Software Archive
Read-only legacy content
17060 Discussions
intel parallel studio 2015
Javier_M_2
Recently i installed and compiled WRF with this version "intel parallel studio 2015".I used intel mpi and i cant run WRF. i obtained mpi errors in the execution. Finally i downgrade to version 2013 and i run succesfully. is this version (2015) incompatible with mpss 3.4 and OFED 3.5.2?
thx in advance.
Kevin_D_Intel
I will inquire with our Cluster Tools team whether there are any known issues with this combination and let you know.
Did you follow this recipe for building WRF for Xeon Phi and use Intel MPI?
Did you happen to try building/running any MPI tests less complex than WRF with IPS XE 2015?
Javier_M_2
no only this.
Kevin_D_Intel
Javier_M_2
yes with this recipe work with Intel® Cluster Studio XE 2013 but no with Intel® Parallel Studio XE 2015. Sorry for poor information next week i'll try  to install Intel® Parallel Studio XE 2015 again and i'll upload the logs of the run and the display mpi errors on terminal.
thxs
Javier_M_2
