVideoOptions.js
server:emulator-webserver (1432047457680): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureVideoOptions.js
server:emulator-webserver (1432047457687): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457687): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureError.js
server:emulator-webserver (1432047457688): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureError.js
server:emulator-webserver (1432047457689): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457689): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFileData.js
server:emulator-webserver (1432047457690): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFileData.js
server:emulator-webserver (1432047457692): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457692): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFile.js
server:emulator-webserver (1432047457693): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFile.js
server:emulator-webserver (1432047457699): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457699): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/capture.js
server:emulator-webserver (1432047457700): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/capture.js
server:emulator-webserver (1432047457701): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457701): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassError.js
server:emulator-webserver (1432047457702): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassError.js
server:emulator-webserver (1432047457709): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457710): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassHeading.js
server:emulator-webserver (1432047457710): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassHeading.js
server:emulator-webserver (1432047457712): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457712): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/compass.js
server:emulator-webserver (1432047457712): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/compass.js
server:emulator-webserver (1432047457719): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457719): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/network.js
server:emulator-webserver (1432047457720): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/network.js
server:emulator-webserver (1432047457721): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457721): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/Connection.js
server:emulator-webserver (1432047457722): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/Connection.js
server:emulator-webserver (1432047457724): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457724): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/contacts.js
server:emulator-webserver (1432047457724): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/contacts.js
server:emulator-webserver (1432047457732): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457732): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/Contact.js
server:emulator-webserver (1432047457732): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/Contact.js
server:emulator-webserver (1432047457734): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457734): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactAddress.js
server:emulator-webserver (1432047457734): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactAddress.js
server:emulator-webserver (1432047457744): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457744): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactError.js
server:emulator-webserver (1432047457745): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactError.js
server:emulator-webserver (1432047457746): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457746): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactField.js
server:emulator-webserver (1432047457747): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactField.js
server:emulator-webserver (1432047457754): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457754): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFindOptions.js
server:emulator-webserver (1432047457755): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFindOptions.js
server:emulator-webserver (1432047457757): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457757): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactName.js
server:emulator-webserver (1432047457757): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactName.js
server:emulator-webserver (1432047457758): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457759): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactOrganization.js
server:emulator-webserver (1432047457759): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactOrganization.js
server:emulator-webserver (1432047457769): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457769): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFieldType.js
server:emulator-webserver (1432047457770): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFieldType.js
server:emulator-webserver (1432047457771): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457771): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/contacts.js
server:emulator-webserver (1432047457772): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/contacts.js
server:emulator-webserver (1432047457778): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457778): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/Contact.js
server:emulator-webserver (1432047457779): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/Contact.js
server:emulator-webserver (1432047457784): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457784): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device/www/device.js
server:emulator-webserver (1432047457784): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device/www/device.js
server:emulator-webserver (1432047457786): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457786): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.battery-status/www/battery.js
server:emulator-webserver (1432047457786): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.battery-status/www/battery.js
server:emulator-webserver (1432047457804): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457804): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransferError.js
server:emulator-webserver (1432047457804): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransferError.js
server:emulator-webserver (1432047457806): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457806): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransfer.js
server:emulator-webserver (1432047457806): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransfer.js
server:emulator-webserver (1432047457807): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457807): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Coordinates.js
server:emulator-webserver (1432047457808): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Coordinates.js
server:emulator-webserver (1432047457813): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457814): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/PositionError.js
server:emulator-webserver (1432047457814): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/PositionError.js
server:emulator-webserver (1432047457815): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457815): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Position.js
server:emulator-webserver (1432047457815): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Position.js
server:emulator-webserver (1432047457829): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457829): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/geolocation.js
server:emulator-webserver (1432047457829): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/geolocation.js
server:emulator-webserver (1432047457834): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457834): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/GlobalizationError.js
server:emulator-webserver (1432047457835): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/GlobalizationError.js
server:emulator-webserver (1432047457840): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457840): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/globalization.js
server:emulator-webserver (1432047457841): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/globalization.js
server:emulator-webserver (1432047457843): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457843): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.inappbrowser/www/inappbrowser.js
server:emulator-webserver (1432047457843): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.inappbrowser/www/inappbrowser.js
server:emulator-webserver (1432047457845): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457845): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/MediaError.js
server:emulator-webserver (1432047457845): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/MediaError.js
server:emulator-webserver (1432047457850): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457850): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/Media.js
server:emulator-webserver (1432047457850): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/Media.js
server:emulator-webserver (1432047457852): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457852): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.dialogs/www/notification.js
server:emulator-webserver (1432047457852): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.dialogs/www/notification.js
server:emulator-webserver (1432047457857): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457857): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.vibration/www/vibration.js
server:emulator-webserver (1432047457857): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.vibration/www/vibration.js
server:emulator-webserver (1432047457859): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457859): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.splashscreen/www/splashscreen.js
server:emulator-webserver (1432047457859): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.splashscreen/www/splashscreen.js
server:emulator-webserver (1432047457860): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457860): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.statusbar/www/statusbar.js
server:emulator-webserver (1432047457860): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.statusbar/www/statusbar.js
server:emulator-webserver (1432047457865): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457865): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryEntry.js
server:emulator-webserver (1432047457866): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryEntry.js
server:emulator-webserver (1432047457867): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457867): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryReader.js
server:emulator-webserver (1432047457868): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryReader.js
server:emulator-webserver (1432047457874): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457874): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Entry.js
