Software Archive
Read-only legacy content
intel XDK 1826
Cantagrel_C_
I use intel XDK version 1826 for the development of my project in ionic/angularjs/cordova. But every 15min/20min intel XDK crash.
I ask you if anyone have an issue ?
Best regards
Rakshith_K_Intel
There is an updated version 1912 available, can u try that?
https://software.intel.com/en-us/html5/tools
PaulF_IntelCorp
We fixed a lot of crash issues with the 1912 release. Please try that release. You should be getting a notification to upgrade, if you are not seeing that notification, you can download 1912 from the main site at http://xdk.intel.com.
Cantagrel_C_
Thanks for your comment but I already started my application on 1826 and i saw the recent version dont use the same library or not in the same repertory. So if I use a recent version I need to restart all my declaration of library or not ?
PaulF_IntelCorp
I'm not sure what you mean by "does not use the same library or repertory."
Your project does not change when you update to 1912, other than some project settings stored in the <project-name>.xdk file that is in the root of your project. Your source files do not change.
Any JavaScript libraries that you reference stay the same, assuming you are storing those JS files in your project and including them as part of your build. The newer version of the XDK will recommend that you use the 4.1.2 build system, but you can set it to use 3.5 if you wish to continue to use that build. The build system is cloud-based, so it is not linked directly to the XDK, so whether you are using 1826 or 1912 (now 1995, as of yesterday) you are using the same build system.
The main difference between each version of the XDK is what versions of the plugins are considered the "default" versions (which you can override), which features are present and what bugs have been fixed in the XDK. In all cases you are building a Cordova app, where the XDK build in the cloud is using a standard Cordova CLI to perform the build.
Cantagrel_C_
Thanks for your answer. I had download version 1912, but it's the same issue with crash ! Every 15 / 20min intel XDK crash ! And today i have download version 1995, but when I change project and I want emulate the current project, the emulator works only for the first project opened. Any issue ? And I have just 1 crash for the moment.
Hard to works with all problems, but if you have any suggestions, tell me.
Best regards.
Cantagrel_C_
After 1 day works with intel XDK 1995, I have 3 crash.
PaulF_IntelCorp
Can you provide more details?
- What are you doing when the XDK crashes? Using App Designer, using the Emulate tab, etc.
- Are you submitting the crash reports? Do you get a crash report?
- What kind of system are you using? Windows, Mac, etc. If Windows, are you using Windows XP? The XDK does not run on XP.
Cantagrel_C_
Every time I work normally, I didnt make a special thing when XDK crash. I use a ionic framework. I use Windows 7 Entreprise SP1 64bits.
I upload all crash reports.
This is one log:
xdk:client (1431933334982): memlim: 767557632
xdk:client (1431933334984): Setting NW crash dump to: C:\Users\ccantagrel\AppData\Local\XDK
xdk:client (1431933335122): Intel XDK: 1995
xdk:client (1431933335122): Platform: win32-ia32 (6.1.7601)
xdk:client (1431933335129): Error SyntaxError: Unexpected token loading components\client\app\locale\ru\text-content.json
xdk:client (1431933335159): Error SyntaxError: Unexpected token loading components\client\profiling\locale\ru\text-content.json
xdk:client (1431933335227): Starting client process initialization
xdk:client (1431933335243): NW Cache is up-to-date.
xdk:client (1431933343803): Component "client:iosdb" finished start()
xdk:client (1431933343803): Component "client:device-discovery" calling start()
xdk:client (1431933343805): Component "client:device-discovery" finished start()
xdk:client (1431933343805): Component "client:test-local-server" calling start()
xdk:client (1431933343806): Component "client:test-local-server" finished start()
xdk:client (1431933343806): Component "client:quick-tour" calling start()
xdk:client (1431933343806): Component "client:quick-tour" finished start()
xdk:client (1431933343806): Component "client:hot-keys" calling start()
xdk:client (1431933343807): Component "client:hot-keys" finished start()
xdk:client (1431933343807): Component "client:persistance" calling start()
xdk:client (1431933343808): Component "client:persistance" finished start()
xdk:client (1431933343808): Component "client:file-watcher" calling start()
xdk:client (1431933343808): Component "client:file-watcher" finished start()
xdk:client (1431933343808): Component "client:cordova" calling start()
xdk:client (1431933343810): Component "client:cordova" finished start()
xdk:client (1431933343810): Component "client:external-editors-runner" calling start()
xdk:client (1431933343812): Component "client:external-editors-runner" finished start()
xdk:client (1431933343814): Intel XDK is initialized now
client:navbar (1431933344155): pollForUpdates called
uib-client (1431933344242): gradeHTMLFile 2 /D/GIT clone/mapmytrip/src/mmt_1/www/templates/view2.html
xdk:client (1431933344986): memmrk:    39982580    71854976
client:navbar (1431933344991): polling up-to-date
xdk:server (1431933345568): memmrk:    30363768    78943616
xdk:client (1431933349987): memmrk:    50303152    91075712
client:emulator (1431933350425): Device Emulator :: Environment Warming Up (Tea. Earl Gray. Hot.)
xdk:server (1431933350568): memmrk:    44880740    85464448
client:emulator (1431933350599): appmobi_plus_cordova :: Emulator changing to project mmt_1
client:emulator (1431933350605): appmobi_plus_cordova :: _xdkLoad for project mmt_1
client:emulator (1431933350606): appmobi_plus_cordova :: Emulator changing to project mmt_1
client:emulator (1431933351273): appmobi_plus_cordova :: Initialization Finished (Make it so.)
server:emulator-webserver (1431933351531): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystemPaths.js
server:emulator-webserver (1431933351531): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystemPaths.js
client:emulator (1431933351544): appmobi_plus_cordova :: Native back button handler was detached.
xdk:client (1431933354990): memmrk:    52063584    88581248
xdk:server (1431933355570): memmrk:    56123140    87483648
xdk:server (1431933490617): memmrk:    24208084    33853952
xdk:client (1431933495042): memmrk:    46557864    60331392
xdk:server (1431933495618): memmrk:    24214424    33853952
client:emulator (1431933498989): Device Emulator :: Environment Warming Up (Tea. Earl Gray. Hot.)
client:emulator (1431933499133): appmobi_plus_cordova :: Emulator changing to project mmt_1
client:emulator (1431933499139): appmobi_plus_cordova :: _xdkLoad for project mmt_1
client:emulator (1431933499141): appmobi_plus_cordova :: Emulator changing to project mmt_1
client:emulator (1431933499370): appmobi_plus_cordova :: Initialization Finished (Make it so.)
server:emulator-webserver (1431933499373): emulator-webserver: got a request for userapp.
server:emulator-webserver (1431933499373): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/index.html
server:emulator-webserver (1431933499373): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-...
server:emulator-webserver (1431933508994): req.path = /http-services/emulator-webserver/ripple/userapp/C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map
server:emulator-webserver (1431933508995): Other file request, fullPath = C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map
server:emulator-webserver (1431933508999): Error testing path C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map; msg = ERROR: name must either start with slash or use base option
Error
    at ComponentError (D:\xdk\core-modules\public\component-error.js:17:1122)
    at new ServiceError (D:\xdk\core-modules\public\service-error.js:17:317)
    at _ensureStartsWithSlashOrUsesBaseOption (D:\xdk\components\server\userfs\filter\sanitize.js:17:800)
    at D:\xdk\components\server\userfs\filter\sanitize.js:17:1227
    at Array.forEach (native)
    at Function._.each._.forEach (D:\xdk\node_modules\underscore\underscore.js:79:11)
    at D:\xdk\components\server\userfs\filter\sanitize.js:17:1120
    at beforeFilter (D:\xdk\components\server\userfs\filter\sanitize.js:17:1082)
xdk:client (1431933510045): memmrk:    53552912    79074176
xdk:server (1431933510621): memmrk:    28186312    36954624
xdk:client (1431933515058): memmrk:    54059456    79074176
xdk:server (1431933515633): memmrk:    25558992    36954624
server:emulator-webserver (1431933519538): emulator-webserver: got a request for userapp.
server:emulator-webserver (1431933519538): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view2.html
server:emulator-webserver (1431933519538): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view2.html
server:emulator-webserver (1431933519542): HTML file doesn't look like entire document; skipping injection
xdk:client (1431933520058): memmrk:    55802088    80077696
xdk:server (1431933520633): memmrk:    25329920    33808896
xdk:client (1431933525058): memmrk:    56164272    80077696
xdk:server (1431933525634): memmrk:    25345456    33808896
server:emulator-webserver (1431933525858): emulator-webserver: got a request for userapp.
server:emulator-webserver (1431933525858): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view3.html
server:emulator-webserver (1431933525858): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view3.html
server:emulator-webserver (1431933525872): HTML file doesn't look like entire document; skipping injection
xdk:client (1431933530060): memmrk:    56978560    80077696
xdk:server (1431934515890): memmrk:    25815776    33853952
xdk:client (1431934520483): memmrk:    62314512    87138816
xdk:server (1431934520890): memmrk:    25822016    33853952
client:emulator (1431934524490): [emulator] file change restarted emulator  /D/GIT clone/mapmytrip/src/mmt_4/www/js/app.js
client:emulator (1431934524497): appmobi_plus_cordova :: Emulator restarting mmt_1
client:emulator (1431934524513): appmobi_plus_cordova :: _xdkLoad for project mmt_1....erapp.
server:emulator-webserver (1431934526473): req.path = /http-services/emulator-webserver/ripple/userapp/C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map
server:emulator-webserver (1431934526474): Other file request, fullPath = C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map
server:emulator-webserver (1431934526476): Error testing path C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map; msg = ERROR: name must either start with slash or use base option
Error
xdk:server (1431934530891): memmrk:    27833768    42164608
xdk:client (1431934531457): memmrk:    67719716    89182336
xdk:client (1431935741915): memmrk:    58676876    71533184
Node Webkit Error log:
[9004:0518/091535:INFO:CONSOLE(17)] ""xdk:client (1431933335129): Error SyntaxError: Unexpected token \uFEFF loading components\\client\\app\\locale\\ru\\text-content.json"", source: D:\xdk\core-modules\private\logger.js (17)
[9004:0518/091535:INFO:CONSOLE(17)] ""xdk:client (1431933335159): Error SyntaxError: Unexpected token \uFEFF loading components\\client\\profiling\\locale\\ru\\text-content.json"", source: D:\xdk\core-modules\private\logger.js (17)
[9004:0518/091535:INFO:CONSOLE(989)] "" Unhandled rejection reasons (should be empty):" ["(no stack) [object Object]"]", source: file:///D:/xdk/node_modules/q/q.js (989)
[9004:0518/091543:INFO:CONSOLE(224)] ""NW proxy string: DIRECT"", source: /brackets.js (224)
[9004:0518/091543:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n    at new jQuery.fn.init (/brackets.js:455:36)\n    at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n    at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/camden.jshint/main.js:174:9\n    at _callHandler (/utils/AppInit.js:94:13)\n    at Object._dispatchReady (/utils/AppInit.js:114:13)\n    at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n    at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n    at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n    at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[9004:0518/091543:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n    at new jQuery.fn.init (/brackets.js:455:36)\n    at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n    at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/camden.jshint/main.js:183:9\n    at _callHandler (/utils/AppInit.js:94:13)\n    at Object._dispatchReady (/utils/AppInit.js:114:13)\n    at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n    at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n    at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n    at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[9004:0518/091543:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n    at new jQuery.fn.init (/brackets.js:455:36)\n    at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n    at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/intelxdk.xlint/main.js:366:9\n    at _callHandler (/utils/AppInit.js:94:13)\n    at Object._dispatchReady (/utils/AppInit.js:114:13)\n    at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n    at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n    at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n    at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[9004:0518/091543:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n    at new jQuery.fn.init (/brackets.js:455:36)\n    at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n    at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/intelxdk.xlint/main.js:375:9\n    at _callHandler (/utils/AppInit.js:94:13)\n    at Object._dispatchReady (/utils/AppInit.js:114:13)\n    at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n    at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n    at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n    at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[9004:0518/091544:INFO:CONSOLE(989)] "" Unhandled rejection reasons (should be empty):" ["(no stack) ERROR: no user is logged in\nError\n    at new ComponentError (D:\\xdk\\core-modules\\public\\component-error.js:17:1122)\n    at makeError (file:///D:/xdk/components/client/backend-service-utils/backend-service-utils.js:17:187)\n    at file:///D:/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1258\n    at _fulfilled (D:\\xdk\\node_modules\\q\\q.js:797:54)\n    at self.promiseDispatch.done (D:\\xdk\\node_modules\\q\\q.js:826:30)\n    at Promise.promise.promiseDispatch (D:\\xdk\\node_modules\\q\\q.js:759:13)\n    at D:\\xdk\\node_modules\\q\\q.js:573:44\n    at flush (D:\\xdk\\node_modules\\q\\q.js:108:17)\n    at process._tickCallback (node.js:393:11)"]", source: D:\xdk\node_modules\q\q.js (989)
[9004:0518/091551:INFO:CONSOLE(23)] ""ROUTE"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (23)
[9004:0518/091551:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[9004:0518/091551:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[9004:0518/091551:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[9004:0518/091551:INFO:CONSOLE(8)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (8)
[9004:0518/091551:INFO:CONSOLE(10)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (10)
[9004:0518/091819:INFO:CONSOLE(23)] ""ROUTE"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (23)
[9004:0518/091819:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[9004:0518/091819:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[9004:0518/091819:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[9004:0518/091819:INFO:CONSOLE(8)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (8)
[9004:0518/091819:INFO:CONSOLE(10)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (10)
[9004:0518/091829:INFO:CONSOLE(989)] "" Unhandled rejection reasons (should be empty):" ["(no stack) ERROR: name must either start with slash or use base option\nError\n    at ComponentError (D:\\xdk\\core-modules\\public\\component-error.js:17:1122)\n    at new ServiceError (D:\\xdk\\core-modules\\public\\service-error.js:17:317)\n    at _ensureStartsWithSlashOrUsesBaseOption (D:\\xdk\\components\\server\\userfs\\filter\\sanitize.js:17:800)\n    at D:\\xdk\\components\\server\\userfs\\filter\\sanitize.js:17:1227\n    at Array.forEach (native)\n    at Function._.each._.forEach (D:\\xdk\\node_modules\\underscore\\underscore.js:79:11)\n    at D:\\xdk\\components\\server\\userfs\\filter\\sanitize.js:17:1120\n    at Array.forEach (native)\n    at Function._.each._.forEach (D:\\xdk\\node_modules\\underscore\\underscore.js:79:11)\n    at beforeFilter (D:\\xdk\\components\\server\\userfs\\filter\\sanitize.js:17:1082)"]", source: D:\xdk\node_modules\q\q.js (989)
[9004:0518/091839:INFO:CONSOLE(8)] ""Second service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service2.js (8)
[9004:0518/091839:INFO:CONSOLE(10)] ""Second controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller2.js (10)
[9004:0518/091845:INFO:CONSOLE(8)] ""Third service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (8)
[9004:0518/091845:INFO:CONSOLE(10)] ""Third controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller3.js (10)
[9004:0518/091845:INFO:CONSOLE(11)] ""service 3 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (11)
[9004:0518/093524:INFO:CONSOLE(24)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (24)
[9004:0518/093524:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[9004:0518/093524:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[9004:0518/093524:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[9004:0518/093524:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[9004:0518/093525:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[9004:0518/093525:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
XDK exit code & signal: 3221225477, null
Crash minidump not found in XDK data folder. Falling back to TEMP...
Crash Minidump File: C:\Users\ccantagrel\AppData\Local\Temp\7b06a7aa-b3d4-48b0-9ee9-52f855bdfe02.dmp Mon May 18 2015 09:55:44 GMT+0200 (Romance Daylight Time)
Size in bytes: 501536
NW Crash Detected.