server:emulator-webserver (1432047457874): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Entry.js
server:emulator-webserver (1432047457876): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457876): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/File.js
server:emulator-webserver (1432047457876): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/File.js
server:emulator-webserver (1432047457878): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457878): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileEntry.js
server:emulator-webserver (1432047457878): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileEntry.js
server:emulator-webserver (1432047457891): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457891): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileError.js
server:emulator-webserver (1432047457892): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileError.js
server:emulator-webserver (1432047457893): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457893): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileReader.js
server:emulator-webserver (1432047457894): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileReader.js
server:emulator-webserver (1432047457900): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457900): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileSystem.js
server:emulator-webserver (1432047457901): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileSystem.js
server:emulator-webserver (1432047457903): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457903): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadOptions.js
server:emulator-webserver (1432047457903): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadOptions.js
server:emulator-webserver (1432047457904): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457904): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadResult.js
server:emulator-webserver (1432047457905): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadResult.js
server:emulator-webserver (1432047457916): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457916): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileWriter.js
server:emulator-webserver (1432047457917): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileWriter.js
server:emulator-webserver (1432047457919): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457919): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Flags.js
server:emulator-webserver (1432047457919): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Flags.js
server:emulator-webserver (1432047457927): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457927): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/LocalFileSystem.js
server:emulator-webserver (1432047457927): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/LocalFileSystem.js
server:emulator-webserver (1432047457928): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457928): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Metadata.js
server:emulator-webserver (1432047457929): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Metadata.js
server:emulator-webserver (1432047457930): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457931): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ProgressEvent.js
server:emulator-webserver (1432047457931): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ProgressEvent.js
server:emulator-webserver (1432047457941): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457941): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems.js
server:emulator-webserver (1432047457942): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems.js
server:emulator-webserver (1432047457944): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457944): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/requestFileSystem.js
server:emulator-webserver (1432047457944): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/requestFileSystem.js
server:emulator-webserver (1432047457953): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457953): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/resolveLocalFileSystemURI.js
server:emulator-webserver (1432047457954): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/resolveLocalFileSystemURI.js
server:emulator-webserver (1432047457956): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457956): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ios/FileSystem.js
server:emulator-webserver (1432047457956): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ios/FileSystem.js
server:emulator-webserver (1432047457958): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457958): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems-roots.js
server:emulator-webserver (1432047457959): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems-roots.js
server:emulator-webserver (1432047457964): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457964): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystemPaths.js
server:emulator-webserver (1432047457964): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystemPaths.js
server:emulator-webserver (1432047459293): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047459293): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
server:emulator-webserver (1432047459293): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
xdk:server (1432047459340): memmrk: 40345196 58654336
server:emulator-webserver (1432047459558): emulator-webserver: got a request for userapp.
client:emulator (1432047459558): appmobi_plus_cordova :: Native back button handler was detached.
server:emulator-webserver (1432047459559): req.path = /http-services/emulator-webserver/ripple/userapp/C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map
server:emulator-webserver (1432047459559): Other file request, fullPath = C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map
server:emulator-webserver (1432047459563): Error testing path C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map; msg = ERROR: name must either start with slash or use base option
Error
xdk:client (1432047459586): memmrk: 53787484 81093376
xdk:server (1432047464340): memmrk: 40469360 58654336
xdk:client (1432047464588): memmrk: 65356596 88190976
client:emulator (1432047468301): [emulator] file change restarted emulator /D/GIT clone/mapmytrip/src/mmt_4/www/js/app.js
client:emulator (1432047468304): appmobi_plus_cordova :: Emulator restarting mmt_1
client:emulator (1432047468307): appmobi_plus_cordova :: _xdkLoad for project mmt_1
xdk:server (1432047469487): memmrk: 33537528 58654336
xdk:client (1432047470371): memmrk: 100795532 120656256
client:emulator (1432047470536): appmobi_plus_cordova :: Initialization Finished (Make it so.)
server:emulator-webserver (1432047470540): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047470540): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/index.html
server:emulator-webserver (1432047470540): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/index.html
client:emulator (1432047470537): appmobi_plus_cordova :: frame appended to document
server:emulator-webserver (1432047471715): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471715): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
server:emulator-webserver (1432047471716): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
server:emulator-webserver (1432047471718): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471718): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js
server:emulator-webserver (1432047471718): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js
server:emulator-webserver (1432047471720): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471720): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js
server:emulator-webserver (1432047471720): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js
server:emulator-webserver (1432047471721): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471721): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js
server:emulator-webserver (1432047471722): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js
server:emulator-webserver (1432047471722): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471722): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js
server:emulator-webserver (1432047471723): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js
server:emulator-webserver (1432047471739): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471739): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/login_controller.js
server:emulator-webserver (1432047471740): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/login_controller.js
server:emulator-webserver (1432047471742): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471742): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/layout_controller.js
server:emulator-webserver (1432047471742): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/layout_controller.js
server:emulator-webserver (1432047471753): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471754): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js
server:emulator-webserver (1432047471754): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js
server:emulator-webserver (1432047471758): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471758): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/login_service.js
server:emulator-webserver (1432047471758): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/login_service.js
server:emulator-webserver (1432047471762): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471762): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/layout_service.js
server:emulator-webserver (1432047471763): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/layout_service.js
server:emulator-webserver (1432047471767): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471767): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/routing_service.js
server:emulator-webserver (1432047471767): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/routing_service.js
server:emulator-webserver (1432047471771): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471771): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/cordova.js
server:emulator-webserver (1432047471772): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471772): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/xhr.js
server:emulator-webserver (1432047471772): xhr.js request fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/xhr.js
server:emulator-webserver (1432047471773): Send cordova.js from D:\xdk\components\server\emulator\resources\cordova.js
server:emulator-webserver (1432047471773): sending empty contents for missing xhr.js file
server:emulator-webserver (1432047471892): emulator-webserver: got a request for userapp.
client:emulator (1432047471892): appmobi_plus_cordova :: Emulation frame loaded
server:emulator-webserver (1432047471892): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view1.html
server:emulator-webserver (1432047471892): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view1.html
server:emulator-webserver (1432047471899): HTML file doesn't look like entire document; skipping injection
client:emulator (1432047471895): appmobi_plus_cordova :: fired appMobi.device.ready event!
server:emulator-webserver (1432047471931): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471931): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/cordova_plugins.js
server:emulator-webserver (1432047471931): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/cordova_plugins.js
client:emulator (1432047472524): appmobi_plus_cordova :: tinyHipposLoaded cleared _loading/_delayedproject
server:emulator-webserver (1432047472532): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472532): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/Acceleration.js
server:emulator-webserver (1432047472533): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/Acceleration.js
server:emulator-webserver (1432047472535): emulator-webserver: got a request for userapp.
client:emulator (1432047472525): appmobi_plus_cordova :: [emulator] file watcher started
server:emulator-webserver (1432047472535): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/accelerometer.js
server:emulator-webserver (1432047472535): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/accelerometer.js
server:emulator-webserver (1432047472539): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472539): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraConstants.js
server:emulator-webserver (1432047472539): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraConstants.js
server:emulator-webserver (1432047472544): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472544): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraPopoverOptions.js
server:emulator-webserver (1432047472544): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraPopoverOptions.js
server:emulator-webserver (1432047472545): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472545): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/Camera.js
server:emulator-webserver (1432047472545): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/Camera.js
server:emulator-webserver (1432047472551): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472552): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/ios/CameraPopoverHandle.js
server:emulator-webserver (1432047472552): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/ios/CameraPopoverHandle.js
server:emulator-webserver (1432047472554): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472554): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureAudioOptions.js
server:emulator-webserver (1432047472555): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureAudioOptions.js
server:emulator-webserver (1432047472555): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472555): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureImageOptions.js
server:emulator-webserver (1432047472556): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureImageOptions.js
server:emulator-webserver (1432047472562): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472562): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureVideoOptions.js
server:emulator-webserver (1432047472562): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureVideoOptions.js
server:emulator-webserver (1432047472563): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472563): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureError.js
server:emulator-webserver (1432047472563): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureError.js
server:emulator-webserver (1432047472568): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472568): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFileData.js
server:emulator-webserver (1432047472568): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFileData.js
server:emulator-webserver (1432047472569): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472569): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFile.js
server:emulator-webserver (1432047472570): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFile.js
server:emulator-webserver (1432047472571): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472571): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/capture.js
server:emulator-webserver (1432047472571): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/capture.js
server:emulator-webserver (1432047472577): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472577): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassError.js
server:emulator-webserver (1432047472578): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassError.js
server:emulator-webserver (1432047472579): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472580): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassHeading.js
server:emulator-webserver (1432047472580): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassHeading.js
server:emulator-webserver (1432047472585): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472585): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/compass.js
server:emulator-webserver (1432047472585): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/compass.js
server:emulator-webserver (1432047472586): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472586): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/network.js
server:emulator-webserver (1432047472587): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/network.js
server:emulator-webserver (1432047472588): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472588): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/Connection.js
server:emulator-webserver (1432047472589): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/Connection.js
server:emulator-webserver (1432047472595): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472595): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/contacts.js
server:emulator-webserver (1432047472595): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/contacts.js
server:emulator-webserver (1432047472597): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472597): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/Contact.js
server:emulator-webserver (1432047472597): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/Contact.js
server:emulator-webserver (1432047472603): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472603): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactAddress.js
server:emulator-webserver (1432047472603): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactAddress.js
server:emulator-webserver (1432047472605): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472605): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactError.js
server:emulator-webserver (1432047472605): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactError.js
server:emulator-webserver (1432047472607): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472607): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactField.js
server:emulator-webserver (1432047472607): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactField.js
server:emulator-webserver (1432047472614): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472614): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFindOptions.js
server:emulator-webserver (1432047472614): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFindOptions.js
server:emulator-webserver (1432047472615): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472615): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactName.js
server:emulator-webserver (1432047472616): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactName.js
server:emulator-webserver (1432047472619): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472619): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactOrganization.js
server:emulator-webserver (1432047472620): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactOrganization.js
server:emulator-webserver (1432047472621): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472621): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFieldType.js
server:emulator-webserver (1432047472622): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFieldType.js
server:emulator-webserver (1432047472623): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472623): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/contacts.js
server:emulator-webserver (1432047472624): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/contacts.js
server:emulator-webserver (1432047472630): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472630): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/Contact.js
server:emulator-webserver (1432047472631): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/Contact.js
server:emulator-webserver (1432047472632): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472632): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device/www/device.js
server:emulator-webserver (1432047472633): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device/www/device.js
server:emulator-webserver (1432047472638): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472638): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.battery-status/www/battery.js
server:emulator-webserver (1432047472639): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.battery-status/www/battery.js
server:emulator-webserver (1432047472640): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472640): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransferError.js
server:emulator-webserver (1432047472641): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransferError.js
server:emulator-webserver (1432047472642): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472642): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransfer.js
server:emulator-webserver (1432047472642): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransfer.js
server:emulator-webserver (1432047472647): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472647): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Coordinates.js
server:emulator-webserver (1432047472647): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Coordinates.js
server:emulator-webserver (1432047472649): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472649): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/PositionError.js
server:emulator-webserver (1432047472649): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/PositionError.js
server:emulator-webserver (1432047472655): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472655): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Position.js