Best regards
Cantagrel_C_
Or another:
xdk:client (1431937128078): memlim: 767557632
xdk:client (1431937128080): Setting NW crash dump to: C:\Users\ccantagrel\AppData\Local\XDK
xdk:client (1431937128226): Intel XDK: 1995
....l" calling init()
xdk:client (1431937130873): Component "client:resource-util" finished initialization
xdk:client (1431937130876): Component "client:backend-services" calling init()
client:backend-services (1431937130876): Base url https://appcenter.html5tools-software.intel.com/, edition xdk
client:backend-services (1431937130877): Account paths: {
  "login": "Account/xdklogin.aspx",
  "logout": "csd/logout.aspx",
  "register": "csd/Cloud-Services-Dashboard-Sign-Up.aspx",
  "update": "csd/Account-Change.aspx",
  "details": "csd/Account.aspx"
client:backend-services (1431937130877): Account urls: {
  "login": "https://appcenter.html5tools-software.intel.com/Account/xdklogin.aspx?xdk=true&xdkvariant=xdk&xdkversion=release-2015-ww19",
  "logout": "https://appcenter.html5tools-software.intel.com/csd/logout.aspx?xdk=true&xdkvariant=xdk&xdkversion=release-2015-ww19",
  "register": "https://appcenter.html5tools-software.intel.com/csd/Cloud-Services-Dashboard-Sign-Up.aspx?xdk=true&xdkvariant=xdk&xdkversion=release-2015-ww19",
  "update": "https://appcenter.html5tools-software.intel.com/csd/Account-Change.aspx?xdk=true&xdkvariant=xdk&xdkversion=release-2015-ww19",
  "details": "https://appcenter.html5tools-software.intel.com/csd/Account.aspx?xdk=true&xdkvariant=xdk&xdkversion=release-2015-ww19"
client:backend-services (1431937130877): Service urls: {
  "issue": "https://appcenter.html5tools-software.intel.com/xdkissue",
  "certificate": "https://appcenter.html5tools-software.intel.com/xdk2/v2/api.asmx/gencert",
  "projectRenderers": "https://appcenter.html5tools-software.intel.com/api/v2.0/redirect/projectrenderers/",
  "updates": "https://appcenter.html5tools-software.intel.com/api/v2.0/redirect/updates/xdk/",
  "curatedServices": "https://appcenter.html5tools-software.intel.com/api/v2.0/redirect/appservices/"
xdk:client (1431937130877): Component "client:backend-services" finished initialization
xdk:client (1431937130877): Component "client:backend-services-ext" calling init()
xdk:server (1431937148679): memmrk:    23364388    61677056
uib-client (1431937149850): gradeHTMLFile 1 /D/GIT clone/mapmytrip/src/mmt_4/www/index.html
uib-client (1431937151752): gradeHTMLFile 1 /D/GIT clone/mapmytrip/src/mmt_4/www/index.html
xdk:client (1431937153101): memmrk:    55670836    83478400
xdk:server (1431937153679): memmrk:    24077812    61677056
client:emulator (1431937156756): Device Emulator :: Environment Warming Up (Tea. Earl Gray. Hot.)
client:emulator (1431937156936): appmobi_plus_cordova :: Emulator changing to project mmt_1
client:emulator (1431937156941): appmobi_plus_cordova :: _xdkLoad for project mmt_1
server:emulator-webserver (1431943183005): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view_layout.html
server:emulator-webserver (1431943183013): HTML file doesn't look like entire document; skipping injection
xdk:server (1431943184376): memmrk:    29748716    41148928
xdk:server (1431943279368): memmrk:    24689444    32838272
xdk:client (1431943279686): memmrk:    83217032    112506496
client:emulator (1431943284015): [emulator] file change restarted emulator  /D/GIT clone/mapmytrip/src/mmt_4/www/js/controllers/controller_layout.js
client:emulator (1431943284017): appmobi_plus_cordova :: Emulator restarting mmt_1
server:emulator-webserver (1431943288342): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view_login.html
server:emulator-webserver (1431943288342): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view_login.html
server:emulator-webserver (1431943288345): HTML file doesn't look like entire document; skipping injection
server:emulator-webserver (1431943289248): emulator-webserver: got a request for userapp.
server:emulator-webserver (1431943289248): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view_layout.html
server:emulator-webserver (1431943289249): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view_layout.html
server:emulator-webserver (1431943289253): HTML file doesn't look like entire document; skipping injection
xdk:server (1431943289369): memmrk:    28165868    36954624
xdk:client (1431943289688): memmrk:    84234676    113522176
xdk:server (1431943294370): memmrk:    28172228    36954624
xdk:server (1431943894392): memmrk:    25380748    32838272
xdk:client (1431943894903): memmrk:    93823144    119604096
client:emulator (1431943898282): Device Emulator :: Environment Warming Up (Tea. Earl Gray. Hot.)
client:emulator (1431943898453): appmobi_plus_cordova :: Emulator changing to project mmt_1
client:emulator (1431943898458): appmobi_plus_cordova :: _xdkLoad for project mmt_1
client:emulator (1431943898614): appmobi_plus_cordova :: Initialization Finished (Make it so.)
server:emulator-webserver (1431943898616): emulator-webserver: got a request for userapp.
server:emulator-webserver (1431943932954): emulator-webserver: got a request for userapp.
server:emulator-webserver (1431943932954): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view_layout.html
server:emulator-webserver (1431943932954): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view_layout.html
server:emulator-webserver (1431943932969): HTML file doesn't look like entire document; skipping injection
xdk:server (1431943934394): memmrk:    26418608    37958144
xdk:client (1431943934913): memmrk:    87405968    121659776
xdk:client (1431944029958): memmrk:    99644488    122675456
xdk:server (1431944034400): memmrk:    25278824    34935424
[6376:0518/101848:INFO:CONSOLE(17)] ""xdk:client (1431937128234): Error SyntaxError: Unexpected token \uFEFF loading components\\client\\app\\locale\\ru\\text-content.json"", source: D:\xdk\core-modules\private\logger.js (17)
[6376:0518/101848:INFO:CONSOLE(17)] ""xdk:client (1431937128265): Error SyntaxError: Unexpected token \uFEFF loading components\\client\\profiling\\locale\\ru\\text-content.json"", source: D:\xdk\core-modules\private\logger.js (17)
[6376:0518/101848:INFO:CONSOLE(989)] "" Unhandled rejection reasons (should be empty):" ["(no stack) [object Object]"]", source: file:///D:/xdk/node_modules/q/q.js (989)
[6376:0518/101854:INFO:CONSOLE(224)] ""NW proxy string: DIRECT"", source: /brackets.js (224)
[6376:0518/101854:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n    at new jQuery.fn.init (/brackets.js:455:36)\n    at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n    at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/camden.jshint/main.js:174:9\n    at _callHandler (/utils/AppInit.js:94:13)\n    at Object._dispatchReady (/utils/AppInit.js:114:13)\n    at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n    at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n    at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n    at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[6376:0518/101854:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n    at new jQuery.fn.init (/brackets.js:455:36)\n    at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n    at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/camden.jshint/main.js:183:9\n    at _callHandler (/utils/AppInit.js:94:13)\n    at Object._dispatchReady (/utils/AppInit.js:114:13)\n    at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n    at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n    at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n    at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[6376:0518/101854:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n    at new jQuery.fn.init (/brackets.js:455:36)\n    at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n    at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/intelxdk.xlint/main.js:366:9\n    at _callHandler (/utils/AppInit.js:94:13)\n    at Object._dispatchReady (/utils/AppInit.js:114:13)\n    at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n    at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n    at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n    at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[6376:0518/101854:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n    at new jQuery.fn.init (/brackets.js:455:36)\n    at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n    at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/intelxdk.xlint/main.js:375:9\n    at _callHandler (/utils/AppInit.js:94:13)\n    at Object._dispatchReady (/utils/AppInit.js:114:13)\n    at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n    at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n    at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n    at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[6376:0518/101854:INFO:CONSOLE(989)] "" Unhandled rejection reasons (should be empty):" ["(no stack) ERROR: no user is logged in\nError\n    at new ComponentError (D:\\xdk\\core-modules\\public\\component-error.js:17:1122)\n    at makeError (file:///D:/xdk/components/client/backend-service-utils/backend-service-utils.js:17:187)\n    at file:///D:/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1258\n    at _fulfilled (D:\\xdk\\node_modules\\q\\q.js:797:54)\n    at self.promiseDispatch.done (D:\\xdk\\node_modules\\q\\q.js:826:30)\n    at Promise.promise.promiseDispatch (D:\\xdk\\node_modules\\q\\q.js:759:13)\n    at D:\\xdk\\node_modules\\q\\q.js:573:44\n    at flush (D:\\xdk\\node_modules\\q\\q.js:108:17)\n    at process._tickCallback (node.js:393:11)"]", source: D:\xdk\node_modules\q\q.js (989)
[6376:0518/101917:INFO:CONSOLE(3)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (3)
[6376:0518/101917:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/101917:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/101917:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/101917:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/101917:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/101917:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/101923:INFO:CONSOLE(8)] ""Second service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service2.js (8)
[6376:0518/101923:INFO:CONSOLE(10)] ""Second controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller2.js (10)
[6376:0518/101924:INFO:CONSOLE(8)] ""Third service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (8)
[6376:0518/101924:INFO:CONSOLE(10)] ""Third controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller3.js (10)
[6376:0518/101924:INFO:CONSOLE(11)] ""service 3 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (11)
[6376:0518/101925:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/101925:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/101926:INFO:CONSOLE(10)] ""Second controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller2.js (10)
[6376:0518/101927:INFO:CONSOLE(10)] ""Third controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller3.js (10)
[6376:0518/101927:INFO:CONSOLE(11)] ""service 3 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (11)
[6376:0518/102000:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/102000:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/102000:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/102000:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/102000:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/102000:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/102000:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/102005:INFO:CONSOLE(8)] ""Second service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service2.js (8)
[6376:0518/102005:INFO:CONSOLE(10)] ""Second controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller2.js (10)
[6376:0518/102006:INFO:CONSOLE(8)] ""Third service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (8)
[6376:0518/102006:INFO:CONSOLE(10)] ""Third controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller3.js (10)
[6376:0518/102006:INFO:CONSOLE(11)] ""service 3 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (11)
[6376:0518/102008:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/102008:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/103223:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/103223:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/103224:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/103224:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/103224:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/103224:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/103224:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/103357:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/103357:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/103357:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/103357:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/103357:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/103357:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/103357:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/110022:ERROR:dns_config_service_win.cc(739)] DNS config watch failed.
[6376:0518/112310:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/112310:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/112310:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/112310:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/112310:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/112310:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/112310:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/112314:INFO:CONSOLE(8)] ""Second service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service2.js (8)
[6376:0518/112314:INFO:CONSOLE(10)] ""Second controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller2.js (10)
[6376:0518/112316:INFO:CONSOLE(8)] ""Third service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (8)
[6376:0518/112316:INFO:CONSOLE(10)] ""Third controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller3.js (10)
[6376:0518/112316:INFO:CONSOLE(11)] ""service 3 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (11)
[6376:0518/112317:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/112317:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/113305:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/113305:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/113305:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/113305:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/113305:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/113305:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/113305:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/113316:INFO:CONSOLE(114)] ""Error: [ng:areq] http://errors.angularjs.org/1.2.12/ng/areq?p0=SecondCtrl&p1=not%20a%20function%2C%20got%20undefined\n   ; at Error (native)\n    at http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:35:450\n   ; at tb (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:47:360)\n    at Pa (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:47:447)\n    at http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:91:17\n   ; at d (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:321:17502)\n    at b (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:321:17903)\n    at h.$broadcast (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:134:155)\n    at t.transition.N.then.t.transition.t.transition (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:298:10007)\n    at A (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:122:5)"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js (114)
[6376:0518/113317:INFO:CONSOLE(8)] ""Third service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (8)
[6376:0518/113317:INFO:CONSOLE(10)] ""Third controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller3.js (10)
[6376:0518/113317:INFO:CONSOLE(11)] ""service 3 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (11)
[6376:0518/113318:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/113318:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/113318:INFO:CONSOLE(114)] ""Error: [ng:areq] http://errors.angularjs.org/1.2.12/ng/areq?p0=SecondCtrl&p1=not%20a%20function%2C%20got%20undefined\n   ; at Error (native)\n    at http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:35:450\n   ; at tb (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:47:360)\n    at Pa (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:47:447)\n    at http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:91:17\n   ; at d (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:321:17502)\n    at b (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:321:17903)\n    at h.$broadcast (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:134:155)\n    at t.transition.N.then.t.transition.t.transition (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:298:10007)\n    at A (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:122:5)"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js (114)
[6376:0518/113409:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/113409:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/113409:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/113409:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/113409:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/113409:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/113409:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/113414:INFO:CONSOLE(8)] ""Login service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_login.js (8)
[6376:0518/113414:INFO:CONSOLE(10)] ""Login controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_login.js (10)
[6376:0518/113416:INFO:CONSOLE(8)] ""Third service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (8)
[6376:0518/113416:INFO:CONSOLE(10)] ""Third controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller3.js (10)
[6376:0518/113416:INFO:CONSOLE(11)] ""service 3 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (11)
[6376:0518/113417:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/113417:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/114552:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/114552:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/114552:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/114552:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/114552:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/114552:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/114552:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/114736:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/114736:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/114736:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/114736:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/114736:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/114736:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/114736:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/114742:INFO:CONSOLE(8)] ""Login service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_login.js (8)
[6376:0518/114742:INFO:CONSOLE(10)] ""Login controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_login.js (10)
[6376:0518/114743:INFO:CONSOLE(8)] ""Third service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (8)
[6376:0518/114743:INFO:CONSOLE(10)] ""Third controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller3.js (10)
[6376:0518/114743:INFO:CONSOLE(11)] ""service 3 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (11)
[6376:0518/114744:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/114744:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/114745:INFO:CONSOLE(10)] ""Login controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_login.js (10)
[6376:0518/114746:INFO:CONSOLE(10)] ""Third controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller3.js (10)
[6376:0518/114746:INFO:CONSOLE(11)] ""service 3 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service3.js (11)
[6376:0518/114747:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/114747:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/115546:INFO:CONSOLE(59)] "Uncaught Error: [$injector:modulerr] http://errors.angularjs.org/1.2.12/$injector/modulerr?p0=mmt&p1=Error%3A%20%5B%24injector%3Amodulerr%5D%20http%3A%2F%2Ferrors.angularjs.org%2F1.2.12%2F%24injector%2Fmodulerr%3Fp0%3Dmmt.controller3%26p1%3DError%253A%2520%255B%2524injector%253Anomod%255D%2520http%253A%252F%252Ferrors.angularjs.org%252F1.2.12%252F%2524injector%252Fnomod%253Fp0%253Dmmt.controller3%250A%2520%2520%2520%2520at%2520Error%2520(native)%250A%2520%2520%2520%2520at%2520http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A35%253A450%250A%2520%2520%2520%2520at%2520http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A49%253A260%250A%2520%2520%2520%2520at%2520http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A50%253A262%250A%2520%2520%2520%2520at%2520http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A58%253A175%250A%2520%2520%2520%2520at%2520Array.forEach%2520(native)%250A%2520%2520%2520%2520at%2520q%2520(http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A36%253A280)%250A%2520%2520%2520%2520at%2520e%2520(http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A58%253A115)%250A%2520%2520%2520%2520at%2520http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A58%253A192%250A%2520%2520%2520%2520at%2520Array.forEach%2520(native)%0A%20%20%20%20at%20Error%20(native)%0A%20%20%20%20at%20http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A35%3A450%0A%20%20%20%20at%20http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A59%3A1%0A%20%20%20%20at%20Array.forEach%20(native)%0A%20%20%20%20at%20q%20(http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A36%3A280)%0A%20%20%20%20at%20e%20(http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A58%3A115)%0A%20%20%20%20at%20http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A58%3A192%0A%20%20%20%20at%20Array.forEach%20(native)%0A%20%20%20%20at%20q%20(http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A36%3A280)%0A%20%20%20%20at%20e%20(http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A58%3A115)", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js (59)
[6376:0518/115907:INFO:CONSOLE(59)] "Uncaught Error: [$injector:modulerr] http://errors.angularjs.org/1.2.12/$injector/modulerr?p0=mmt&p1=Error%3A%20%5B%24injector%3Amodulerr%5D%20http%3A%2F%2Ferrors.angularjs.org%2F1.2.12%2F%24injector%2Fmodulerr%3Fp0%3Dmmt.controller_layout%26p1%3DError%253A%2520%255B%2524injector%253Amodulerr%255D%2520http%253A%252F%252Ferrors.angularjs.org%252F1.2.12%252F%2524injector%252Fmodulerr%253Fp0%253Dmmt.service_layout%2526p1%253DError%25253A%252520%25255B%252524injector%25253Anomod%25255D%252520http%25253A%25252F%25252Ferrors.angularjs.org%25252F1.2.12%25252F%252524injector%25252Fnomod%25253Fp0%25253Dmmt.service_layout%25250A%252520%252520%252520%252520at%252520Error%252520(native)%25250A%252520%252520%252520%252520at%252520http%25253A%25252F%25252F127.0.0.1%25253A58889%25252Fhttp-services%25252Femulator-webserver%25252Fripple%25252Fuserapp%25252F%25252FC%25252FUsers%25252Fccantagrel%25252FAppData%25252FLocal%25252FXDK%25252Fxdk-scratchdir%25252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%25252Fplatforms%25252Fios%25252Fwww%25252Flib%25252Fionicframework%25252Fionic.bundle.min.js%25253A35%25253A450%25250A%252520%252520%252520%252520at%252520http%25253A%25252F%25252F127.0.0.1%25253A58889%25252Fhttp-services%25252Femulator-webserver%25252Fripple%25252Fuserapp%25252F%25252FC%25252FUsers%25252Fccantagrel%25252FAppData%25252FLocal%25252FXDK%25252Fxdk-scratchdir%25252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%25252Fplatforms%25252Fios%25252Fwww%25252Flib%25252Fionicframework%25252Fionic.bundle.min.js%25253A49%25253A260%25250A%252520%252520%252520%252520at%252520http%25253A%25252F%25252F127.0.0.1%25253A58889%25252Fhttp-services%25252Femulator-webserver%25252Fripple%25252Fuserapp%25252F%25252FC%25252FUsers%25252Fccantagrel%25252FAppData%25252FLocal%25252FXDK%25252Fxdk-scratchdir%25252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%25252Fplatforms%25252Fios%25252Fwww%25252Flib%25252Fionicframework%25252Fionic.bundle.min.js%25253A50%25253A262%25250A%252520%252520%252520%252520at%252520http%25253A%25252F%25252F127.0.0.1%25253A58889%25252Fhttp-services%25252Femulator-webserver%25252Fripple%25252Fuserapp%25252F%25252FC%25252FUsers%25252Fccantagrel%25252FAppData%25252FLocal%25252FXDK%25252Fxdk-scratchdir%25252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%25252Fplatforms%25252Fios%25252Fwww%25252Flib%25252Fionicframework%25252Fionic.bundle.min.js%25253A58%25253A175%25250A%252520%252520%252520%252520at%252520Array.forEach%252520(native)%25250A%252520%252520%252520%252520at%252520q%252520(http%25253A%25252F%25252F127.0.0.1%25253A58889%25252Fhttp-services%25252Femulator-webserver%25252Fripple%25252Fuserapp%25252F%25252FC%25252FUsers%25252Fccantagrel%25252FAppData%25252FLocal%25252FXDK%25252Fxdk-scratchdir%25252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%25252Fplatforms%25252Fios%25252Fwww%25252Flib%25252Fionicframework%25252Fionic.bundle.min.js%25253A36%25253A280)%25250A%252520%252520%252520%252520at%252520e%252520(http%25253A%25252F%25252F127.0.0.1%25253A58889%25252Fhttp-services%25252Femulator-webserver%25252Fripple%25252Fuserapp%25252F%25252FC%25252FUsers%25252Fccantagrel%25252FAppData%25252FLocal%25252FXDK%25252Fxdk-scratchdir%25252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%25252Fplatforms%25252Fios%25252Fwww%25252Flib%25252Fionicframework%25252Fionic.bundle.min.js%25253A58%25253A115)%25250A%252520%252520%252520%252520at%252520http%25253A%25252F%25252F127.0.0.1%25253A58889%25252Fhttp-services%25252Femulator-webserver%25252Fripple%25252Fuserapp%25252F%25252FC%25252FUsers%25252Fccantagrel%25252FAppData%25252FLocal%25252FXDK%25252Fxdk-scratchdir%25252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%25252Fplatforms%25252Fios%25252Fwww%25252Flib%25252Fionicframework%25252Fionic.bundle.min.js%25253A58%25253A192%25250A%252520%252520%252520%252520at%252520Array.forEach%252520(native)%250A%2520%2520%2520%2520at%2520Error%2520(native)%250A%2520%2520%2520%2520at%2520http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A35%253A450%250A%2520%2520%2520%2520at%2520http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A59%253A1%250A%2520%2520%2520%2520at%2520Array.forEach%2520(native)%250A%2520%2520%2520%2520at%2520q%2520(http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A36%253A280)%250A%2520%2520%2520%2520at%2520e%2520(http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A58%253A115)%250A%2520%2520%2520%2520at%2520http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A58%253A192%250A%2520%2520%2520%2520at%2520Array.forEach%2520(native)%250A%2520%2520%2520%2520at%2520q%2520(http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A36%253A280)%250A%2520%2520%2520%2520at%2520e%2520(http%253A%252F%252F127.0.0.1%253A58889%252Fhttp-services%252Femulator-webserver%252Fripple%252Fuserapp%252F%252FC%252FUsers%252Fccantagrel%252FAppData%252FLocal%252FXDK%252Fxdk-scratchdir%252F0d3b2229-6528-4d6f-ae1f-320d443ff76c%252Fplatforms%252Fios%252Fwww%252Flib%252Fionicframework%252Fionic.bundle.min.js%253A58%253A115)%0A%20%20%20%20at%20Error%20(native)%0A%20%20%20%20at%20http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A35%3A450%0A%20%20%20%20at%20http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A59%3A1%0A%20%20%20%20at%20Array.forEach%20(native)%0A%20%20%20%20at%20q%20(http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A36%3A280)%0A%20%20%20%20at%20e%20(http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A58%3A115)%0A%20%20%20%20at%20http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A58%3A192%0A%20%20%20%20at%20Array.forEach%20(native)%0A%20%20%20%20at%20q%20(http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A36%3A280)%0A%20%20%20%20at%20e%20(http%3A%2F%2F127.0.0.1%3A58889%2Fhttp-services%2Femulator-webserver%2Fripple%2Fuserapp%2F%2FC%2FUsers%2Fccantagrel%2FAppData%2FLocal%2FXDK%2Fxdk-scratchdir%2F0d3b2229-6528-4d6f-ae1f-320d443ff76c%2Fplatforms%2Fios%2Fwww%2Flib%2Fionicframework%2Fionic.bundle.min.js%3A58%3A115)", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js (59)
[6376:0518/115937:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/115937:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/115937:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/115937:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/115937:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/115937:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/115937:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/115942:INFO:CONSOLE(8)] ""Login service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_login.js (8)
[6376:0518/115942:INFO:CONSOLE(10)] ""Login controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_login.js (10)
[6376:0518/115943:INFO:CONSOLE(114)] ""Error: [$injector:unpr] http://errors.angularjs.org/1.2.12/$injector/unpr?p0=ThirdServiceProvider%20%3C-%20ThirdService\n   ; at Error (native)\n    at http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:35:450\n   ; at http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:61:125\n   ; at Object.c [as get] (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:59:200)\n    at http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:61:193\n   ; at c (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:59:200)\n    at d (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:59:417)\n    at Object.instantiate (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:60:80)\n    at http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:91:33\n   ; at d (http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js:321:17502)"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js (114)
[6376:0518/120124:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/120124:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/120124:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/120124:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/120124:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/120124:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/120124:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/120128:INFO:CONSOLE(8)] ""Login service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_login.js (8)
[6376:0518/120128:INFO:CONSOLE(10)] ""Login controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_login.js (10)
[6376:0518/120129:INFO:CONSOLE(8)] ""Layout service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_layout.js (8)
[6376:0518/120129:INFO:CONSOLE(10)] ""Layout controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_layout.js (10)
[6376:0518/120129:INFO:CONSOLE(11)] ""service layout called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_layout.js (11)
[6376:0518/120130:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/120130:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/121138:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/121138:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/121138:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/121138:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/121138:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/121138:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/121138:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/121153:INFO:CONSOLE(8)] ""Login service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_login.js (8)
[6376:0518/121153:INFO:CONSOLE(10)] ""Login controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_login.js (10)
[6376:0518/121154:INFO:CONSOLE(8)] ""Layout service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_layout.js (8)
[6376:0518/121154:INFO:CONSOLE(10)] ""Layout controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_layout.js (10)
[6376:0518/121154:INFO:CONSOLE(11)] ""service layout called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_layout.js (11)
[6376:0518/121156:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/121156:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/121157:INFO:CONSOLE(10)] ""Login controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_login.js (10)
[6376:0518/121158:INFO:CONSOLE(10)] ""Layout controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_layout.js (10)
[6376:0518/121158:INFO:CONSOLE(11)] ""service layout called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_layout.js (11)
[6376:0518/121204:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[6376:0518/121204:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[6376:0518/121204:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[6376:0518/121204:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/121204:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/121205:INFO:CONSOLE(9)] ""ready"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (9)
[6376:0518/121205:INFO:CONSOLE(11)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (11)
[6376:0518/121211:INFO:CONSOLE(8)] ""Login service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_login.js (8)
[6376:0518/121211:INFO:CONSOLE(10)] ""Login controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_login.js (10)
[6376:0518/121212:INFO:CONSOLE(8)] ""Layout service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_layout.js (8)
[6376:0518/121212:INFO:CONSOLE(10)] ""Layout controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_layout.js (10)
[6376:0518/121212:INFO:CONSOLE(11)] ""service layout called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service_layout.js (11)
[6376:0518/121214:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[6376:0518/121214:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[6376:0518/121216:INFO:CONSOLE(10)] ""Login controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller_login.js (10)
XDK exit code & signal: 3221225477, null
Crash minidump not found in XDK data folder. Falling back to TEMP...
Crash Minidump File: C:\Users\ccantagrel\AppData\Local\Temp\2215c8ed-f84e-4d1e-852b-f36fde874fb0.dmp Mon May 18 2015 12:13:54 GMT+0200 (Romance Daylight Time)
Size in bytes: 520465
NW Crash Detected.
Cantagrel_C_
another one :
xdk:client (1432047263674): memlim: 767557632
xdk:client (1432047263679): Setting NW crash dump to: C:\Users\ccantagrel\AppData\Local\XDK
xdk:client (1432047263843): Intel XDK: 1995
xdk:client (1432047263843): Platform: win32-ia32 (6.1.7601)
xdk:client (1432047263851): Error SyntaxError: Unexpected token loading components\client\app\locale\ru\text-content.json
xdk:client (1432047263883): Error SyntaxError: Unexpected token loading components\client\profiling\locale\ru\text-content.json
xdk:client (1432047263959): Starting client process initialization
xdk:client (1432047263979): NW Cache is up-to-date.
xdk:server (1432047264314): memlim: 767557632
xdk:server (1432047264316): Setting NW crash dump to: C:\Users\ccantagrel\AppData\Local\XDK
xdk:server (1432047264463): Starting server process initialization
xdk:server (1432047264540): Http server started on the standard port 58889
xdk:server (1432047265600): Component "core:assert" starting import
xdk:server (1432047265601): Component "core:assert" finished initialization
xdk:server (1432047265601): Component "core:component-error" starting import
xdk:server (1432047265601): Component "core:component-error" finished initialization
xdk:server (1432047265601): Component "core:command-line-options" starting import
xdk:server (1432047265602): Component "core:command-line-options" finished initialization
xdk:server (1432047265602): Component "core:service-error" starting import
xdk:server (1432047265602): Component "core:service-error" finished initialization
xdk:server (1432047265602): Component "core:buffer" starting import
xdk:server (1432047265607): Component "core:buffer" finished initialization
xdk:server (1432047265607): Component "core:signaler" starting import
xdk:server (1432047265610): Component "core:signaler" finished initialization
xdk:server (1432047265610): Component "core:signaler-group" starting import
xdk:server (1432047265613): Component "core:signaler-group" finished initialization
xdk:server (1432047265613): Component "core:logger" starting import
xdk:server (1432047265614): Component "core:logger" finished initialization
xdk:server (1432047265614): Component "core:http-request" starting import
xdk:server (1432047265617): Component "core:http-request" finished initialization
xdk:server (1432047265617): Component "core:database" starting import
xdk:server (1432047265619): Component "core:database" finished initialization
xdk:server (1432047265619): Component "core:version" starting import
xdk:server (1432047265619): Component "core:version" finished initialization
xdk:server (1432047265619): Component "core:userfs-name-converter" starting import
xdk:server (1432047265620): Component "core:userfs-name-converter" finished initialization
xdk:server (1432047265620): Component "core:crash-handler" starting import
xdk:server (1432047265621): Component "core:crash-handler" finished initialization
xdk:server (1432047265621): Component "core:i18n-support" starting import
xdk:server (1432047265621): Component "core:i18n-support" finished initialization
xdk:server (1432047265621): Component "core:theme" starting import
xdk:server (1432047265664): Component "core:theme" finished initialization
xdk:server (1432047265666): Component "server:userfs" starting import
xdk:server (1432047265670): Component "server:userfs" calling init()
xdk:server (1432047265698): Component "server:userfs" finished initialization
xdk:server (1432047265698): Component "server:user-profile" starting import
xdk:server (1432047265700): Component "server:user-profile" calling init()
xdk:server (1432047265701): Component "server:user-profile" finished initialization
xdk:server (1432047265701): Component "server:ui-builder" starting import
xdk:server (1432047265750): Component "server:ui-builder" calling init()
xdk:server (1432047265752): Component "server:ui-builder" finished initialization
xdk:server (1432047265752): Component "server:emulator-notification" starting import
xdk:server (1432047265755): Component "server:emulator-notification" calling init()
xdk:server (1432047265755): Component "server:emulator-notification" finished initialization
xdk:server (1432047265755): Component "server:emulator-webserver" starting import
xdk:server (1432047265756): Component "server:emulator-webserver" calling init()
xdk:server (1432047265757): Component "server:emulator-webserver" finished initialization
xdk:server (1432047265757): Component "server:new-project-creator" starting import
xdk:server (1432047265760): Component "server:new-project-creator" calling init()
xdk:server (1432047265760): Component "server:new-project-creator" finished initialization
xdk:server (1432047265760): Component "server:zip-util" starting import
xdk:server (1432047265763): Component "server:zip-util" calling init()
xdk:server (1432047265763): Component "server:zip-util" finished initialization
xdk:server (1432047265763): Component "server:uuid-server" starting import
xdk:server (1432047265765): Component "server:uuid-server" calling init()
xdk:server (1432047265766): Component "server:uuid-server" finished initialization
xdk:server (1432047265766): Component "server:app-starter" starting import
xdk:server (1432047265772): Component "server:app-starter" calling init()
xdk:server (1432047265773): Component "server:app-starter" finished initialization
xdk:server (1432047265773): Component "server:force-download" starting import
xdk:server (1432047265776): Component "server:force-download" calling init()
xdk:server (1432047265776): Component "server:force-download" finished initialization
xdk:server (1432047265776): Component "server:updater" starting import
xdk:server (1432047265781): Component "server:updater" calling init()
server:updater (1432047265781): config.base-auto
server:updater (1432047265781): url=auto
xdk:server (1432047265782): Component "server:updater" finished initialization
xdk:server (1432047265782): Component "server:editor-node" starting import
xdk:server (1432047265802): Component "server:editor-node" calling init()
xdk:server (1432047265802): Component "server:editor-node" waiting for delayed initialization
xdk:server (1432047265802): Component "server:cordova-lib" starting import
xdk:server (1432047265846): Component "server:cordova-lib" calling init()
xdk:server (1432047265956): Component "server:cordova-lib" finished initialization
xdk:server (1432047265956): Component "server:api-explorer" starting import
xdk:server (1432047265959): Component "server:api-explorer" calling init()
xdk:server (1432047265978): Component "server:api-explorer" finished initialization
xdk:server (1432047265978): Component "server:plugin-listener" starting import
xdk:server (1432047265980): Component "server:plugin-listener" calling init()
xdk:server (1432047265980): Component "server:plugin-listener" finished initialization
server:editor-node (1432047265981): Starting Brackets node process D:\bin\node.exe D:\bin\node-core
xdk:server (1432047265992): NW Cache is up-to-date.
server:editor-node (1432047266101): Brackets node is running on port 64357
xdk:server (1432047266102): Component "server:editor-node" finished delayed initialization
xdk:server (1432047266102): Component "server:ui-builder" calling start()
xdk:server (1432047266105): Component "server:ui-builder" finished start()
xdk:server (1432047266105): Component "server:emulator-webserver" calling start()
xdk:server (1432047266105): Component "server:emulator-webserver" finished start()
xdk:server (1432047266105): Component "server:editor-node" calling start()
xdk:server (1432047266105): Component "server:editor-node" finished start()
xdk:server (1432047266107): Intel XDK is initialized now
xdk:server (1432047266108): Writing to the server data file
xdk:server (1432047266109): Wrote server data to "C:\Users\ccantagrel\AppData\Local\XDK\server-data.txt"
xdk:client (1432047266227): Successfully read server data file