server:emulator-webserver (1432047472656): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Position.js
server:emulator-webserver (1432047472657): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472657): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/geolocation.js
server:emulator-webserver (1432047472658): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/geolocation.js
server:emulator-webserver (1432047472659): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472659): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/GlobalizationError.js
server:emulator-webserver (1432047472660): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/GlobalizationError.js
server:emulator-webserver (1432047472666): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472666): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/globalization.js
server:emulator-webserver (1432047472666): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/globalization.js
server:emulator-webserver (1432047472668): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472668): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.inappbrowser/www/inappbrowser.js
server:emulator-webserver (1432047472668): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.inappbrowser/www/inappbrowser.js
server:emulator-webserver (1432047472672): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472672): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/MediaError.js
server:emulator-webserver (1432047472672): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/MediaError.js
server:emulator-webserver (1432047472674): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472674): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/Media.js
server:emulator-webserver (1432047472675): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/Media.js
server:emulator-webserver (1432047472677): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472677): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.dialogs/www/notification.js
server:emulator-webserver (1432047472677): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.dialogs/www/notification.js
server:emulator-webserver (1432047472684): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472684): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.vibration/www/vibration.js
server:emulator-webserver (1432047472685): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.vibration/www/vibration.js
server:emulator-webserver (1432047472686): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472686): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.splashscreen/www/splashscreen.js
server:emulator-webserver (1432047472687): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.splashscreen/www/splashscreen.js
server:emulator-webserver (1432047472691): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472691): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.statusbar/www/statusbar.js
server:emulator-webserver (1432047472692): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.statusbar/www/statusbar.js
server:emulator-webserver (1432047472692): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472693): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryEntry.js
server:emulator-webserver (1432047472693): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryEntry.js
server:emulator-webserver (1432047472697): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472697): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryReader.js
server:emulator-webserver (1432047472697): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryReader.js
server:emulator-webserver (1432047472698): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472698): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Entry.js
server:emulator-webserver (1432047472699): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Entry.js
server:emulator-webserver (1432047472702): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472702): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/File.js
server:emulator-webserver (1432047472702): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/File.js
server:emulator-webserver (1432047472705): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472706): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileEntry.js
server:emulator-webserver (1432047472706): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileEntry.js
server:emulator-webserver (1432047472707): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472707): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileError.js
server:emulator-webserver (1432047472708): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileError.js
server:emulator-webserver (1432047472712): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472712): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileReader.js
server:emulator-webserver (1432047472713): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileReader.js
server:emulator-webserver (1432047472714): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472714): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileSystem.js
server:emulator-webserver (1432047472714): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileSystem.js
server:emulator-webserver (1432047472715): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472715): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadOptions.js
server:emulator-webserver (1432047472715): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadOptions.js
server:emulator-webserver (1432047472720): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472720): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadResult.js
server:emulator-webserver (1432047472720): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadResult.js
server:emulator-webserver (1432047472722): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472722): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileWriter.js
server:emulator-webserver (1432047472722): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileWriter.js
server:emulator-webserver (1432047472725): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472725): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Flags.js
server:emulator-webserver (1432047472726): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Flags.js
server:emulator-webserver (1432047472726): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472727): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/LocalFileSystem.js
server:emulator-webserver (1432047472727): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/LocalFileSystem.js
server:emulator-webserver (1432047472731): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472731): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Metadata.js
server:emulator-webserver (1432047472731): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Metadata.js
server:emulator-webserver (1432047472732): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472732): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ProgressEvent.js
server:emulator-webserver (1432047472733): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ProgressEvent.js
server:emulator-webserver (1432047472735): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472736): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems.js
server:emulator-webserver (1432047472736): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems.js
server:emulator-webserver (1432047472739): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472739): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/requestFileSystem.js
server:emulator-webserver (1432047472740): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/requestFileSystem.js
server:emulator-webserver (1432047472741): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472741): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/resolveLocalFileSystemURI.js
server:emulator-webserver (1432047472741): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/resolveLocalFileSystemURI.js
server:emulator-webserver (1432047472747): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472747): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ios/FileSystem.js
server:emulator-webserver (1432047472747): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ios/FileSystem.js
server:emulator-webserver (1432047472749): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472749): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems-roots.js
server:emulator-webserver (1432047472749): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems-roots.js
server:emulator-webserver (1432047472757): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472757): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystemPaths.js
server:emulator-webserver (1432047472757): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystemPaths.js
server:emulator-webserver (1432047473615): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047473616): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
server:emulator-webserver (1432047473616): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
server:emulator-webserver (1432047474072): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047474072): req.path = /http-services/emulator-webserver/ripple/userapp/C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map
server:emulator-webserver (1432047474072): Other file request, fullPath = C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map
server:emulator-webserver (1432047474074): Error testing path C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map; msg = ERROR: name must either start with slash or use base option
Error
at ComponentError (D:\xdk\core-modules\public\component-error.js:17:1122)
at new ServiceError (D:\xdk\core-modules\public\service-error.js:17:317)
at _ensureStartsWithSlashOrUsesBaseOption (D:\xdk\components\server\userfs\filter\sanitize.js:17:800)
at D:\xdk\components\server\userfs\filter\sanitize.js:17:1227
at Array.forEach (native)
at Function._.each._.forEach (D:\xdk\node_modules\underscore\underscore.js:79:11)
at D:\xdk\components\server\userfs\filter\sanitize.js:17:1120
at beforeFilter (D:\xdk\components\server\userfs\filter\sanitize.js:17:1082)
client:emulator (1432047474146): appmobi_plus_cordova :: Native back button handler was detached.