xdk:client (1432047266360): Component "core:assert" starting import
xdk:client (1432047266360): Component "core:assert" finished initialization
xdk:client (1432047266360): Component "core:component-error" starting import
xdk:client (1432047266361): Component "core:component-error" finished initialization
xdk:client (1432047266361): Component "core:command-line-options" starting import
xdk:client (1432047266361): Component "core:command-line-options" finished initialization
xdk:client (1432047266361): Component "core:service-error" starting import
xdk:client (1432047266361): Component "core:service-error" finished initialization
xdk:client (1432047266361): Component "core:buffer" starting import
xdk:client (1432047266361): Component "core:buffer" finished initialization
xdk:client (1432047266361): Component "core:signaler" starting import
xdk:client (1432047266362): Component "core:signaler" finished initialization
xdk:client (1432047266362): Component "core:signaler-group" starting import
xdk:client (1432047266363): Component "core:signaler-group" finished initialization
xdk:client (1432047266363): Component "core:logger" starting import
xdk:client (1432047266364): Component "core:logger" finished initialization
xdk:client (1432047266364): Component "core:http-request" starting import
xdk:client (1432047266365): Component "core:http-request" finished initialization
xdk:client (1432047266365): Component "core:version" starting import
xdk:client (1432047266366): Component "core:version" finished initialization
xdk:client (1432047266366): Component "core:exit-notifier" starting import
xdk:client (1432047266366): Component "core:exit-notifier" finished initialization
xdk:client (1432047266366): Component "core:userfs-name-converter" starting import
xdk:client (1432047266366): Component "core:userfs-name-converter" finished initialization
xdk:client (1432047266366): Component "core:crash-handler" starting import
xdk:client (1432047266367): Component "core:crash-handler" finished initialization
xdk:client (1432047266367): Component "core:analytics" starting import
xdk:client (1432047266367): Component "core:analytics" finished initialization
xdk:client (1432047266367): Component "core:i18n-support" starting import
xdk:client (1432047266367): Component "core:i18n-support" finished initialization
xdk:client (1432047266367): Component "core:theme" starting import
xdk:client (1432047266400): Component "core:theme" finished initialization
xdk:client (1432047266410): Analytics ID: 4e26d75a-e1ab-4dbf-8f64-cee264ad6395
xdk:client (1432047266417): Component "client:app" starting import
xdk:client (1432047266417): Component "client:help-helper" starting import
xdk:client (1432047266417): Component "client:nativefs" starting import
xdk:client (1432047266417): Component "client:document-manager" starting import
xdk:client (1432047266417): Component "client:project-manager" starting import
xdk:client (1432047266417): Component "client:aa-controller" starting import
xdk:client (1432047266417): Component "client:projects-renderers" starting import
xdk:client (1432047266417): Component "client:projects-renderers-jsapp" starting import
xdk:client (1432047266417): Component "client:projects-renderers-webapp" starting import
xdk:client (1432047266417): Component "client:projects-renderers-iotapp" starting import
xdk:client (1432047266417): Component "client:active-sync" starting import
xdk:client (1432047266417): Component "client:apk-installer" starting import
xdk:client (1432047266417): Component "client:appcenter-options" starting import
xdk:client (1432047266417): Component "client:resource-manager" starting import
xdk:client (1432047266417): Component "client:resource-cocos2d" starting import
xdk:client (1432047266417): Component "client:resource-cocos2djs" starting import
xdk:client (1432047266417): Component "client:resource-phaser" starting import
xdk:client (1432047266417): Component "client:resource-pixi" starting import
xdk:client (1432047266417): Component "client:resource-easeljs" starting import
xdk:client (1432047266417): Component "client:resource-plain" starting import
xdk:client (1432047266417): Component "client:resource-render-frame" starting import
xdk:client (1432047266417): Component "client:resource-util" starting import
xdk:client (1432047266417): Component "client:services-tab" starting import
xdk:client (1432047266417): Component "client:editor" starting import
xdk:client (1432047266417): Component "client:live-preview" starting import
xdk:client (1432047266417): Component "client:backend-services" starting import
xdk:client (1432047266417): Component "client:backend-services-ext" starting import
xdk:client (1432047266417): Component "client:backend-service-utils" starting import
xdk:client (1432047266417): Component "client:app-starter" starting import
xdk:client (1432047266417): Component "client:ui-builder-client" starting import
xdk:client (1432047266417): Component "client:project-meta" starting import
xdk:client (1432047266418): Component "client:contenttype-registry" starting import
xdk:client (1432047266418): Component "client:editor-registry" starting import
xdk:client (1432047266418): Component "client:platform-registry" starting import
xdk:client (1432047266418): Component "client:projecttype-registry" starting import
xdk:client (1432047266418): Component "client:library-registry" starting import
xdk:client (1432047266418): Component "client:cordova-registry" starting import
xdk:client (1432047266418): Component "client:service-method" starting import
xdk:client (1432047266418): Component "client:settings-db" starting import
xdk:client (1432047266418): Component "client:adb" starting import
xdk:client (1432047266418): Component "client:iosdb" starting import
xdk:client (1432047266418): Component "client:device" starting import
xdk:client (1432047266418): Component "client:device-discovery" starting import
xdk:client (1432047266418): Component "client:dialog-box" starting import
xdk:client (1432047266418): Component "client:test-local-server" starting import
xdk:client (1432047266418): Component "client:quick-tour" starting import
xdk:client (1432047266418): Component "client:hot-keys" starting import
xdk:client (1432047266418): Component "client:persistance" starting import
xdk:client (1432047266418): Component "client:tabs" starting import
xdk:client (1432047266418): Component "client:hash-utils" starting import
xdk:client (1432047266418): Component "client:file-watcher" starting import
xdk:client (1432047266418): Component "client:tool-tip" starting import
xdk:client (1432047266418): Component "client:cordova" starting import
xdk:client (1432047266418): Component "client:settings-ui" starting import
xdk:client (1432047266418): Component "client:external-links" starting import
xdk:client (1432047266418): Component "client:external-editors-runner" starting import
xdk:client (1432047266452): Component "client:help-helper" finished initialization
xdk:client (1432047266452): Component "client:nativefs" finished initialization
xdk:client (1432047266461): Component "client:active-sync" calling init()
xdk:client (1432047266461): Component "client:active-sync" finished initialization
xdk:client (1432047266462): Component "client:apk-installer" calling init()
xdk:client (1432047266462): Component "client:apk-installer" finished initialization
xdk:client (1432047266468): Component "client:resource-easeljs" calling init()
xdk:client (1432047266469): Component "client:resource-easeljs" finished initialization
xdk:client (1432047266470): Component "client:resource-util" calling init()
xdk:client (1432047266470): Component "client:resource-util" finished initialization
xdk:client (1432047266472): Component "client:resource-render-frame" calling init()
xdk:client (1432047266472): Component "client:resource-render-frame" waiting for delayed initialization
xdk:client (1432047266474): Component "client:backend-services" calling init()
client:backend-services (1432047266474): Base url https://appcenter.html5tools-software.intel.com/, edition xdk
client:backend-services (1432047266475): Account paths: {
  "login": "Account/xdklogin.aspx",
  "logout": "csd/logout.aspx",
  "register": "csd/Cloud-Services-Dashboard-Sign-Up.aspx",
  "update": "csd/Account-Change.aspx",
  "details": "csd/Account.aspx"
client:backend-services (1432047266475): Account urls: {
  "login": "https://appcenter.html5tools-software.intel.com/Account/xdklogin.aspx?xdk=true&xdkvariant=xdk&xdkversion=release-2015-ww19",
  "logout": "https://appcenter.html5tools-software.intel.com/csd/logout.aspx?xdk=true&xdkvariant=xdk&xdkversion=release-2015-ww19",
  "register": "https://appcenter.html5tools-software.intel.com/csd/Cloud-Services-Dashboard-Sign-Up.aspx?xdk=true&xdkvariant=xdk&xdkversion=release-2015-ww19",
  "update": "https://appcenter.html5tools-software.intel.com/csd/Account-Change.aspx?xdk=true&xdkvariant=xdk&xdkversion=release-2015-ww19",
  "details": "https://appcenter.html5tools-software.intel.com/csd/Account.aspx?xdk=true&xdkvariant=xdk&xdkversion=release-2015-ww19"
client:backend-services (1432047266475): Service urls: {
  "issue": "https://appcenter.html5tools-software.intel.com/xdkissue",
  "certificate": "https://appcenter.html5tools-software.intel.com/xdk2/v2/api.asmx/gencert",
  "projectRenderers": "https://appcenter.html5tools-software.intel.com/api/v2.0/redirect/projectrenderers/",
  "updates": "https://appcenter.html5tools-software.intel.com/api/v2.0/redirect/updates/xdk/",
  "curatedServices": "https://appcenter.html5tools-software.intel.com/api/v2.0/redirect/appservices/"
xdk:client (1432047266475): Component "client:backend-services" finished initialization
xdk:client (1432047266475): Component "client:backend-services-ext" calling init()
xdk:client (1432047266476): Component "client:backend-services-ext" finished initialization
xdk:client (1432047266476): Component "client:backend-service-utils" finished initialization
xdk:client (1432047266478): Component "client:project-meta" calling init()
xdk:client (1432047266478): Component "client:project-meta" finished initialization
xdk:client (1432047266482): Component "client:service-method" finished initialization
xdk:client (1432047266483): Component "client:adb" calling init()
xdk:client (1432047266494): Component "client:adb" waiting for delayed initialization
xdk:client (1432047266495): Component "client:settings-db" calling init()
xdk:client (1432047266495): Component "client:settings-db" waiting for delayed initialization
xdk:client (1432047266495): Component "client:iosdb" calling init()
xdk:client (1432047266496): Component "client:iosdb" finished initialization
xdk:client (1432047266497): Component "client:device" finished initialization
xdk:client (1432047266501): Component "client:persistance" calling init()
xdk:client (1432047266501): Component "client:persistance" waiting for delayed initialization
xdk:client (1432047266503): Component "client:file-watcher" calling init()
xdk:client (1432047266503): Component "client:file-watcher" finished initialization
xdk:client (1432047266505): Component "client:external-links" finished initialization
xdk:client (1432047266506): Component "client:external-editors-runner" calling init()
xdk:client (1432047266506): Component "client:external-editors-runner" finished initialization
xdk:client (1432047266509): Component "client:resource-render-frame" finished delayed initialization
xdk:client (1432047266517): Component "client:tool-tip" finished initialization
xdk:client (1432047266521): Component "client:app-starter" finished initialization
xdk:client (1432047266523): Component "client:ui-builder-client" calling init()
xdk:client (1432047266523): Component "client:ui-builder-client" finished initialization
xdk:client (1432047266524): Component "client:dialog-box" finished initialization
xdk:client (1432047266524): Component "client:hot-keys" calling init()
xdk:client (1432047266524): Component "client:hot-keys" finished initialization
xdk:client (1432047266526): Component "client:settings-ui" finished initialization
xdk:client (1432047266527): Component "client:document-manager" calling init()
xdk:client (1432047266528): Component "client:document-manager" finished initialization
xdk:client (1432047266542): Component "client:aa-controller" calling init()
xdk:client (1432047266542): Component "client:aa-controller" finished initialization
xdk:client (1432047266565): Component "client:contenttype-registry" calling init()
xdk:client (1432047266566): Component "client:contenttype-registry" finished initialization
xdk:client (1432047266572): Component "client:editor-registry" finished initialization
xdk:client (1432047266574): Component "client:library-registry" calling init()
xdk:client (1432047266574): Component "client:library-registry" finished initialization
xdk:client (1432047266576): Component "client:cordova-registry" calling init()
xdk:client (1432047266576): Component "client:cordova-registry" waiting for delayed initialization
xdk:client (1432047266578): Component "client:device-discovery" calling init()
xdk:client (1432047266578): Component "client:device-discovery" waiting for delayed initialization
xdk:client (1432047266579): Component "client:hash-utils" finished initialization
xdk:client (1432047266595): Component "client:cordova" calling init()
xdk:client (1432047266595): Component "client:cordova" finished initialization
xdk:client (1432047266598): Component "client:device-discovery" finished delayed initialization
xdk:client (1432047266610): Component "client:resource-manager" calling init()
xdk:client (1432047266610): Component "client:resource-manager" waiting for delayed initialization
xdk:client (1432047266615): Component "client:resource-cocos2djs" calling init()
xdk:client (1432047266615): Component "client:resource-cocos2djs" finished initialization
xdk:client (1432047266616): Component "client:resource-phaser" calling init()
xdk:client (1432047266616): Component "client:resource-phaser" finished initialization
xdk:client (1432047266617): Component "client:resource-pixi" calling init()
xdk:client (1432047266617): Component "client:resource-pixi" finished initialization
xdk:client (1432047266618): Component "client:resource-plain" calling init()
xdk:client (1432047266618): Component "client:resource-plain" finished initialization
xdk:client (1432047266622): Component "client:appcenter-options" calling init()
xdk:client (1432047266623): Component "client:appcenter-options" waiting for delayed initialization
xdk:client (1432047266623): Component "client:services-tab" calling init()
xdk:client (1432047266624): Component "client:services-tab" finished initialization
xdk:client (1432047266625): Component "client:test-local-server" calling init()
xdk:client (1432047266644): Component "client:test-local-server" finished initialization
xdk:client (1432047266644): Component "client:tabs" finished initialization
xdk:client (1432047266647): Component "client:app" calling init()
xdk:client (1432047266654): Component "client:app" finished initialization
xdk:client (1432047266663): Component "client:quick-tour" calling init()
xdk:client (1432047266663): Component "client:quick-tour" finished initialization
xdk:client (1432047266670): Component "client:project-manager" calling init()
xdk:client (1432047266670): Component "client:project-manager" waiting for delayed initialization
xdk:client (1432047266673): Component "client:projects-renderers" calling init()
xdk:client (1432047266673): Component "client:projects-renderers" waiting for delayed initialization
xdk:client (1432047266673): Component "client:projects-renderers-iotapp" calling init()
xdk:client (1432047266673): Component "client:projects-renderers-iotapp" finished initialization
xdk:client (1432047266679): Component "client:resource-cocos2d" calling init()
xdk:client (1432047266679): Component "client:resource-cocos2d" waiting for delayed initialization
xdk:client (1432047266683): Component "client:platform-registry" calling init()
xdk:client (1432047266684): Component "client:platform-registry" finished initialization
xdk:client (1432047266685): Component "client:projecttype-registry" calling init()
xdk:client (1432047266685): Component "client:projecttype-registry" finished initialization
xdk:client (1432047266686): Component "client:navbar" starting import
xdk:client (1432047266686): Component "client:tweets" starting import
xdk:client (1432047266686): Component "client:projects-tab" starting import
xdk:client (1432047266686): Component "client:test-tab" starting import
xdk:client (1432047266686): Component "client:profilingTab" starting import
xdk:client (1432047266686): Component "client:emulator" starting import
xdk:client (1432047266686): Component "client:remote-tab" starting import
xdk:client (1432047266686): Component "client:build-tab" starting import
xdk:client (1432047266686): Component "client:editor-tab" starting import
xdk:client (1432047266686): Component "client:account" starting import
xdk:client (1432047266686): Component "client:project-selector" starting import
xdk:client (1432047266692): Component "client:cordova-registry" finished delayed initialization
xdk:client (1432047266692): Component "client:resource-cocos2d" finished delayed initialization
xdk:client (1432047266702): Component "client:projects-renderers-jsapp" calling init()
xdk:client (1432047266702): Component "client:projects-renderers-jsapp" finished initialization
xdk:client (1432047266702): Component "client:projects-renderers-webapp" calling init()
xdk:client (1432047266703): Component "client:projects-renderers-webapp" finished initialization
xdk:client (1432047266720): Component "client:projects-renderers" finished delayed initialization
xdk:client (1432047266726): Component "client:settings-db" finished delayed initialization
xdk:client (1432047266738): Component "client:editor" calling init()
xdk:client (1432047266739): Component "client:editor" finished initialization
xdk:client (1432047266739): Component "client:live-preview" calling init()
xdk:client (1432047266739): Component "client:live-preview" finished initialization
xdk:client (1432047266739): Component "client:editor-tab" getting UI region for "develop"
xdk:client (1432047266739): Component "client:editor-tab" calling init()
xdk:client (1432047266747): Component "client:editor-tab" waiting for delayed initialization
xdk:client (1432047266777): Component "client:account" getting UI region for "account"
xdk:client (1432047266777): Component "client:account" calling init()
xdk:client (1432047266779): Component "client:account" finished initialization
xdk:client (1432047266780): Component "client:project-selector" getting UI region for "project-selector"
xdk:client (1432047266780): Component "client:project-selector" calling init()
xdk:client (1432047266780): Component "client:project-selector" finished initialization
xdk:client (1432047266781): Component "client:tweets" finished initialization
xdk:client (1432047266782): Component "client:projects-tab" getting UI region for "project"
xdk:client (1432047266782): Component "client:projects-tab" calling init()
xdk:client (1432047266782): Component "client:projects-tab" waiting for delayed initialization
xdk:client (1432047266784): Component "client:test-tab" getting UI region for "test"
xdk:client (1432047266784): Component "client:test-tab" calling init()
xdk:client (1432047266794): Component "client:test-tab" finished initialization
xdk:client (1432047266796): Component "client:emulator" getting UI region for "emulate"
xdk:client (1432047266796): Component "client:emulator" calling init()
xdk:client (1432047266797): Component "client:emulator" finished initialization
xdk:client (1432047266798): Component "client:build-tab" getting UI region for "build"
xdk:client (1432047266798): Component "client:build-tab" calling init()
xdk:client (1432047266801): Component "client:build-tab" finished initialization
xdk:client (1432047266808): Component "client:navbar" getting UI region for "navbar-common"
xdk:client (1432047266808): Component "client:navbar" calling init()
client:navbar (1432047266809): navbar options: {"common":{"servicesVersion":"release-2015-ww19","xdkVariant":"xdk"},"updatePollingInterval":1800,"forceUpdate":false}
xdk:client (1432047266809): Component "client:navbar" finished initialization
xdk:client (1432047266828): Component "client:remote-tab" getting UI region for "debug"
xdk:client (1432047266828): Component "client:remote-tab" calling init()
xdk:client (1432047266937): Component "client:remote-tab" finished initialization
client:adb (1432047266950): Using existing adb at "D:\bin\adb\adb.exe"
xdk:client (1432047266984): Component "client:profilingTab" getting UI region for "profile"
xdk:client (1432047266985): Component "client:profilingTab" calling init()
xdk:client (1432047266986): Component "client:profilingTab" finished initialization
xdk:client (1432047266989): Component "client:adb" finished delayed initialization
client:appcenter-options (1432047267173): Fetch Status: 1, Message: Feched latest appcenter-options info because network is available.
xdk:client (1432047267174): Component "client:appcenter-options" finished delayed initialization
xdk:client (1432047268180): Component "client:project-manager" finished delayed initialization
xdk:client (1432047268192): Component "client:resource-manager" finished delayed initialization
xdk:client (1432047268192): Component "client:projects-tab" finished delayed initialization
xdk:client (1432047268192): Component "client:projects-list" starting import
xdk:client (1432047268192): Component "client:projects-info" starting import
xdk:client (1432047268192): Component "client:projects-create-list" starting import
xdk:client (1432047268192): Component "client:projects-create-info" starting import
xdk:client (1432047268230): Component "client:projects-list" getting UI region for "existing-list"
xdk:client (1432047268230): Component "client:projects-list" calling init()
xdk:client (1432047268231): Component "client:projects-list" finished initialization
xdk:client (1432047268281): Component "client:projects-info" getting UI region for "existing-info"
xdk:client (1432047268281): Component "client:projects-info" calling init()
xdk:client (1432047268282): Component "client:projects-info" finished initialization
xdk:client (1432047268290): Component "client:projects-create-info" getting UI region for "create-info"
xdk:client (1432047268290): Component "client:projects-create-info" calling init()
xdk:client (1432047268290): Component "client:projects-create-info" finished initialization
xdk:client (1432047268293): Component "client:projects-create-list" getting UI region for "create-list"
xdk:client (1432047268294): Component "client:projects-create-list" calling init()
xdk:client (1432047268294): Component "client:projects-create-list" finished initialization
xdk:client (1432047268808): memmrk:    44366052    62750336
xdk:server (1432047269315): memmrk:    27104440    43419136
xdk:client (1432047269680): Component "client:editor-tab" finished delayed initialization
xdk:client (1432047273792): memmrk:    65235500    89572480
xdk:server (1432047274315): memmrk:    54832556    77241344
xdk:client (1432047278792): memmrk:    71186128    92607360
xdk:server (1432047279315): memmrk:    55289408    77241344
xdk:client (1432047283006): Component "client:persistance" finished delayed initialization
xdk:client (1432047283007): Component "client:app" calling start()
xdk:client (1432047283028): Component "client:app" finished start()
xdk:client (1432047283028): Component "client:navbar" calling start()
xdk:client (1432047283039): Component "client:navbar" finished start()
xdk:client (1432047283039): Component "client:project-manager" calling start()
xdk:client (1432047283039): Component "client:project-manager" finished start()
xdk:client (1432047283039): Component "client:aa-controller" calling start()
xdk:client (1432047283040): Component "client:aa-controller" finished start()
xdk:client (1432047283040): Component "client:projects-tab" calling start()
xdk:client (1432047283047): Component "client:projects-tab" finished start()
xdk:client (1432047283047): Component "client:projects-list" calling start()
xdk:client (1432047283050): Component "client:projects-list" finished start()
xdk:client (1432047283050): Component "client:projects-info" calling start()
xdk:client (1432047283153): Component "client:projects-info" finished start()
xdk:client (1432047283154): Component "client:projects-create-list" calling start()
xdk:client (1432047283165): Component "client:projects-create-list" finished start()
xdk:client (1432047283165): Component "client:projects-create-info" calling start()
xdk:client (1432047283169): Component "client:projects-create-info" finished start()
xdk:client (1432047283169): Component "client:test-tab" calling start()
xdk:client (1432047283172): Component "client:test-tab" finished start()
xdk:client (1432047283172): Component "client:profilingTab" calling start()
xdk:client (1432047283206): Component "client:profilingTab" finished start()
xdk:client (1432047283206): Component "client:emulator" calling start()
xdk:client (1432047283207): Component "client:emulator" finished start()
xdk:client (1432047283207): Component "client:remote-tab" calling start()
xdk:client (1432047283210): Component "client:remote-tab" finished start()
xdk:client (1432047283210): Component "client:build-tab" calling start()
xdk:client (1432047283212): Component "client:build-tab" finished start()
xdk:client (1432047283212): Component "client:active-sync" calling start()
xdk:client (1432047283212): Component "client:active-sync" finished start()
xdk:client (1432047283212): Component "client:apk-installer" calling start()
xdk:client (1432047283212): Component "client:apk-installer" finished start()
xdk:client (1432047283213): Component "client:resource-manager" calling start()
xdk:client (1432047283213): Component "client:resource-manager" finished start()
xdk:client (1432047283213): Component "client:resource-cocos2d" calling start()
xdk:client (1432047283213): Component "client:resource-cocos2d" finished start()
xdk:client (1432047283213): Component "client:resource-cocos2djs" calling start()
xdk:client (1432047283214): Component "client:resource-cocos2djs" finished start()
xdk:client (1432047283214): Component "client:resource-phaser" calling start()
xdk:client (1432047283214): Component "client:resource-phaser" finished start()
xdk:client (1432047283214): Component "client:resource-pixi" calling start()
xdk:client (1432047283214): Component "client:resource-pixi" finished start()
xdk:client (1432047283214): Component "client:resource-easeljs" calling start()
xdk:client (1432047283214): Component "client:resource-easeljs" finished start()
xdk:client (1432047283214): Component "client:resource-plain" calling start()
xdk:client (1432047283214): Component "client:resource-plain" finished start()
xdk:client (1432047283214): Component "client:resource-render-frame" calling start()
xdk:client (1432047283214): Component "client:resource-render-frame" finished start()
xdk:client (1432047283214): Component "client:resource-util" calling start()
xdk:client (1432047283214): Component "client:resource-util" finished start()
xdk:client (1432047283214): Component "client:editor" calling start()
xdk:client (1432047283214): Component "client:editor" finished start()
xdk:client (1432047283214): Component "client:editor-tab" calling start()
xdk:client (1432047283232): Component "client:editor-tab" finished start()
xdk:client (1432047283232): Component "client:live-preview" calling start()
xdk:client (1432047283232): Component "client:live-preview" finished start()
xdk:client (1432047283232): Component "client:account" calling start()
xdk:client (1432047283232): Component "client:account" finished start()
xdk:client (1432047283232): Component "client:project-selector" calling start()
xdk:client (1432047283235): Component "client:project-selector" finished start()
xdk:client (1432047283235): Component "client:app-starter" calling start()
xdk:client (1432047283235): Component "client:app-starter" finished start()
xdk:client (1432047283235): Component "client:ui-builder-client" calling start()
xdk:client (1432047283236): Component "client:ui-builder-client" finished start()
xdk:client (1432047283236): Component "client:project-meta" calling start()
xdk:client (1432047283236): Component "client:project-meta" finished start()
xdk:client (1432047283236): Component "client:cordova-registry" calling start()
xdk:client (1432047283236): Component "client:cordova-registry" finished start()
xdk:client (1432047283236): Component "client:adb" calling start()
xdk:client (1432047283236): Component "client:adb" finished start()
xdk:client (1432047283236): Component "client:iosdb" calling start()
xdk:client (1432047283237): Component "client:iosdb" finished start()
xdk:client (1432047283237): Component "client:device-discovery" calling start()
xdk:client (1432047283239): Component "client:device-discovery" finished start()
xdk:client (1432047283239): Component "client:test-local-server" calling start()
xdk:client (1432047283239): Component "client:test-local-server" finished start()
xdk:client (1432047283239): Component "client:quick-tour" calling start()
xdk:client (1432047283239): Component "client:quick-tour" finished start()
xdk:client (1432047283239): Component "client:hot-keys" calling start()
xdk:client (1432047283241): Component "client:hot-keys" finished start()
xdk:client (1432047283241): Component "client:persistance" calling start()
xdk:client (1432047283242): Component "client:persistance" finished start()
xdk:client (1432047283242): Component "client:file-watcher" calling start()
xdk:client (1432047283242): Component "client:file-watcher" finished start()
xdk:client (1432047283242): Component "client:cordova" calling start()
xdk:client (1432047283243): Component "client:cordova" finished start()
xdk:client (1432047283243): Component "client:external-editors-runner" calling start()
xdk:client (1432047283243): Component "client:external-editors-runner" finished start()
xdk:client (1432047283245): Intel XDK is initialized now
client:navbar (1432047283278): pollForUpdates called
xdk:client (1432047284226): memmrk:    49314008    100720640
client:navbar (1432047284263): polling up-to-date
xdk:server (1432047284317): memmrk:    57870600    77241344
xdk:client (1432047289227): memmrk:    51700960    100720640
xdk:server (1432047289317): memmrk:    25929432    63696256
xdk:client (1432047294228): memmrk:    52150960    100720640
xdk:server (1432047294317): memmrk:    25942456    63696256
xdk:client (1432047299229): memmrk:    52438156    100720640
xdk:server (1432047299318): memmrk:    20117384    35791616
xdk:client (1432047304229): memmrk:    52856800    100720640
xdk:server (1432047304319): memmrk:    19233256    27702656
xdk:client (1432047309230): memmrk:    53127924    100720640
xdk:server (1432047309319): memmrk:    19242000    27702656
xdk:client (1432047314231): memmrk:    53546412    100720640
xdk:server (1432047314319): memmrk:    17948748    27702656
xdk:client (1432047319249): memmrk:    56078172    100720640
xdk:server (1432047319321): memmrk:    17958324    27702656
xdk:client (1432047324248): memmrk:    56650976    100720640
xdk:server (1432047324320): memmrk:    17573728    24679936
xdk:client (1432047329248): memmrk:    59550036    100720640
xdk:server (1432047329320): memmrk:    17543008    25728512
xdk:client (1432047334250): memmrk:    60465152    100720640
xdk:server (1432047334322): memmrk:    17072820    25728512
xdk:client (1432047339263): memmrk:    61980900    100720640
xdk:server (1432047339322): memmrk:    17079724    25728512
xdk:client (1432047344263): memmrk:    57480576    100720640
xdk:server (1432047344322): memmrk:    17086120    25728512
xdk:client (1432047349263): memmrk:    58607468    100720640
xdk:server (1432047349322): memmrk:    17092516    25728512
xdk:client (1432047354264): memmrk:    60191892    100720640
xdk:server (1432047354324): memmrk:    17098912    25728512
xdk:client (1432047359314): memmrk:    61095260    100720640
xdk:server (1432047359324): memmrk:    17104384    25728512
xdk:client (1432047364315): memmrk:    62848084    100720640
xdk:server (1432047364324): memmrk:    17110780    25728512
xdk:client (1432047369318): memmrk:    61380528    101736320
xdk:server (1432047369325): memmrk:    17117172    25728512
xdk:client (1432047374317): memmrk:    62751384    101736320
xdk:server (1432047374326): memmrk:    17123568    25728512
xdk:client (1432047379317): memmrk:    63574788    101736320
xdk:server (1432047379326): memmrk:    17129964    25728512
xdk:client (1432047384321): memmrk:    64883104    101736320
xdk:server (1432047384329): memmrk:    17136360    25728512
xdk:client (1432047389322): memmrk:    44480960    99241856
xdk:server (1432047389330): memmrk:    17142756    25728512
xdk:client (1432047394323): memmrk:    44969272    99241856
xdk:server (1432047394331): memmrk:    17149152    25728512
xdk:client (1432047399323): memmrk:    45261888    99241856
xdk:server (1432047399331): memmrk:    17155548    25728512
xdk:client (1432047404324): memmrk:    41799768    63272576
xdk:server (1432047404332): memmrk:    17161944    25728512
xdk:client (1432047409325): memmrk:    42078644    63272576
xdk:server (1432047409332): memmrk:    17168340    25728512
xdk:client (1432047414325): memmrk:    43727288    66418304
xdk:server (1432047414333): memmrk:    17174736    25728512
xdk:client (1432047419325): memmrk:    44323164    66418304
xdk:server (1432047419333): memmrk:    17181132    25728512
xdk:client (1432047424327): memmrk:    43387876    66418304
xdk:server (1432047424334): memmrk:    17187528    25728512
xdk:client (1432047429327): memmrk:    43925780    66418304
xdk:server (1432047429335): memmrk:    17195228    25728512
xdk:server (1432047434335): memmrk:    17202868    25728512
xdk:client (1432047434337): memmrk:    45988424    66418304
client:emulator (1432047439129): Device Emulator :: Environment Warming Up (Tea. Earl Gray. Hot.)
client:emulator (1432047439314): appmobi_plus_cordova :: Emulator changing to project mmt_1
xdk:server (1432047439336): memmrk:    18466080    26744192
client:emulator (1432047439320): appmobi_plus_cordova :: _xdkLoad for project mmt_1
xdk:client (1432047439355): memmrk:    54694312    73647488
client:emulator (1432047442602): appmobi_plus_cordova :: Initialization Finished (Make it so.)
server:emulator-webserver (1432047442607): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442608): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/index.html
server:emulator-webserver (1432047442608): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/index.html
client:emulator (1432047442602): appmobi_plus_cordova :: frame appended to document
server:emulator-webserver (1432047442731): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442732): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
server:emulator-webserver (1432047442732): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
server:emulator-webserver (1432047442733): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442733): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js
server:emulator-webserver (1432047442734): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js
server:emulator-webserver (1432047442736): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442736): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js
server:emulator-webserver (1432047442736): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js
server:emulator-webserver (1432047442738): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442738): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js
server:emulator-webserver (1432047442738): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js
server:emulator-webserver (1432047442745): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442745): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js
server:emulator-webserver (1432047442745): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js
server:emulator-webserver (1432047442750): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442750): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/login_controller.js
server:emulator-webserver (1432047442751): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/login_controller.js
server:emulator-webserver (1432047442754): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442754): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/layout_controller.js
server:emulator-webserver (1432047442754): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/layout_controller.js
server:emulator-webserver (1432047442758): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442758): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js
server:emulator-webserver (1432047442759): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js
server:emulator-webserver (1432047442765): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442765): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/login_service.js
server:emulator-webserver (1432047442765): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/login_service.js
server:emulator-webserver (1432047442767): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442767): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/layout_service.js
server:emulator-webserver (1432047442767): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/layout_service.js
server:emulator-webserver (1432047442768): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442768): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/routing_service.js
server:emulator-webserver (1432047442769): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/routing_service.js
server:emulator-webserver (1432047442773): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442773): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/cordova.js
server:emulator-webserver (1432047442774): Send cordova.js from D:\xdk\components\server\emulator\resources\cordova.js
server:emulator-webserver (1432047442776): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047442776): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/xhr.js
server:emulator-webserver (1432047442776): xhr.js request fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/xhr.js
server:emulator-webserver (1432047442777): sending empty contents for missing xhr.js file
server:emulator-webserver (1432047443442): emulator-webserver: got a request for userapp.
client:emulator (1432047443442): appmobi_plus_cordova :: Emulation frame loaded
server:emulator-webserver (1432047443442): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view1.html
server:emulator-webserver (1432047443442): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view1.html
server:emulator-webserver (1432047443444): HTML file doesn't look like entire document; skipping injection
client:emulator (1432047443446): appmobi_plus_cordova :: fired appMobi.device.ready event!
client:emulator (1432047443616): appmobi_plus_cordova :: tinyHipposLoaded cleared _loading/_delayedproject
server:emulator-webserver (1432047443616): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443616): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/cordova_plugins.js
client:emulator (1432047443617): appmobi_plus_cordova :: [emulator] file watcher started
server:emulator-webserver (1432047443616): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/cordova_plugins.js
server:emulator-webserver (1432047443685): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443685): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/Acceleration.js
server:emulator-webserver (1432047443685): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/Acceleration.js
server:emulator-webserver (1432047443686): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443686): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/accelerometer.js
server:emulator-webserver (1432047443687): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/accelerometer.js
server:emulator-webserver (1432047443687): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443687): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraConstants.js
server:emulator-webserver (1432047443688): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraConstants.js
server:emulator-webserver (1432047443689): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443689): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraPopoverOptions.js
server:emulator-webserver (1432047443689): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraPopoverOptions.js
server:emulator-webserver (1432047443698): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443699): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/Camera.js
server:emulator-webserver (1432047443699): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/Camera.js
server:emulator-webserver (1432047443700): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443700): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/ios/CameraPopoverHandle.js
server:emulator-webserver (1432047443700): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/ios/CameraPopoverHandle.js
server:emulator-webserver (1432047443704): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443704): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureAudioOptions.js
server:emulator-webserver (1432047443704): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureAudioOptions.js
server:emulator-webserver (1432047443706): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443706): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureImageOptions.js
server:emulator-webserver (1432047443707): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureImageOptions.js
server:emulator-webserver (1432047443714): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443714): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureVideoOptions.js
server:emulator-webserver (1432047443714): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureVideoOptions.js
server:emulator-webserver (1432047443715): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443715): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureError.js
server:emulator-webserver (1432047443715): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureError.js
server:emulator-webserver (1432047443720): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443720): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFileData.js
server:emulator-webserver (1432047443720): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFileData.js
server:emulator-webserver (1432047443723): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443723): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFile.js
server:emulator-webserver (1432047443723): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFile.js
server:emulator-webserver (1432047443725): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443726): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/capture.js
server:emulator-webserver (1432047443726): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/capture.js
server:emulator-webserver (1432047443727): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443727): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassError.js
server:emulator-webserver (1432047443727): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassError.js
server:emulator-webserver (1432047443734): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443734): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassHeading.js
server:emulator-webserver (1432047443734): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassHeading.js
server:emulator-webserver (1432047443737): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443737): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/compass.js
server:emulator-webserver (1432047443737): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/compass.js
server:emulator-webserver (1432047443739): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443739): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/network.js
server:emulator-webserver (1432047443740): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/network.js
server:emulator-webserver (1432047443742): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443743): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/Connection.js
server:emulator-webserver (1432047443743): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/Connection.js
server:emulator-webserver (1432047443751): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443751): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/contacts.js
server:emulator-webserver (1432047443752): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/contacts.js
server:emulator-webserver (1432047443755): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443755): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/Contact.js
server:emulator-webserver (1432047443755): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/Contact.js
server:emulator-webserver (1432047443759): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443759): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactAddress.js
server:emulator-webserver (1432047443760): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactAddress.js
server:emulator-webserver (1432047443761): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443762): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactError.js
server:emulator-webserver (1432047443762): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactError.js
server:emulator-webserver (1432047443771): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443771): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactField.js
server:emulator-webserver (1432047443772): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactField.js
server:emulator-webserver (1432047443779): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443779): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFindOptions.js
server:emulator-webserver (1432047443780): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFindOptions.js
server:emulator-webserver (1432047443782): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443782): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactName.js
server:emulator-webserver (1432047443782): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactName.js
server:emulator-webserver (1432047443784): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443784): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactOrganization.js
server:emulator-webserver (1432047443784): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactOrganization.js
server:emulator-webserver (1432047443787): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443787): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFieldType.js
server:emulator-webserver (1432047443788): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFieldType.js
server:emulator-webserver (1432047443796): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443796): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/contacts.js
server:emulator-webserver (1432047443797): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/contacts.js
server:emulator-webserver (1432047443798): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443798): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/Contact.js
server:emulator-webserver (1432047443798): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/Contact.js
server:emulator-webserver (1432047443799): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443799): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device/www/device.js
server:emulator-webserver (1432047443799): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device/www/device.js
server:emulator-webserver (1432047443804): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443804): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.battery-status/www/battery.js
server:emulator-webserver (1432047443804): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.battery-status/www/battery.js
server:emulator-webserver (1432047443809): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443809): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransferError.js
server:emulator-webserver (1432047443810): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransferError.js
server:emulator-webserver (1432047443811): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443811): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransfer.js
server:emulator-webserver (1432047443811): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransfer.js
server:emulator-webserver (1432047443812): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443812): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Coordinates.js
server:emulator-webserver (1432047443812): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Coordinates.js
server:emulator-webserver (1432047443823): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443823): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/PositionError.js
server:emulator-webserver (1432047443823): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/PositionError.js
server:emulator-webserver (1432047443828): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443828): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Position.js
server:emulator-webserver (1432047443829): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Position.js
server:emulator-webserver (1432047443832): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443832): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/geolocation.js
server:emulator-webserver (1432047443833): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/geolocation.js
server:emulator-webserver (1432047443834): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443834): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/GlobalizationError.js
server:emulator-webserver (1432047443834): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/GlobalizationError.js
server:emulator-webserver (1432047443838): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443838): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/globalization.js
server:emulator-webserver (1432047443838): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/globalization.js
server:emulator-webserver (1432047443842): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443842): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.inappbrowser/www/inappbrowser.js
server:emulator-webserver (1432047443843): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.inappbrowser/www/inappbrowser.js
server:emulator-webserver (1432047443846): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443846): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/MediaError.js
server:emulator-webserver (1432047443847): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/MediaError.js
server:emulator-webserver (1432047443848): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443848): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/Media.js
server:emulator-webserver (1432047443849): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/Media.js
server:emulator-webserver (1432047443853): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443853): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.dialogs/www/notification.js
server:emulator-webserver (1432047443854): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.dialogs/www/notification.js
server:emulator-webserver (1432047443857): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443857): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.vibration/www/vibration.js
server:emulator-webserver (1432047443862): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.vibration/www/vibration.js
server:emulator-webserver (1432047443872): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443872): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.splashscreen/www/splashscreen.js
server:emulator-webserver (1432047443872): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.splashscreen/www/splashscreen.js
server:emulator-webserver (1432047443874): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443874): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.statusbar/www/statusbar.js
server:emulator-webserver (1432047443874): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.statusbar/www/statusbar.js
server:emulator-webserver (1432047443878): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443878): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryEntry.js
server:emulator-webserver (1432047443878): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryEntry.js
server:emulator-webserver (1432047443881): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443881): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryReader.js
server:emulator-webserver (1432047443882): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryReader.js
server:emulator-webserver (1432047443884): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443884): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Entry.js
server:emulator-webserver (1432047443885): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Entry.js
server:emulator-webserver (1432047443886): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443886): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/File.js
server:emulator-webserver (1432047443886): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/File.js
server:emulator-webserver (1432047443891): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443891): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileEntry.js
server:emulator-webserver (1432047443891): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileEntry.js
server:emulator-webserver (1432047443892): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443892): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileError.js
server:emulator-webserver (1432047443893): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileError.js
server:emulator-webserver (1432047443897): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443897): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileReader.js
server:emulator-webserver (1432047443898): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileReader.js
server:emulator-webserver (1432047443899): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443899): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileSystem.js
server:emulator-webserver (1432047443899): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileSystem.js
server:emulator-webserver (1432047443905): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443905): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadOptions.js
server:emulator-webserver (1432047443906): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadOptions.js
server:emulator-webserver (1432047443907): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443907): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadResult.js
server:emulator-webserver (1432047443908): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadResult.js
server:emulator-webserver (1432047443915): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443915): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileWriter.js
server:emulator-webserver (1432047443915): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileWriter.js
server:emulator-webserver (1432047443920): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443920): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Flags.js
server:emulator-webserver (1432047443920): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Flags.js
server:emulator-webserver (1432047443921): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443921): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/LocalFileSystem.js
server:emulator-webserver (1432047443922): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/LocalFileSystem.js
server:emulator-webserver (1432047443922): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443922): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Metadata.js
server:emulator-webserver (1432047443923): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Metadata.js
server:emulator-webserver (1432047443926): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443926): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ProgressEvent.js
server:emulator-webserver (1432047443927): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ProgressEvent.js
server:emulator-webserver (1432047443930): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443930): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems.js
server:emulator-webserver (1432047443931): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems.js
server:emulator-webserver (1432047443934): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443934): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/requestFileSystem.js
server:emulator-webserver (1432047443934): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/requestFileSystem.js
server:emulator-webserver (1432047443937): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443937): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/resolveLocalFileSystemURI.js
server:emulator-webserver (1432047443937): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/resolveLocalFileSystemURI.js
server:emulator-webserver (1432047443940): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443940): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ios/FileSystem.js
server:emulator-webserver (1432047443940): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ios/FileSystem.js
server:emulator-webserver (1432047443942): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443942): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems-roots.js
server:emulator-webserver (1432047443943): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems-roots.js
server:emulator-webserver (1432047443946): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047443946): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystemPaths.js
server:emulator-webserver (1432047443947): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystemPaths.js
xdk:server (1432047444339): memmrk:    42774688    57638656
xdk:client (1432047444582): memmrk:    110167600    131804416
client:emulator (1432047444604): appmobi_plus_cordova :: Native back button handler was detached.