xdk:server (1432047474488): memmrk: 36824680 58654336
xdk:client (1432047475373): memmrk: 65713188 89194496
xdk:server (1432047479488): memmrk: 36832644 58654336
xdk:client (1432047480373): memmrk: 66222816 89194496
xdk:server (1432047484489): memmrk: 26198684 58654336
xdk:client (1432047485373): memmrk: 66555564 89194496
xdk:server (1432047489489): memmrk: 25984088 36855936
xdk:client (1432047490374): memmrk: 67119908 89194496
xdk:server (1432047494491): memmrk: 26018000 36855936
xdk:client (1432047495376): memmrk: 71051132 92229376
xdk:server (1432047499492): memmrk: 25716176 34824576
xdk:client (1432047500377): memmrk: 72469168 92229376
xdk:server (1432047504495): memmrk: 25723216 34824576
xdk:client (1432047505381): memmrk: 72796640 92229376
xdk:server (1432047509496): memmrk: 25045048 32805376
xdk:client (1432047510383): memmrk: 65415872 92229376
xdk:server (1432047514497): memmrk: 25010968 33853952
xdk:client (1432047515383): memmrk: 65743364 92229376
xdk:server (1432047519497): memmrk: 24411752 33853952
xdk:client (1432047520383): memmrk: 66716568 92229376
xdk:server (1432047524498): memmrk: 24418448 33853952
xdk:client (1432047525383): memmrk: 67792732 92229376
xdk:server (1432047529499): memmrk: 24424812 33853952
xdk:client (1432047530385): memmrk: 68643964 92229376
xdk:server (1432047534499): memmrk: 24431176 33853952
xdk:client (1432047535386): memmrk: 69239412 92229376
xdk:server (1432047539499): memmrk: 25380300 33853952
xdk:client (1432047540386): memmrk: 67093292 94248576
xdk:server (1432047544500): memmrk: 25386664 33853952
xdk:client (1432047545387): memmrk: 67681752 94248576
xdk:server (1432047549501): memmrk: 25393028 33853952
xdk:client (1432047550387): memmrk: 68175312 94248576
xdk:server (1432047554501): memmrk: 25399392 33853952
xdk:client (1432047555388): memmrk: 68505920 94248576
xdk:server (1432047559501): memmrk: 25405756 33853952
xdk:client (1432047560389): memmrk: 68999452 94248576
xdk:server (1432047564504): memmrk: 25412120 33853952
xdk:client (1432047565392): memmrk: 69330076 94248576
xdk:server (1432047569504): memmrk: 25418484 33853952
xdk:client (1432047570393): memmrk: 69906952 94248576
xdk:server (1432047574505): memmrk: 25424848 33853952
xdk:client (1432047575393): memmrk: 70385996 94248576
xdk:server (1432047579506): memmrk: 25431212 33853952
xdk:client (1432047580395): memmrk: 70988068 94248576
xdk:server (1432047584506): memmrk: 25446728 33853952
xdk:client (1432047585395): memmrk: 71479688 94248576
xdk:server (1432047589506): memmrk: 25452168 33853952
xdk:client (1432047590396): memmrk: 72107260 94248576
xdk:server (1432047594507): memmrk: 25458532 33853952
xdk:client (1432047595396): memmrk: 72636772 94248576
xdk:server (1432047599508): memmrk: 25464896 33853952
xdk:client (1432047600397): memmrk: 73131112 94248576
xdk:server (1432047604508): memmrk: 25471260 33853952
xdk:client (1432047605397): memmrk: 73462504 94248576
xdk:server (1432047609508): memmrk: 25477624 33853952
xdk:client (1432047610398): memmrk: 73873948 94248576
xdk:server (1432047614510): memmrk: 25483988 33853952
xdk:client (1432047615399): memmrk: 74366460 94248576
xdk:server (1432047619510): memmrk: 25490352 33853952
xdk:client (1432047620400): memmrk: 74773976 94248576
xdk:server (1432047624513): memmrk: 25496716 33853952
xdk:client (1432047625403): memmrk: 69251080 94248576
xdk:server (1432047629513): memmrk: 25503080 33853952
xdk:client (1432047630403): memmrk: 69741412 95264256
xdk:server (1432047634515): memmrk: 25509444 33853952
xdk:client (1432047635405): memmrk: 70069636 95264256
xdk:server (1432047639515): memmrk: 25515808 33853952
xdk:client (1432047640406): memmrk: 70553400 95264256
xdk:server (1432047644515): memmrk: 25522172 33853952
xdk:client (1432047645406): memmrk: 71054600 95264256
xdk:server (1432047649516): memmrk: 25528536 33853952
xdk:client (1432047650407): memmrk: 71492588 95264256
xdk:server (1432047654517): memmrk: 25534924 33853952
xdk:client (1432047655408): memmrk: 71902876 95264256
xdk:server (1432047659517): memmrk: 25540364 33853952
xdk:client (1432047660408): memmrk: 72310400 95264256
xdk:server (1432047664517): memmrk: 25546728 33853952
xdk:client (1432047665409): memmrk: 72726444 95264256
xdk:server (1432047669518): memmrk: 25553092 33853952
xdk:client (1432047670410): memmrk: 73216852 95264256
xdk:server (1432047674518): memmrk: 25559456 33853952
xdk:client (1432047675411): memmrk: 73561012 95264256
xdk:server (1432047679519): memmrk: 25565820 33853952
xdk:client (1432047680411): memmrk: 73968528 95264256
xdk:server (1432047684522): memmrk: 25572184 33853952
xdk:client (1432047685415): memmrk: 74378816 95264256
xdk:server (1432047689522): memmrk: 25578548 33853952
xdk:client (1432047690415): memmrk: 74786332 95264256
xdk:server (1432047694522): memmrk: 25584912 33853952
xdk:client (1432047695416): memmrk: 52716464 95264256
xdk:server (1432047699523): memmrk: 25591276 33853952
xdk:client (1432047700417): memmrk: 53146504 95264256
xdk:server (1432047704524): memmrk: 25597640 33853952
xdk:client (1432047705418): memmrk: 53556792 95264256
xdk:server (1432047709524): memmrk: 25604004 33853952
xdk:client (1432047710427): memmrk: 54134384 95264256
xdk:server (1432047714524): memmrk: 25610368 33853952
xdk:client (1432047715427): memmrk: 54548772 95264256
xdk:server (1432047719526): memmrk: 25616732 33853952
xdk:client (1432047720428): memmrk: 54969056 95264256
xdk:server (1432047724526): memmrk: 25623096 33853952
xdk:client (1432047725429): memmrk: 55383392 95264256
xdk:server (1432047729526): memmrk: 25629460 33853952
xdk:client (1432047730429): memmrk: 55795488 95264256
xdk:server (1432047734526): memmrk: 25634900 33853952
xdk:client (1432047735430): memmrk: 56225564 95264256
xdk:server (1432047739528): memmrk: 25641264 33853952
xdk:client (1432047740432): memmrk: 56848504 95264256
xdk:server (1432047744531): memmrk: 25647628 33853952
xdk:client (1432047745436): memmrk: 57544012 95264256