xdk:server (1432047449339): memmrk:    42781684    57638656
xdk:client (1432047449568): memmrk:    116776416    136882816
server:emulator-webserver (1432047451580): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047451580): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
server:emulator-webserver (1432047451580): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
server:emulator-webserver (1432047451584): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047451584): req.path = /http-services/emulator-webserver/ripple/userapp/C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map
server:emulator-webserver (1432047451584): Other file request, fullPath = C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map
server:emulator-webserver (1432047451591): Error testing path C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map; msg = ERROR: name must either start with slash or use base option
Error
    at ComponentError (D:\xdk\core-modules\public\component-error.js:17:1122)
    at new ServiceError (D:\xdk\core-modules\public\service-error.js:17:317)
    at _ensureStartsWithSlashOrUsesBaseOption (D:\xdk\components\server\userfs\filter\sanitize.js:17:800)
    at D:\xdk\components\server\userfs\filter\sanitize.js:17:1227
    at Array.forEach (native)
    at Function._.each._.forEach (D:\xdk\node_modules\underscore\underscore.js:79:11)
    at D:\xdk\components\server\userfs\filter\sanitize.js:17:1120
    at beforeFilter (D:\xdk\components\server\userfs\filter\sanitize.js:17:1082)
xdk:server (1432047454339): memmrk:    37727676    58654336
client:emulator (1432047454390): appmobi_plus_cordova :: Emulator restarting mmt_1
client:emulator (1432047454397): appmobi_plus_cordova :: _xdkLoad for project mmt_1
xdk:client (1432047454568): memmrk:    48891716    83076096
client:emulator (1432047456547): appmobi_plus_cordova :: Initialization Finished (Make it so.)
server:emulator-webserver (1432047456551): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456551): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/index.html
server:emulator-webserver (1432047456551): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/index.html
client:emulator (1432047456549): appmobi_plus_cordova :: frame appended to document
server:emulator-webserver (1432047456669): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456669): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
server:emulator-webserver (1432047456669): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
server:emulator-webserver (1432047456670): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456670): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js
server:emulator-webserver (1432047456671): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js
server:emulator-webserver (1432047456680): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456680): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js
server:emulator-webserver (1432047456680): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js
server:emulator-webserver (1432047456681): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456681): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js
server:emulator-webserver (1432047456682): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js
server:emulator-webserver (1432047456683): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456683): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js
server:emulator-webserver (1432047456683): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js
server:emulator-webserver (1432047456691): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456691): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/login_controller.js
server:emulator-webserver (1432047456691): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/login_controller.js
server:emulator-webserver (1432047456695): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456695): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/layout_controller.js
server:emulator-webserver (1432047456695): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/layout_controller.js
server:emulator-webserver (1432047456696): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456696): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js
server:emulator-webserver (1432047456696): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js
server:emulator-webserver (1432047456697): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456697): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/login_service.js
server:emulator-webserver (1432047456698): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/login_service.js
server:emulator-webserver (1432047456703): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456703): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/layout_service.js
server:emulator-webserver (1432047456703): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/layout_service.js
server:emulator-webserver (1432047456706): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456706): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/routing_service.js
server:emulator-webserver (1432047456706): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/routing_service.js
server:emulator-webserver (1432047456709): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456709): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/cordova.js
server:emulator-webserver (1432047456711): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047456711): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/xhr.js
server:emulator-webserver (1432047456712): xhr.js request fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/xhr.js
server:emulator-webserver (1432047456713): Send cordova.js from D:\xdk\components\server\emulator\resources\cordova.js
server:emulator-webserver (1432047456714): sending empty contents for missing xhr.js file
server:emulator-webserver (1432047457458): emulator-webserver: got a request for userapp.
client:emulator (1432047457458): appmobi_plus_cordova :: Emulation frame loaded
server:emulator-webserver (1432047457458): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view1.html
server:emulator-webserver (1432047457458): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view1.html
server:emulator-webserver (1432047457460): HTML file doesn't look like entire document; skipping injection
client:emulator (1432047457461): appmobi_plus_cordova :: fired appMobi.device.ready event!
client:emulator (1432047457502): appmobi_plus_cordova :: tinyHipposLoaded cleared _loading/_delayedproject
client:emulator (1432047457504): appmobi_plus_cordova :: [emulator] file watcher started
server:emulator-webserver (1432047457518): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457518): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/cordova_plugins.js
server:emulator-webserver (1432047457518): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/cordova_plugins.js
server:emulator-webserver (1432047457621): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457621): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/Acceleration.js
server:emulator-webserver (1432047457621): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/Acceleration.js
server:emulator-webserver (1432047457622): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457622): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/accelerometer.js
server:emulator-webserver (1432047457622): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/accelerometer.js
server:emulator-webserver (1432047457627): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457627): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraConstants.js
server:emulator-webserver (1432047457627): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraConstants.js
server:emulator-webserver (1432047457635): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457635): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraPopoverOptions.js
server:emulator-webserver (1432047457644): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraPopoverOptions.js
server:emulator-webserver (1432047457655): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457655): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/Camera.js
server:emulator-webserver (1432047457656): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/Camera.js
server:emulator-webserver (1432047457666): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457666): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/ios/CameraPopoverHandle.js
server:emulator-webserver (1432047457667): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/ios/CameraPopoverHandle.js
server:emulator-webserver (1432047457668): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457668): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureAudioOptions.js
server:emulator-webserver (1432047457669): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureAudioOptions.js
server:emulator-webserver (1432047457676): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457676): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureImageOptions.js
server:emulator-webserver (1432047457677): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureImageOptions.js
server:emulator-webserver (1432047457679): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457679): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureVideoOptions.js
server:emulator-webserver (1432047457680): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureVideoOptions.js
server:emulator-webserver (1432047457687): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457687): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureError.js
server:emulator-webserver (1432047457688): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureError.js
server:emulator-webserver (1432047457689): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457689): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFileData.js
server:emulator-webserver (1432047457690): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFileData.js
server:emulator-webserver (1432047457692): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457692): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFile.js
server:emulator-webserver (1432047457693): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFile.js
server:emulator-webserver (1432047457699): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457699): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/capture.js
server:emulator-webserver (1432047457700): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/capture.js
server:emulator-webserver (1432047457701): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457701): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassError.js
server:emulator-webserver (1432047457702): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassError.js
server:emulator-webserver (1432047457709): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457710): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassHeading.js
server:emulator-webserver (1432047457710): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassHeading.js
server:emulator-webserver (1432047457712): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457712): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/compass.js
server:emulator-webserver (1432047457712): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/compass.js
server:emulator-webserver (1432047457719): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457719): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/network.js
server:emulator-webserver (1432047457720): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/network.js
server:emulator-webserver (1432047457721): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457721): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/Connection.js
server:emulator-webserver (1432047457722): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/Connection.js
server:emulator-webserver (1432047457724): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457724): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/contacts.js
server:emulator-webserver (1432047457724): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/contacts.js
server:emulator-webserver (1432047457732): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457732): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/Contact.js
server:emulator-webserver (1432047457732): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/Contact.js
server:emulator-webserver (1432047457734): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457734): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactAddress.js
server:emulator-webserver (1432047457734): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactAddress.js
server:emulator-webserver (1432047457744): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457744): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactError.js
server:emulator-webserver (1432047457745): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactError.js
server:emulator-webserver (1432047457746): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457746): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactField.js
server:emulator-webserver (1432047457747): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactField.js
server:emulator-webserver (1432047457754): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457754): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFindOptions.js
server:emulator-webserver (1432047457755): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFindOptions.js
server:emulator-webserver (1432047457757): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457757): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactName.js
server:emulator-webserver (1432047457757): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactName.js
server:emulator-webserver (1432047457758): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457759): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactOrganization.js
server:emulator-webserver (1432047457759): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactOrganization.js
server:emulator-webserver (1432047457769): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457769): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFieldType.js
server:emulator-webserver (1432047457770): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFieldType.js
server:emulator-webserver (1432047457771): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457771): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/contacts.js
server:emulator-webserver (1432047457772): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/contacts.js
server:emulator-webserver (1432047457778): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457778): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/Contact.js
server:emulator-webserver (1432047457779): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/Contact.js
server:emulator-webserver (1432047457784): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457784): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device/www/device.js
server:emulator-webserver (1432047457784): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device/www/device.js
server:emulator-webserver (1432047457786): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457786): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.battery-status/www/battery.js
server:emulator-webserver (1432047457786): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.battery-status/www/battery.js
server:emulator-webserver (1432047457804): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457804): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransferError.js
server:emulator-webserver (1432047457804): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransferError.js
server:emulator-webserver (1432047457806): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457806): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransfer.js
server:emulator-webserver (1432047457806): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransfer.js
server:emulator-webserver (1432047457807): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457807): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Coordinates.js
server:emulator-webserver (1432047457808): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Coordinates.js
server:emulator-webserver (1432047457813): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457814): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/PositionError.js
server:emulator-webserver (1432047457814): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/PositionError.js
server:emulator-webserver (1432047457815): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457815): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Position.js
server:emulator-webserver (1432047457815): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Position.js
server:emulator-webserver (1432047457829): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457829): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/geolocation.js
server:emulator-webserver (1432047457829): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/geolocation.js
server:emulator-webserver (1432047457834): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457834): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/GlobalizationError.js
server:emulator-webserver (1432047457835): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/GlobalizationError.js
server:emulator-webserver (1432047457840): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457840): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/globalization.js
server:emulator-webserver (1432047457841): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/globalization.js
server:emulator-webserver (1432047457843): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457843): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.inappbrowser/www/inappbrowser.js
server:emulator-webserver (1432047457843): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.inappbrowser/www/inappbrowser.js
server:emulator-webserver (1432047457845): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457845): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/MediaError.js
server:emulator-webserver (1432047457845): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/MediaError.js
server:emulator-webserver (1432047457850): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457850): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/Media.js
server:emulator-webserver (1432047457850): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/Media.js
server:emulator-webserver (1432047457852): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457852): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.dialogs/www/notification.js
server:emulator-webserver (1432047457852): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.dialogs/www/notification.js
server:emulator-webserver (1432047457857): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457857): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.vibration/www/vibration.js
server:emulator-webserver (1432047457857): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.vibration/www/vibration.js
server:emulator-webserver (1432047457859): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457859): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.splashscreen/www/splashscreen.js
server:emulator-webserver (1432047457859): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.splashscreen/www/splashscreen.js
server:emulator-webserver (1432047457860): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457860): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.statusbar/www/statusbar.js
server:emulator-webserver (1432047457860): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.statusbar/www/statusbar.js
server:emulator-webserver (1432047457865): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457865): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryEntry.js
server:emulator-webserver (1432047457866): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryEntry.js
server:emulator-webserver (1432047457867): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457867): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryReader.js
server:emulator-webserver (1432047457868): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryReader.js
server:emulator-webserver (1432047457874): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457874): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Entry.js
server:emulator-webserver (1432047457874): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Entry.js
server:emulator-webserver (1432047457876): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457876): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/File.js
server:emulator-webserver (1432047457876): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/File.js
server:emulator-webserver (1432047457878): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457878): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileEntry.js
server:emulator-webserver (1432047457878): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileEntry.js
server:emulator-webserver (1432047457891): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457891): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileError.js
server:emulator-webserver (1432047457892): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileError.js
server:emulator-webserver (1432047457893): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457893): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileReader.js
server:emulator-webserver (1432047457894): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileReader.js
server:emulator-webserver (1432047457900): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457900): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileSystem.js
server:emulator-webserver (1432047457901): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileSystem.js
server:emulator-webserver (1432047457903): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457903): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadOptions.js
server:emulator-webserver (1432047457903): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadOptions.js
server:emulator-webserver (1432047457904): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457904): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadResult.js
server:emulator-webserver (1432047457905): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadResult.js
server:emulator-webserver (1432047457916): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457916): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileWriter.js
server:emulator-webserver (1432047457917): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileWriter.js
server:emulator-webserver (1432047457919): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457919): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Flags.js
server:emulator-webserver (1432047457919): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Flags.js
server:emulator-webserver (1432047457927): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457927): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/LocalFileSystem.js
server:emulator-webserver (1432047457927): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/LocalFileSystem.js
server:emulator-webserver (1432047457928): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457928): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Metadata.js
server:emulator-webserver (1432047457929): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Metadata.js
server:emulator-webserver (1432047457930): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457931): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ProgressEvent.js
server:emulator-webserver (1432047457931): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ProgressEvent.js
server:emulator-webserver (1432047457941): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457941): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems.js
server:emulator-webserver (1432047457942): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems.js
server:emulator-webserver (1432047457944): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457944): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/requestFileSystem.js
server:emulator-webserver (1432047457944): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/requestFileSystem.js
server:emulator-webserver (1432047457953): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457953): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/resolveLocalFileSystemURI.js
server:emulator-webserver (1432047457954): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/resolveLocalFileSystemURI.js
server:emulator-webserver (1432047457956): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457956): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ios/FileSystem.js
server:emulator-webserver (1432047457956): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ios/FileSystem.js
server:emulator-webserver (1432047457958): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457958): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems-roots.js
server:emulator-webserver (1432047457959): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems-roots.js
server:emulator-webserver (1432047457964): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047457964): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystemPaths.js
server:emulator-webserver (1432047457964): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystemPaths.js
server:emulator-webserver (1432047459293): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047459293): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
server:emulator-webserver (1432047459293): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
xdk:server (1432047459340): memmrk:    40345196    58654336
server:emulator-webserver (1432047459558): emulator-webserver: got a request for userapp.
client:emulator (1432047459558): appmobi_plus_cordova :: Native back button handler was detached.
server:emulator-webserver (1432047459559): req.path = /http-services/emulator-webserver/ripple/userapp/C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map
server:emulator-webserver (1432047459559): Other file request, fullPath = C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map
server:emulator-webserver (1432047459563): Error testing path C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map; msg = ERROR: name must either start with slash or use base option
Error
xdk:client (1432047459586): memmrk:    53787484    81093376
xdk:server (1432047464340): memmrk:    40469360    58654336
xdk:client (1432047464588): memmrk:    65356596    88190976
client:emulator (1432047468301): [emulator] file change restarted emulator  /D/GIT clone/mapmytrip/src/mmt_4/www/js/app.js
client:emulator (1432047468304): appmobi_plus_cordova :: Emulator restarting mmt_1
client:emulator (1432047468307): appmobi_plus_cordova :: _xdkLoad for project mmt_1
xdk:server (1432047469487): memmrk:    33537528    58654336
xdk:client (1432047470371): memmrk:    100795532    120656256
client:emulator (1432047470536): appmobi_plus_cordova :: Initialization Finished (Make it so.)
server:emulator-webserver (1432047470540): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047470540): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/index.html
server:emulator-webserver (1432047470540): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/index.html
client:emulator (1432047470537): appmobi_plus_cordova :: frame appended to document
server:emulator-webserver (1432047471715): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471715): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
server:emulator-webserver (1432047471716): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
server:emulator-webserver (1432047471718): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471718): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js
server:emulator-webserver (1432047471718): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.bundle.min.js
server:emulator-webserver (1432047471720): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471720): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js
server:emulator-webserver (1432047471720): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js
server:emulator-webserver (1432047471721): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471721): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js
server:emulator-webserver (1432047471722): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js
server:emulator-webserver (1432047471722): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471722): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js
server:emulator-webserver (1432047471723): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js
server:emulator-webserver (1432047471739): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471739): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/login_controller.js
server:emulator-webserver (1432047471740): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/login_controller.js
server:emulator-webserver (1432047471742): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471742): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/layout_controller.js
server:emulator-webserver (1432047471742): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/layout_controller.js
server:emulator-webserver (1432047471753): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471754): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js
server:emulator-webserver (1432047471754): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js
server:emulator-webserver (1432047471758): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471758): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/login_service.js
server:emulator-webserver (1432047471758): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/login_service.js
server:emulator-webserver (1432047471762): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471762): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/layout_service.js
server:emulator-webserver (1432047471763): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/layout_service.js
server:emulator-webserver (1432047471767): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471767): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/routing_service.js
server:emulator-webserver (1432047471767): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/routing_service.js
server:emulator-webserver (1432047471771): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471771): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/cordova.js
server:emulator-webserver (1432047471772): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471772): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/xhr.js
server:emulator-webserver (1432047471772): xhr.js request fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/xhr.js
server:emulator-webserver (1432047471773): Send cordova.js from D:\xdk\components\server\emulator\resources\cordova.js
server:emulator-webserver (1432047471773): sending empty contents for missing xhr.js file
server:emulator-webserver (1432047471892): emulator-webserver: got a request for userapp.
client:emulator (1432047471892): appmobi_plus_cordova :: Emulation frame loaded
server:emulator-webserver (1432047471892): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view1.html
server:emulator-webserver (1432047471892): Main html fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/templates/view1.html
server:emulator-webserver (1432047471899): HTML file doesn't look like entire document; skipping injection
client:emulator (1432047471895): appmobi_plus_cordova :: fired appMobi.device.ready event!
server:emulator-webserver (1432047471931): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047471931): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/cordova_plugins.js
server:emulator-webserver (1432047471931): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/cordova_plugins.js
client:emulator (1432047472524): appmobi_plus_cordova :: tinyHipposLoaded cleared _loading/_delayedproject
server:emulator-webserver (1432047472532): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472532): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/Acceleration.js
server:emulator-webserver (1432047472533): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/Acceleration.js
server:emulator-webserver (1432047472535): emulator-webserver: got a request for userapp.
client:emulator (1432047472525): appmobi_plus_cordova :: [emulator] file watcher started
server:emulator-webserver (1432047472535): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/accelerometer.js
server:emulator-webserver (1432047472535): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-motion/www/accelerometer.js
server:emulator-webserver (1432047472539): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472539): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraConstants.js
server:emulator-webserver (1432047472539): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraConstants.js
server:emulator-webserver (1432047472544): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472544): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraPopoverOptions.js
server:emulator-webserver (1432047472544): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/CameraPopoverOptions.js
server:emulator-webserver (1432047472545): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472545): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/Camera.js
server:emulator-webserver (1432047472545): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/Camera.js
server:emulator-webserver (1432047472551): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472552): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/ios/CameraPopoverHandle.js
server:emulator-webserver (1432047472552): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.camera/www/ios/CameraPopoverHandle.js
server:emulator-webserver (1432047472554): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472554): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureAudioOptions.js
server:emulator-webserver (1432047472555): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureAudioOptions.js
server:emulator-webserver (1432047472555): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472555): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureImageOptions.js
server:emulator-webserver (1432047472556): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureImageOptions.js
server:emulator-webserver (1432047472562): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472562): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureVideoOptions.js
server:emulator-webserver (1432047472562): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureVideoOptions.js
server:emulator-webserver (1432047472563): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472563): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureError.js
server:emulator-webserver (1432047472563): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/CaptureError.js
server:emulator-webserver (1432047472568): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472568): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFileData.js
server:emulator-webserver (1432047472568): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFileData.js
server:emulator-webserver (1432047472569): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472569): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFile.js
server:emulator-webserver (1432047472570): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/MediaFile.js
server:emulator-webserver (1432047472571): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472571): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/capture.js
server:emulator-webserver (1432047472571): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media-capture/www/capture.js
server:emulator-webserver (1432047472577): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472577): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassError.js
server:emulator-webserver (1432047472578): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassError.js
server:emulator-webserver (1432047472579): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472580): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassHeading.js
server:emulator-webserver (1432047472580): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/CompassHeading.js
server:emulator-webserver (1432047472585): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472585): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/compass.js
server:emulator-webserver (1432047472585): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device-orientation/www/compass.js
server:emulator-webserver (1432047472586): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472586): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/network.js
server:emulator-webserver (1432047472587): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/network.js
server:emulator-webserver (1432047472588): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472588): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/Connection.js
server:emulator-webserver (1432047472589): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.network-information/www/Connection.js
server:emulator-webserver (1432047472595): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472595): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/contacts.js
server:emulator-webserver (1432047472595): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/contacts.js
server:emulator-webserver (1432047472597): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472597): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/Contact.js
server:emulator-webserver (1432047472597): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/Contact.js
server:emulator-webserver (1432047472603): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472603): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactAddress.js
server:emulator-webserver (1432047472603): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactAddress.js
server:emulator-webserver (1432047472605): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472605): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactError.js
server:emulator-webserver (1432047472605): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactError.js
server:emulator-webserver (1432047472607): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472607): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactField.js
server:emulator-webserver (1432047472607): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactField.js
server:emulator-webserver (1432047472614): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472614): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFindOptions.js
server:emulator-webserver (1432047472614): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFindOptions.js
server:emulator-webserver (1432047472615): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472615): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactName.js
server:emulator-webserver (1432047472616): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactName.js
server:emulator-webserver (1432047472619): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472619): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactOrganization.js
server:emulator-webserver (1432047472620): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactOrganization.js
server:emulator-webserver (1432047472621): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472621): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFieldType.js
server:emulator-webserver (1432047472622): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ContactFieldType.js
server:emulator-webserver (1432047472623): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472623): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/contacts.js
server:emulator-webserver (1432047472624): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/contacts.js
server:emulator-webserver (1432047472630): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472630): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/Contact.js
server:emulator-webserver (1432047472631): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.contacts/www/ios/Contact.js
server:emulator-webserver (1432047472632): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472632): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device/www/device.js
server:emulator-webserver (1432047472633): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.device/www/device.js
server:emulator-webserver (1432047472638): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472638): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.battery-status/www/battery.js
server:emulator-webserver (1432047472639): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.battery-status/www/battery.js
server:emulator-webserver (1432047472640): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472640): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransferError.js
server:emulator-webserver (1432047472641): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransferError.js
server:emulator-webserver (1432047472642): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472642): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransfer.js
server:emulator-webserver (1432047472642): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file-transfer/www/FileTransfer.js
server:emulator-webserver (1432047472647): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472647): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Coordinates.js
server:emulator-webserver (1432047472647): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Coordinates.js
server:emulator-webserver (1432047472649): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472649): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/PositionError.js
server:emulator-webserver (1432047472649): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/PositionError.js
server:emulator-webserver (1432047472655): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472655): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Position.js
server:emulator-webserver (1432047472656): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/Position.js
server:emulator-webserver (1432047472657): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472657): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/geolocation.js
server:emulator-webserver (1432047472658): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.geolocation/www/geolocation.js
server:emulator-webserver (1432047472659): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472659): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/GlobalizationError.js
server:emulator-webserver (1432047472660): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/GlobalizationError.js
server:emulator-webserver (1432047472666): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472666): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/globalization.js
server:emulator-webserver (1432047472666): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.globalization/www/globalization.js
server:emulator-webserver (1432047472668): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472668): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.inappbrowser/www/inappbrowser.js
server:emulator-webserver (1432047472668): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.inappbrowser/www/inappbrowser.js
server:emulator-webserver (1432047472672): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472672): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/MediaError.js
server:emulator-webserver (1432047472672): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/MediaError.js
server:emulator-webserver (1432047472674): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472674): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/Media.js
server:emulator-webserver (1432047472675): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.media/www/Media.js
server:emulator-webserver (1432047472677): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472677): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.dialogs/www/notification.js
server:emulator-webserver (1432047472677): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.dialogs/www/notification.js
server:emulator-webserver (1432047472684): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472684): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.vibration/www/vibration.js
server:emulator-webserver (1432047472685): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.vibration/www/vibration.js
server:emulator-webserver (1432047472686): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472686): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.splashscreen/www/splashscreen.js
server:emulator-webserver (1432047472687): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.splashscreen/www/splashscreen.js
server:emulator-webserver (1432047472691): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472691): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.statusbar/www/statusbar.js
server:emulator-webserver (1432047472692): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.statusbar/www/statusbar.js
server:emulator-webserver (1432047472692): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472693): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryEntry.js
server:emulator-webserver (1432047472693): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryEntry.js
server:emulator-webserver (1432047472697): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472697): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryReader.js
server:emulator-webserver (1432047472697): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/DirectoryReader.js
server:emulator-webserver (1432047472698): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472698): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Entry.js
server:emulator-webserver (1432047472699): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Entry.js
server:emulator-webserver (1432047472702): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472702): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/File.js
server:emulator-webserver (1432047472702): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/File.js
server:emulator-webserver (1432047472705): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472706): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileEntry.js
server:emulator-webserver (1432047472706): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileEntry.js
server:emulator-webserver (1432047472707): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472707): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileError.js
server:emulator-webserver (1432047472708): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileError.js
server:emulator-webserver (1432047472712): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472712): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileReader.js
server:emulator-webserver (1432047472713): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileReader.js
server:emulator-webserver (1432047472714): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472714): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileSystem.js
server:emulator-webserver (1432047472714): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileSystem.js
server:emulator-webserver (1432047472715): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472715): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadOptions.js
server:emulator-webserver (1432047472715): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadOptions.js
server:emulator-webserver (1432047472720): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472720): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadResult.js
server:emulator-webserver (1432047472720): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileUploadResult.js
server:emulator-webserver (1432047472722): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472722): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileWriter.js
server:emulator-webserver (1432047472722): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/FileWriter.js
server:emulator-webserver (1432047472725): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472725): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Flags.js
server:emulator-webserver (1432047472726): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Flags.js
server:emulator-webserver (1432047472726): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472727): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/LocalFileSystem.js
server:emulator-webserver (1432047472727): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/LocalFileSystem.js
server:emulator-webserver (1432047472731): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472731): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Metadata.js
server:emulator-webserver (1432047472731): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/Metadata.js
server:emulator-webserver (1432047472732): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472732): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ProgressEvent.js
server:emulator-webserver (1432047472733): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ProgressEvent.js
server:emulator-webserver (1432047472735): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472736): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems.js
server:emulator-webserver (1432047472736): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems.js
server:emulator-webserver (1432047472739): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472739): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/requestFileSystem.js
server:emulator-webserver (1432047472740): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/requestFileSystem.js
server:emulator-webserver (1432047472741): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472741): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/resolveLocalFileSystemURI.js
server:emulator-webserver (1432047472741): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/resolveLocalFileSystemURI.js
server:emulator-webserver (1432047472747): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472747): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ios/FileSystem.js
server:emulator-webserver (1432047472747): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/ios/FileSystem.js
server:emulator-webserver (1432047472749): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472749): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems-roots.js
server:emulator-webserver (1432047472749): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystems-roots.js
server:emulator-webserver (1432047472757): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047472757): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystemPaths.js
server:emulator-webserver (1432047472757): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/plugins/org.apache.cordova.file/www/fileSystemPaths.js
server:emulator-webserver (1432047473615): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047473616): req.path = /http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
server:emulator-webserver (1432047473616): Other file request, fullPath = /C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/ionic.min.css
server:emulator-webserver (1432047474072): emulator-webserver: got a request for userapp.
server:emulator-webserver (1432047474072): req.path = /http-services/emulator-webserver/ripple/userapp/C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map
server:emulator-webserver (1432047474072): Other file request, fullPath = C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map
server:emulator-webserver (1432047474074): Error testing path C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/lib/ionicframework/angular-sanitize.min.js.map; msg = ERROR: name must either start with slash or use base option
Error
    at ComponentError (D:\xdk\core-modules\public\component-error.js:17:1122)
    at new ServiceError (D:\xdk\core-modules\public\service-error.js:17:317)
    at _ensureStartsWithSlashOrUsesBaseOption (D:\xdk\components\server\userfs\filter\sanitize.js:17:800)
    at D:\xdk\components\server\userfs\filter\sanitize.js:17:1227
    at Array.forEach (native)
    at Function._.each._.forEach (D:\xdk\node_modules\underscore\underscore.js:79:11)
    at D:\xdk\components\server\userfs\filter\sanitize.js:17:1120
    at beforeFilter (D:\xdk\components\server\userfs\filter\sanitize.js:17:1082)
client:emulator (1432047474146): appmobi_plus_cordova :: Native back button handler was detached.
xdk:server (1432047474488): memmrk:    36824680    58654336
xdk:client (1432047475373): memmrk:    65713188    89194496
xdk:server (1432047479488): memmrk:    36832644    58654336
xdk:client (1432047480373): memmrk:    66222816    89194496
xdk:server (1432047484489): memmrk:    26198684    58654336
xdk:client (1432047485373): memmrk:    66555564    89194496
xdk:server (1432047489489): memmrk:    25984088    36855936
xdk:client (1432047490374): memmrk:    67119908    89194496
xdk:server (1432047494491): memmrk:    26018000    36855936
xdk:client (1432047495376): memmrk:    71051132    92229376
xdk:server (1432047499492): memmrk:    25716176    34824576
xdk:client (1432047500377): memmrk:    72469168    92229376
xdk:server (1432047504495): memmrk:    25723216    34824576
xdk:client (1432047505381): memmrk:    72796640    92229376
xdk:server (1432047509496): memmrk:    25045048    32805376
xdk:client (1432047510383): memmrk:    65415872    92229376
xdk:server (1432047514497): memmrk:    25010968    33853952
xdk:client (1432047515383): memmrk:    65743364    92229376
xdk:server (1432047519497): memmrk:    24411752    33853952
xdk:client (1432047520383): memmrk:    66716568    92229376
xdk:server (1432047524498): memmrk:    24418448    33853952
xdk:client (1432047525383): memmrk:    67792732    92229376
xdk:server (1432047529499): memmrk:    24424812    33853952
xdk:client (1432047530385): memmrk:    68643964    92229376
xdk:server (1432047534499): memmrk:    24431176    33853952
xdk:client (1432047535386): memmrk:    69239412    92229376
xdk:server (1432047539499): memmrk:    25380300    33853952
xdk:client (1432047540386): memmrk:    67093292    94248576
xdk:server (1432047544500): memmrk:    25386664    33853952
xdk:client (1432047545387): memmrk:    67681752    94248576
xdk:server (1432047549501): memmrk:    25393028    33853952
xdk:client (1432047550387): memmrk:    68175312    94248576
xdk:server (1432047554501): memmrk:    25399392    33853952
xdk:client (1432047555388): memmrk:    68505920    94248576
xdk:server (1432047559501): memmrk:    25405756    33853952
xdk:client (1432047560389): memmrk:    68999452    94248576
xdk:server (1432047564504): memmrk:    25412120    33853952
xdk:client (1432047565392): memmrk:    69330076    94248576
xdk:server (1432047569504): memmrk:    25418484    33853952
xdk:client (1432047570393): memmrk:    69906952    94248576
xdk:server (1432047574505): memmrk:    25424848    33853952
xdk:client (1432047575393): memmrk:    70385996    94248576
xdk:server (1432047579506): memmrk:    25431212    33853952
xdk:client (1432047580395): memmrk:    70988068    94248576
xdk:server (1432047584506): memmrk:    25446728    33853952
xdk:client (1432047585395): memmrk:    71479688    94248576
xdk:server (1432047589506): memmrk:    25452168    33853952
xdk:client (1432047590396): memmrk:    72107260    94248576
xdk:server (1432047594507): memmrk:    25458532    33853952