xdk:server (1432047749531): memmrk: 25653992 33853952
xdk:client (1432047750446): memmrk: 57955692 95264256
xdk:server (1432047754532): memmrk: 25660356 33853952
xdk:client (1432047755447): memmrk: 58370148 95264256
xdk:server (1432047759532): memmrk: 25666720 33853952
xdk:client (1432047760453): memmrk: 58801472 95264256
xdk:server (1432047764533): memmrk: 25673084 33853952
xdk:client (1432047765453): memmrk: 59238492 95264256
xdk:server (1432047769533): memmrk: 25679448 33853952
xdk:client (1432047770458): memmrk: 59649988 95264256
xdk:server (1432047774534): memmrk: 25685812 33853952
xdk:client (1432047775459): memmrk: 60064196 95264256
xdk:server (1432047779534): memmrk: 25740088 33853952
xdk:client (1432047780464): memmrk: 60507128 95264256
xdk:server (1432047784535): memmrk: 25746452 33853952
xdk:client (1432047785465): memmrk: 60921336 95264256
xdk:server (1432047789536): memmrk: 25752816 33853952
xdk:client (1432047790479): memmrk: 61332772 95264256
xdk:server (1432047794536): memmrk: 25759180 33853952
xdk:client (1432047795480): memmrk: 55179264 95264256
xdk:server (1432047799536): memmrk: 25781436 33853952
xdk:client (1432047800480): memmrk: 55676296 95264256
xdk:server (1432047804539): memmrk: 25786748 33853952
xdk:client (1432047805494): memmrk: 57048332 95264256
xdk:server (1432047809541): memmrk: 25792952 33853952
xdk:client (1432047810512): memmrk: 57964496 95264256
xdk:server (1432047814541): memmrk: 25799156 33853952
xdk:client (1432047815513): memmrk: 58955560 95264256
xdk:server (1432047819541): memmrk: 25805360 33853952
xdk:client (1432047820513): memmrk: 59436700 95264256
xdk:server (1432047824542): memmrk: 25811548 33853952
xdk:client (1432047825515): memmrk: 60233196 95264256
xdk:server (1432047829550): memmrk: 25817752 33853952
xdk:client (1432047830516): memmrk: 60636264 95264256
xdk:server (1432047834542): memmrk: 25013624 33853952
xdk:client (1432047835516): memmrk: 61264720 95264256
xdk:server (1432047839543): memmrk: 25029744 33853952
xdk:client (1432047840517): memmrk: 61637364 95264256
xdk:server (1432047844544): memmrk: 25035964 33853952
xdk:client (1432047845517): memmrk: 62291952 95264256
xdk:server (1432047849544): memmrk: 25045180 33853952
xdk:client (1432047850518): memmrk: 56788092 95264256
xdk:server (1432047854544): memmrk: 25052188 33853952
xdk:client (1432047855518): memmrk: 57290136 95264256
xdk:server (1432047859545): memmrk: 25058408 33853952
xdk:client (1432047860520): memmrk: 57630784 95264256
xdk:server (1432047864548): memmrk: 25064628 33853952
xdk:client (1432047865523): memmrk: 58210976 95264256
xdk:server (1432047869548): memmrk: 25070848 33853952
xdk:client (1432047870523): memmrk: 58542448 95264256
xdk:server (1432047874549): memmrk: 25077068 33853952
xdk:client (1432047875525): memmrk: 59036780 95264256
xdk:server (1432047879550): memmrk: 25082396 33853952
xdk:client (1432047880525): memmrk: 59369068 95264256
xdk:server (1432047884550): memmrk: 25088616 33853952
xdk:client (1432047885526): memmrk: 59956316 96267776
xdk:server (1432047889551): memmrk: 25094836 33853952
xdk:client (1432047890526): memmrk: 60323944 96267776
xdk:server (1432047894552): memmrk: 25118792 33853952
xdk:client (1432047895527): memmrk: 60818816 96267776
xdk:server (1432047899552): memmrk: 25125012 33853952
xdk:client (1432047900528): memmrk: 61152016 96267776
xdk:server (1432047904552): memmrk: 25131232 33853952
xdk:client (1432047905529): memmrk: 61646268 96267776
xdk:server (1432047909553): memmrk: 25137452 33853952
xdk:client (1432047910530): memmrk: 62000612 96267776
xdk:server (1432047914554): memmrk: 25143672 33853952
xdk:client (1432047915530): memmrk: 62503688 96267776
xdk:server (1432047919554): memmrk: 25149892 33853952
xdk:client (1432047920530): memmrk: 62835288 96267776
xdk:server (1432047924557): memmrk: 25156112 33853952
xdk:client (1432047925533): memmrk: 63329740 96267776
xdk:server (1432047929558): memmrk: 25162332 33853952
xdk:client (1432047930535): memmrk: 63664096 96267776
xdk:server (1432047934559): memmrk: 25168552 33853952
xdk:client (1432047935535): memmrk: 64165152 96267776
xdk:server (1432047939559): memmrk: 25174772 33853952
xdk:client (1432047940536): memmrk: 58487060 96267776
xdk:server (1432047944559): memmrk: 25180992 33853952
xdk:client (1432047945538): memmrk: 59428072 96267776
xdk:server (1432047949561): memmrk: 25187196 33853952
xdk:client (1432047950539): memmrk: 59795568 96267776
xdk:server (1432047954561): memmrk: 25192524 33853952
xdk:client (1432047955539): memmrk: 60261356 96267776
xdk:server (1432047959561): memmrk: 25198744 33853952
xdk:client (1432047960539): memmrk: 60571048 96267776
xdk:server (1432047964562): memmrk: 25204964 33853952
xdk:client (1432047965541): memmrk: 61037380 96267776
xdk:server (1432047969562): memmrk: 25211184 33853952
xdk:client (1432047970541): memmrk: 61339440 96267776
xdk:server (1432047974563): memmrk: 25219080 33853952
xdk:client (1432047975547): memmrk: 61798712 96267776
xdk:server (1432047979563): memmrk: 25225300 33853952
xdk:client (1432047980548): memmrk: 52176944 92241536
xdk:server (1432047984567): memmrk: 25231520 33853952
xdk:client (1432047985550): memmrk: 52686096 93245056
xdk:server (1432047989567): memmrk: 25237740 33853952
xdk:client (1432047990551): memmrk: 52976584 93245056
xdk:server (1432047994567): memmrk: 25243960 33853952
xdk:client (1432047995552): memmrk: 50294800 73465856
xdk:server (1432047999568): memmrk: 25250180 33853952
xdk:client (1432048000554): memmrk: 50644964 73465856
xdk:server (1432048004569): memmrk: 25256400 33853952
xdk:client (1432048005554): memmrk: 51080252 73465856
xdk:server (1432048009569): memmrk: 25262620 33853952
xdk:client (1432048010554): memmrk: 50584048 76611584
xdk:server (1432048014569): memmrk: 25268840 33853952
xdk:client (1432048015556): memmrk: 51011960 76611584
xdk:server (1432048019570): memmrk: 25275060 33853952