xdk:client (1432047595396): memmrk:    72636772    94248576
xdk:server (1432047599508): memmrk:    25464896    33853952
xdk:client (1432047600397): memmrk:    73131112    94248576
xdk:server (1432047604508): memmrk:    25471260    33853952
xdk:client (1432047605397): memmrk:    73462504    94248576
xdk:server (1432047609508): memmrk:    25477624    33853952
xdk:client (1432047610398): memmrk:    73873948    94248576
xdk:server (1432047614510): memmrk:    25483988    33853952
xdk:client (1432047615399): memmrk:    74366460    94248576
xdk:server (1432047619510): memmrk:    25490352    33853952
xdk:client (1432047620400): memmrk:    74773976    94248576
xdk:server (1432047624513): memmrk:    25496716    33853952
xdk:client (1432047625403): memmrk:    69251080    94248576
xdk:server (1432047629513): memmrk:    25503080    33853952
xdk:client (1432047630403): memmrk:    69741412    95264256
xdk:server (1432047634515): memmrk:    25509444    33853952
xdk:client (1432047635405): memmrk:    70069636    95264256
xdk:server (1432047639515): memmrk:    25515808    33853952
xdk:client (1432047640406): memmrk:    70553400    95264256
xdk:server (1432047644515): memmrk:    25522172    33853952
xdk:client (1432047645406): memmrk:    71054600    95264256
xdk:server (1432047649516): memmrk:    25528536    33853952
xdk:client (1432047650407): memmrk:    71492588    95264256
xdk:server (1432047654517): memmrk:    25534924    33853952
xdk:client (1432047655408): memmrk:    71902876    95264256
xdk:server (1432047659517): memmrk:    25540364    33853952
xdk:client (1432047660408): memmrk:    72310400    95264256
xdk:server (1432047664517): memmrk:    25546728    33853952
xdk:client (1432047665409): memmrk:    72726444    95264256
xdk:server (1432047669518): memmrk:    25553092    33853952
xdk:client (1432047670410): memmrk:    73216852    95264256
xdk:server (1432047674518): memmrk:    25559456    33853952
xdk:client (1432047675411): memmrk:    73561012    95264256
xdk:server (1432047679519): memmrk:    25565820    33853952
xdk:client (1432047680411): memmrk:    73968528    95264256
xdk:server (1432047684522): memmrk:    25572184    33853952
xdk:client (1432047685415): memmrk:    74378816    95264256
xdk:server (1432047689522): memmrk:    25578548    33853952
xdk:client (1432047690415): memmrk:    74786332    95264256
xdk:server (1432047694522): memmrk:    25584912    33853952
xdk:client (1432047695416): memmrk:    52716464    95264256
xdk:server (1432047699523): memmrk:    25591276    33853952
xdk:client (1432047700417): memmrk:    53146504    95264256
xdk:server (1432047704524): memmrk:    25597640    33853952
xdk:client (1432047705418): memmrk:    53556792    95264256
xdk:server (1432047709524): memmrk:    25604004    33853952
xdk:client (1432047710427): memmrk:    54134384    95264256
xdk:server (1432047714524): memmrk:    25610368    33853952
xdk:client (1432047715427): memmrk:    54548772    95264256
xdk:server (1432047719526): memmrk:    25616732    33853952
xdk:client (1432047720428): memmrk:    54969056    95264256
xdk:server (1432047724526): memmrk:    25623096    33853952
xdk:client (1432047725429): memmrk:    55383392    95264256
xdk:server (1432047729526): memmrk:    25629460    33853952
xdk:client (1432047730429): memmrk:    55795488    95264256
xdk:server (1432047734526): memmrk:    25634900    33853952
xdk:client (1432047735430): memmrk:    56225564    95264256
xdk:server (1432047739528): memmrk:    25641264    33853952
xdk:client (1432047740432): memmrk:    56848504    95264256
xdk:server (1432047744531): memmrk:    25647628    33853952
xdk:client (1432047745436): memmrk:    57544012    95264256
xdk:server (1432047749531): memmrk:    25653992    33853952
xdk:client (1432047750446): memmrk:    57955692    95264256
xdk:server (1432047754532): memmrk:    25660356    33853952
xdk:client (1432047755447): memmrk:    58370148    95264256
xdk:server (1432047759532): memmrk:    25666720    33853952
xdk:client (1432047760453): memmrk:    58801472    95264256
xdk:server (1432047764533): memmrk:    25673084    33853952
xdk:client (1432047765453): memmrk:    59238492    95264256
xdk:server (1432047769533): memmrk:    25679448    33853952
xdk:client (1432047770458): memmrk:    59649988    95264256
xdk:server (1432047774534): memmrk:    25685812    33853952
xdk:client (1432047775459): memmrk:    60064196    95264256
xdk:server (1432047779534): memmrk:    25740088    33853952
xdk:client (1432047780464): memmrk:    60507128    95264256
xdk:server (1432047784535): memmrk:    25746452    33853952
xdk:client (1432047785465): memmrk:    60921336    95264256
xdk:server (1432047789536): memmrk:    25752816    33853952
xdk:client (1432047790479): memmrk:    61332772    95264256
xdk:server (1432047794536): memmrk:    25759180    33853952
xdk:client (1432047795480): memmrk:    55179264    95264256
xdk:server (1432047799536): memmrk:    25781436    33853952
xdk:client (1432047800480): memmrk:    55676296    95264256
xdk:server (1432047804539): memmrk:    25786748    33853952
xdk:client (1432047805494): memmrk:    57048332    95264256
xdk:server (1432047809541): memmrk:    25792952    33853952
xdk:client (1432047810512): memmrk:    57964496    95264256
xdk:server (1432047814541): memmrk:    25799156    33853952
xdk:client (1432047815513): memmrk:    58955560    95264256
xdk:server (1432047819541): memmrk:    25805360    33853952
xdk:client (1432047820513): memmrk:    59436700    95264256
xdk:server (1432047824542): memmrk:    25811548    33853952
xdk:client (1432047825515): memmrk:    60233196    95264256
xdk:server (1432047829550): memmrk:    25817752    33853952
xdk:client (1432047830516): memmrk:    60636264    95264256
xdk:server (1432047834542): memmrk:    25013624    33853952
xdk:client (1432047835516): memmrk:    61264720    95264256
xdk:server (1432047839543): memmrk:    25029744    33853952
xdk:client (1432047840517): memmrk:    61637364    95264256
xdk:server (1432047844544): memmrk:    25035964    33853952
xdk:client (1432047845517): memmrk:    62291952    95264256
xdk:server (1432047849544): memmrk:    25045180    33853952
xdk:client (1432047850518): memmrk:    56788092    95264256
xdk:server (1432047854544): memmrk:    25052188    33853952
xdk:client (1432047855518): memmrk:    57290136    95264256
xdk:server (1432047859545): memmrk:    25058408    33853952
xdk:client (1432047860520): memmrk:    57630784    95264256
xdk:server (1432047864548): memmrk:    25064628    33853952
xdk:client (1432047865523): memmrk:    58210976    95264256
xdk:server (1432047869548): memmrk:    25070848    33853952
xdk:client (1432047870523): memmrk:    58542448    95264256
xdk:server (1432047874549): memmrk:    25077068    33853952
xdk:client (1432047875525): memmrk:    59036780    95264256
xdk:server (1432047879550): memmrk:    25082396    33853952
xdk:client (1432047880525): memmrk:    59369068    95264256
xdk:server (1432047884550): memmrk:    25088616    33853952
xdk:client (1432047885526): memmrk:    59956316    96267776
xdk:server (1432047889551): memmrk:    25094836    33853952
xdk:client (1432047890526): memmrk:    60323944    96267776
xdk:server (1432047894552): memmrk:    25118792    33853952
xdk:client (1432047895527): memmrk:    60818816    96267776
xdk:server (1432047899552): memmrk:    25125012    33853952
xdk:client (1432047900528): memmrk:    61152016    96267776
xdk:server (1432047904552): memmrk:    25131232    33853952
xdk:client (1432047905529): memmrk:    61646268    96267776
xdk:server (1432047909553): memmrk:    25137452    33853952
xdk:client (1432047910530): memmrk:    62000612    96267776
xdk:server (1432047914554): memmrk:    25143672    33853952
xdk:client (1432047915530): memmrk:    62503688    96267776
xdk:server (1432047919554): memmrk:    25149892    33853952
xdk:client (1432047920530): memmrk:    62835288    96267776
xdk:server (1432047924557): memmrk:    25156112    33853952
xdk:client (1432047925533): memmrk:    63329740    96267776
xdk:server (1432047929558): memmrk:    25162332    33853952
xdk:client (1432047930535): memmrk:    63664096    96267776
xdk:server (1432047934559): memmrk:    25168552    33853952
xdk:client (1432047935535): memmrk:    64165152    96267776
xdk:server (1432047939559): memmrk:    25174772    33853952
xdk:client (1432047940536): memmrk:    58487060    96267776
xdk:server (1432047944559): memmrk:    25180992    33853952
xdk:client (1432047945538): memmrk:    59428072    96267776
xdk:server (1432047949561): memmrk:    25187196    33853952
xdk:client (1432047950539): memmrk:    59795568    96267776
xdk:server (1432047954561): memmrk:    25192524    33853952
xdk:client (1432047955539): memmrk:    60261356    96267776
xdk:server (1432047959561): memmrk:    25198744    33853952
xdk:client (1432047960539): memmrk:    60571048    96267776
xdk:server (1432047964562): memmrk:    25204964    33853952
xdk:client (1432047965541): memmrk:    61037380    96267776
xdk:server (1432047969562): memmrk:    25211184    33853952
xdk:client (1432047970541): memmrk:    61339440    96267776
xdk:server (1432047974563): memmrk:    25219080    33853952
xdk:client (1432047975547): memmrk:    61798712    96267776
xdk:server (1432047979563): memmrk:    25225300    33853952
xdk:client (1432047980548): memmrk:    52176944    92241536
xdk:server (1432047984567): memmrk:    25231520    33853952
xdk:client (1432047985550): memmrk:    52686096    93245056
xdk:server (1432047989567): memmrk:    25237740    33853952
xdk:client (1432047990551): memmrk:    52976584    93245056
xdk:server (1432047994567): memmrk:    25243960    33853952
xdk:client (1432047995552): memmrk:    50294800    73465856
xdk:server (1432047999568): memmrk:    25250180    33853952
xdk:client (1432048000554): memmrk:    50644964    73465856
xdk:server (1432048004569): memmrk:    25256400    33853952
xdk:client (1432048005554): memmrk:    51080252    73465856
xdk:server (1432048009569): memmrk:    25262620    33853952
xdk:client (1432048010554): memmrk:    50584048    76611584
xdk:server (1432048014569): memmrk:    25268840    33853952
xdk:client (1432048015556): memmrk:    51011960    76611584
xdk:server (1432048019570): memmrk:    25275060    33853952
xdk:client (1432048020556): memmrk:    49406176    75608064
xdk:server (1432048024571): memmrk:    25280388    33853952
xdk:client (1432048025556): memmrk:    50000096    75608064
xdk:server (1432048029571): memmrk:    25286608    33853952
xdk:client (1432048030556): memmrk:    50278328    75608064
xdk:server (1432048034572): memmrk:    25292828    33853952
xdk:client (1432048035558): memmrk:    50734472    75608064
xdk:server (1432048039573): memmrk:    25299048    33853952
xdk:client (1432048040558): memmrk:    49591432    72462336
xdk:server (1432048044576): memmrk:    25305268    33853952
xdk:client (1432048045562): memmrk:    50069852    73465856
xdk:server (1432048049576): memmrk:    25320748    33853952
xdk:client (1432048050567): memmrk:    50347980    73465856
xdk:server (1432048054578): memmrk:    25328292    33853952
xdk:client (1432048055567): memmrk:    50083740    74514432
xdk:server (1432048059578): memmrk:    25336192    33853952
xdk:client (1432048060567): memmrk:    49599888    73510912
xdk:server (1432048064578): memmrk:    25343232    33853952
xdk:client (1432048065568): memmrk:    50056920    73510912
xdk:server (1432048069580): memmrk:    25350236    33853952
xdk:client (1432048070569): memmrk:    50360764    73510912
xdk:server (1432048074580): memmrk:    25356432    33853952
xdk:client (1432048075569): memmrk:    50004508    73510912
xdk:server (1432048079580): memmrk:    25362628    33853952
xdk:client (1432048080569): memmrk:    49869552    73510912
xdk:server (1432048084580): memmrk:    25368824    33853952
xdk:client (1432048085571): memmrk:    49767564    66401152
xdk:server (1432048089581): memmrk:    25375020    33853952
xdk:client (1432048090572): memmrk:    47611000    66401152
xdk:server (1432048094581): memmrk:    25381216    33853952
xdk:client (1432048095571): memmrk:    48137940    66401152
xdk:server (1432048099582): memmrk:    25386520    33853952
xdk:client (1432048100572): memmrk:    48424048    66401152
xdk:server (1432048104585): memmrk:    25392716    33853952
xdk:client (1432048105575): memmrk:    48041716    66401152
xdk:server (1432048109585): memmrk:    25398912    33853952
xdk:client (1432048110576): memmrk:    48323540    66401152
xdk:server (1432048114585): memmrk:    25405108    33853952
xdk:client (1432048115577): memmrk:    48729312    66401152
xdk:server (1432048119586): memmrk:    25411304    33853952
xdk:client (1432048120578): memmrk:    48370168    66401152
xdk:server (1432048124587): memmrk:    25417500    33853952
xdk:client (1432048125579): memmrk:    49122444    66401152
xdk:server (1432048129587): memmrk:    25423696    33853952
xdk:client (1432048130579): memmrk:    48954312    68498304
xdk:server (1432048134588): memmrk:    25429892    33853952
xdk:client (1432048135579): memmrk:    49790604    69501824
xdk:server (1432048139589): memmrk:    25436088    33853952
xdk:client (1432048140581): memmrk:    50136340    69501824
xdk:server (1432048144589): memmrk:    25442284    33853952
xdk:client (1432048145583): memmrk:    50811484    69501824
Node Webkit Error log:
[14592:0519/165423:INFO:CONSOLE(17)] ""xdk:client (1432047263851): Error SyntaxError: Unexpected token \uFEFF loading components\\client\\app\\locale\\ru\\text-content.json"", source: D:\xdk\core-modules\private\logger.js (17)
[14592:0519/165423:INFO:CONSOLE(17)] ""xdk:client (1432047263883): Error SyntaxError: Unexpected token \uFEFF loading components\\client\\profiling\\locale\\ru\\text-content.json"", source: D:\xdk\core-modules\private\logger.js (17)
[14592:0519/165424:INFO:CONSOLE(989)] "" Unhandled rejection reasons (should be empty):" ["(no stack) [object Object]"]", source: file:///D:/xdk/node_modules/q/q.js (989)
[14592:0519/165429:INFO:CONSOLE(224)] ""NW proxy string: DIRECT"", source: /brackets.js (224)
[14592:0519/165429:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n    at new jQuery.fn.init (/brackets.js:455:36)\n    at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n    at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/camden.jshint/main.js:174:9\n    at _callHandler (/utils/AppInit.js:94:13)\n    at Object._dispatchReady (/utils/AppInit.js:114:13)\n    at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n    at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n    at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n    at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[14592:0519/165429:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n    at new jQuery.fn.init (/brackets.js:455:36)\n    at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n    at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/camden.jshint/main.js:183:9\n    at _callHandler (/utils/AppInit.js:94:13)\n    at Object._dispatchReady (/utils/AppInit.js:114:13)\n    at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n    at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n    at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n    at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[14592:0519/165429:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n    at new jQuery.fn.init (/brackets.js:455:36)\n    at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n    at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/intelxdk.xlint/main.js:366:9\n    at _callHandler (/utils/AppInit.js:94:13)\n    at Object._dispatchReady (/utils/AppInit.js:114:13)\n    at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n    at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n    at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n    at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[14592:0519/165429:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n    at new jQuery.fn.init (/brackets.js:455:36)\n    at n (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:405)\n    at file:///C:/Users/ccantagrel/AppData/Local/XDK/editor/extensions/user/intelxdk.xlint/main.js:375:9\n    at _callHandler (/utils/AppInit.js:94:13)\n    at Object._dispatchReady (/utils/AppInit.js:114:13)\n    at Object.ready (file:///D:/xdk/brackets/b/extensions/default/XDK/main.js:490:21)\n    at j (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:26911)\n    at Object.k.fireWith [as resolveWith] (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:27724)\n    at Object.e.(anonymous function) (file:///D:/xdk/brackets/b/thirdparty/thirdparty.min.js:559:28704)"", source: /utils/DeprecationWarning.js (90)
[14592:0519/165430:INFO:CONSOLE(989)] "" Unhandled rejection reasons (should be empty):" ["(no stack) ERROR: no user is logged in\nError\n    at new ComponentError (D:\\xdk\\core-modules\\public\\component-error.js:17:1122)\n    at makeError (file:///D:/xdk/components/client/backend-service-utils/backend-service-utils.js:17:187)\n    at file:///D:/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1258\n    at _fulfilled (D:\\xdk\\node_modules\\q\\q.js:797:54)\n    at self.promiseDispatch.done (D:\\xdk\\node_modules\\q\\q.js:826:30)\n    at Promise.promise.promiseDispatch (D:\\xdk\\node_modules\\q\\q.js:759:13)\n    at D:\\xdk\\node_modules\\q\\q.js:573:44\n    at flush (D:\\xdk\\node_modules\\q\\q.js:108:17)\n    at process._tickCallback (node.js:393:11)"]", source: D:\xdk\node_modules\q\q.js (989)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.device-motion"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.camera"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.media-capture"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.device-orientation"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.network-information"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.contacts"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.device"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.battery-status"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.file"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.file-transfer"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.geolocation"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.globalization"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.inappbrowser"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.media"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.dialogs"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.vibration"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.splashscreen"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165430:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.statusbar"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.device-motion"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.camera"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.media-capture"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.device-orientation"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.network-information"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.contacts"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.device"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.battery-status"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.file"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.file-transfer"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.geolocation"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.globalization"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.inappbrowser"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.media"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.dialogs"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.vibration"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.splashscreen"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165432:INFO:CONSOLE(17)] ""no hint for this plugin: org.apache.cordova.statusbar"", source: file:///D:/xdk/brackets/b/extensions/default/JavaScriptCodeHints/ServicePluginHint.js (17)
[14592:0519/165443:WARNING:backend_impl.cc(1785)] Destroying invalid entry.
[14592:0519/165723:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[14592:0519/165723:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[14592:0519/165723:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[14592:0519/165723:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[14592:0519/165723:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[14592:0519/165724:INFO:CONSOLE(10)] ""RRROUTING service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (10)
[14592:0519/165724:INFO:CONSOLE(21)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (21)
[14592:0519/165731:INFO:CONSOLE(989)] "" Unhandled rejection reasons (should be empty):" ["(no stack) ERROR: name must either start with slash or use base option\nError\n    at ComponentError (D:\\xdk\\core-modules\\public\\component-error.js:17:1122)\n    at new ServiceError (D:\\xdk\\core-modules\\public\\service-error.js:17:317)\n    at _ensureStartsWithSlashOrUsesBaseOption (D:\\xdk\\components\\server\\userfs\\filter\\sanitize.js:17:800)\n    at D:\\xdk\\components\\server\\userfs\\filter\\sanitize.js:17:1227\n    at Array.forEach (native)\n    at Function._.each._.forEach (D:\\xdk\\node_modules\\underscore\\underscore.js:79:11)\n    at D:\\xdk\\components\\server\\userfs\\filter\\sanitize.js:17:1120\n    at Array.forEach (native)\n    at Function._.each._.forEach (D:\\xdk\\node_modules\\underscore\\underscore.js:79:11)\n    at beforeFilter (D:\\xdk\\components\\server\\userfs\\filter\\sanitize.js:17:1082)"]", source: D:\xdk\node_modules\q\q.js (989)
[14592:0519/165737:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[14592:0519/165737:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[14592:0519/165737:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[14592:0519/165737:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[14592:0519/165737:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[14592:0519/165739:INFO:CONSOLE(10)] ""RRROUTING service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (10)
[14592:0519/165739:INFO:CONSOLE(21)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (21)
[14592:0519/165751:INFO:CONSOLE(5)] ""Application Routing"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/routing.js (5)
[14592:0519/165751:INFO:CONSOLE(6)] ""Application Run"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (6)
[14592:0519/165752:INFO:CONSOLE(8)] ""First service"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (8)
[14592:0519/165752:INFO:CONSOLE(7)] ""First controller"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/controllers/controller1.js (7)
[14592:0519/165752:INFO:CONSOLE(11)] ""service 1 called"", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/services/service1.js (11)
[14592:0519/165754:INFO:CONSOLE(20)] "Uncaught TypeError: Cannot read property 'Keyboard' of undefined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp//C/Users/ccantagrel/AppData/Local/XDK/xdk-scratchdir/0d3b2229-6528-4d6f-ae1f-320d443ff76c/platforms/ios/www/js/app.js (20)
[14592:0519/170745:ERROR:dns_config_service_win.cc(739)] DNS config watch failed.
XDK exit code & signal: 3221225477, null
Crash minidump not found in XDK data folder. Falling back to TEMP...
Crash Minidump File: C:\Users\ccantagrel\AppData\Local\Temp\c2b717a5-3652-4bab-8ca2-356abb6b19f9.dmp Tue May 19 2015 17:09:06 GMT+0200 (Romance Daylight Time)
Size in bytes: 0
NW Crash Detected.
Cantagrel_C_
If someone have an issue, it's very important.
Cantagrel_C_
Hello, up
No one ?
Chris_P_Intel
When these crash reports were submitted we received them and opened a ticket. I found the ticket and it is being worked, but I don't have a progress update yet. It's not yet clear to me exactly what the problem is.
Your project was created with the Ionic command line tool, correct?
Would it be possible for you to .zip and post your entire project directory?
Cantagrel_C_
My project was not created with the ionic command line tool.
I just created my project with INTEL XDK version 1826, and I created a ionic project directly.
Yesterday intel xdk crash all 15min all the day, and today 0 crash. So I will work all the weekend, and i will post my .zip monday.