xdk:client (1432048020556): memmrk: 49406176 75608064
xdk:server (1432048024571): memmrk: 25280388 33853952
xdk:client (1432048025556): memmrk: 50000096 75608064
xdk:server (1432048029571): memmrk: 25286608 33853952
xdk:client (1432048030556): memmrk: 50278328 75608064
xdk:server (1432048034572): memmrk: 25292828 33853952
xdk:client (1432048035558): memmrk: 50734472 75608064
xdk:server (1432048039573): memmrk: 25299048 33853952
xdk:client (1432048040558): memmrk: 49591432 72462336
xdk:server (1432048044576): memmrk: 25305268 33853952
xdk:client (1432048045562): memmrk: 50069852 73465856
xdk:server (1432048049576): memmrk: 25320748 33853952
xdk:client (1432048050567): memmrk: 50347980 73465856
xdk:server (1432048054578): memmrk: 25328292 33853952
xdk:client (1432048055567): memmrk: 50083740 74514432
xdk:server (1432048059578): memmrk: 25336192 33853952
xdk:client (1432048060567): memmrk: 49599888 73510912
xdk:server (1432048064578): memmrk: 25343232 33853952
xdk:client (1432048065568): memmrk: 50056920 73510912
xdk:server (1432048069580): memmrk: 25350236 33853952
xdk:client (1432048070569): memmrk: 50360764 73510912
xdk:server (1432048074580): memmrk: 25356432 33853952
xdk:client (1432048075569): memmrk: 50004508 73510912
xdk:server (1432048079580): memmrk: 25362628 33853952
xdk:client (1432048080569): memmrk: 49869552 73510912
xdk:server (1432048084580): memmrk: 25368824 33853952
xdk:client (1432048085571): memmrk: 49767564 66401152
xdk:server (1432048089581): memmrk: 25375020 33853952
xdk:client (1432048090572): memmrk: 47611000 66401152
xdk:server (1432048094581): memmrk: 25381216 33853952
xdk:client (1432048095571): memmrk: 48137940 66401152
xdk:server (1432048099582): memmrk: 25386520 33853952
xdk:client (1432048100572): memmrk: 48424048 66401152
xdk:server (1432048104585): memmrk: 25392716 33853952
xdk:client (1432048105575): memmrk: 48041716 66401152
xdk:server (1432048109585): memmrk: 25398912 33853952
xdk:client (1432048110576): memmrk: 48323540 66401152
xdk:server (1432048114585): memmrk: 25405108 33853952
xdk:client (1432048115577): memmrk: 48729312 66401152
xdk:server (1432048119586): memmrk: 25411304 33853952
xdk:client (1432048120578): memmrk: 48370168 66401152
xdk:server (1432048124587): memmrk: 25417500 33853952
xdk:client (1432048125579): memmrk: 49122444 66401152
xdk:server (1432048129587): memmrk: 25423696 33853952
xdk:client (1432048130579): memmrk: 48954312 68498304
xdk:server (1432048134588): memmrk: 25429892 33853952
xdk:client (1432048135579): memmrk: 49790604 69501824
xdk:server (1432048139589): memmrk: 25436088 33853952
xdk:client (1432048140581): memmrk: 50136340 69501824
xdk:server (1432048144589): memmrk: 25442284 33853952
xdk:client (1432048145583): memmrk: 50811484 69501824
Node Webkit Error log:
[14592:0519/165423:INFO:CONSOLE(17)] ""xdk:client (1432047263851): Error SyntaxError: Unexpected token \uFEFF loading components\\client\\app\\locale\\ru\\text-content.json"", source: D:\xdk\core-modules\private\logger.js (17)
[14592:0519/165423:INFO:CONSOLE(17)] ""xdk:client (1432047263883): Error SyntaxError: Unexpected token \uFEFF loading components\\client\\profiling\\locale\\ru\\text-content.json"", source: D:\xdk\core-modules\private\logger.js (17)
[14592:0519/165424:INFO:CONSOLE(989)] "" Unhandled rejection reasons (should be empty):" ["(no stack) [object Object]"]", source: file:///D:/xdk/node_modules/q/q.js (989)
[14592:0519/165429:INFO:CONSOLE(224)] ""NW proxy string: DIRECT"", source: /brackets.js (224)
[14592:0519/165429:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n at new jQuery.fn.init (/brackets.js:455:36)\n at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/camden.jshint/main.js:174:9\n at _callHandler (/utils/AppInit.js:94:13)\n at Object._dispatchReady (/utils/AppInit.js:114:13)\n at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[14592:0519/165429:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n at new jQuery.fn.init (/brackets.js:455:36)\n at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/camden.jshint/main.js:183:9\n at _callHandler (/utils/AppInit.js:94:13)\n at Object._dispatchReady (/utils/AppInit.js:114:13)\n at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[14592:0519/165429:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n at new jQuery.fn.init (/brackets.js:455:36)\n at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/intelxdk.xlint/main.js:366:9\n at _callHandler (/utils/AppInit.js:94:13)\n at Object._dispatchReady (/utils/AppInit.js:114:13)\n at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[14592:0519/165429:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n at new jQuery.fn.init (/brackets.js:455:36)\n at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/intelxdk.xlint/main.js:375:9\n at _callHandler (/utils/AppInit.js:94:13)\n at Object._dispatchReady (/utils/AppInit.js:114:13)\n at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[14592:0519/165430:INFO:CONSOLE(989)] "" Unhandled rejection reasons (should be empty):" ["(no stack) ERROR: no user is logged in\nError\n at new ComponentError (D:\\xdk\\core-modules\\public\\component-error.js:17:1122)\n at makeError (file:///D:/xdk/components/client/backend-service-utils/backend-service-utils.js:17:187)\n at file:///D:/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1258\n at _fulfilled (D:\\xdk\\node_modules\\q\\q.js:797:54)\n at self.promiseDispatch.done (D:\\xdk\\node_modules\\q\\q.js:826:30)\n at Promise.promise.promiseDispatch (D:\\xdk\\node_modules\\q\\q.js:759:13)\n at D:\\xdk\\node_modules\\q\\q.js:573:44\n at flush (D:\\xdk\\node_modules\\q\\q.js:108:17)\n at process._tickCallback (node.js:393:11)"]", source: D:\xdk\node_modules\q\q.js (989)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.device-motion"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.camera"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.media-capture"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.device-orientation"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.network-information"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.contacts"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.device"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.battery-status"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.file"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.file-transfer"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.geolocation"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.globalization"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.inappbrowser"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.media"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.dialogs"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.vibration"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.splashscreen"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.statusbar"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.device-motion"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.camera"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.media-capture"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.device-orientation"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.network-information"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.contacts"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.device"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.battery-status"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.file"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.file-transfer"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.geolocation"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.globalization"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.inappbrowser"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.media"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.dialogs"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.vibration"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.splashscreen"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.statusbar"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165443:WARNING:backend_impl.cc(1785)] Destroying invalid entry.
[14592:0519/165723:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[14592:0519/165723:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[14592:0519/165723:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[14592:0519/165723:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[14592:0519/165723:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[14592:0519/165724:INFO:CONSOLE(10)] ""RRROUTING service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (10)
[14592:0519/165724:INFO:CONSOLE(21)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (21)
[14592:0519/165731:INFO:CONSOLE(989)] "" Unhandled rejection reasons (should be empty):" ["(no stack) ERROR: name must either start with slash or use base option\nError\n at ComponentError (D:\\xdk\\core-modules\\public\\component-error.js:17:1122)\n at new ServiceError (D:\\xdk\\core-modules\\public\\service-error.js:17:317)\n at _ensureStartsWithSlashOrUsesBaseOption (D:\\xdk\\components\\server\\userfs\\filter\\sanitize.js:17:800)\n at D:\\xdk\\components\\server\\userfs\\filter\\sanitize.js:17:1227\n at Array.forEach (native)\n at Function._.each._.forEach (D:\\xdk\\node_modules\\underscore\\underscore.js:79:11)\n at D:\\xdk\\components\\server\\userfs\\filter\\sanitize.js:17:1120\n at Array.forEach (native)\n at Function._.each._.forEach (D:\\xdk\\node_modules\\underscore\\underscore.js:79:11)\n at beforeFilter (D:\\xdk\\components\\server\\userfs\\filter\\sanitize.js:17:1082)"]", source: D:\xdk\node_modules\q\q.js (989)
[14592:0519/165737:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[14592:0519/165737:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[14592:0519/165737:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[14592:0519/165737:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[14592:0519/165737:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[14592:0519/165739:INFO:CONSOLE(10)] ""RRROUTING service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (10)
[14592:0519/165739:INFO:CONSOLE(21)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (21)
[14592:0519/165751:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[14592:0519/165751:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[14592:0519/165752:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[14592:0519/165752:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[14592:0519/165752:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[14592:0519/165754:INFO:CONSOLE(20)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (20)
[14592:0519/170745:ERROR:dns_config_service_win.cc(739)] DNS config watch failed.
XDK exit code & signal: 3221225477, null
Crash minidump not found in XDK data folder. Falling back to TEMP...
Crash Minidump File: C:\Users\ccantagrel\AppData\Local\Temp\c2b717a5-3652-4bab-8ca2-356abb6b19f9.dmp Tue May 19 2015 17:09:06 GMT+0200 (Romance Daylight Time)
Size in bytes: 0
NW Crash Detected.
If someone have an issue, it's very important.
Hello, up
No one ?
When these crash reports were submitted we received them and opened a ticket. I found the ticket and it is being worked, but I don't have a progress update yet. It's not yet clear to me exactly what the problem is.
Your project was created with the Ionic command line tool, correct?
Would it be possible for you to .zip and post your entire project directory?
My project was not created with the ionic command line tool.
I just created my project with INTEL XDK version 1826, and I created a ionic project directly.
Yesterday intel xdk crash all 15min all the day, and today 0 crash. So I will work all the weekend, and i will post my .zip monday.
