Software Archive
Read-only legacy content
17060 Discussions
internal error
jorgenjohansson
! First case:Internal error.
E:femp22X>f90 /c /real_size:64 /warn:all /check:all Input_Output_Subroutines.f90
Compaq Visual Fortran Optimizing Compiler Version 6.6
Copyright 2001 Compaq Computer Corp. All rights reserved.
f90: Fatal: There has been an internal compiler error (C0000005).
! 2nd case:object file is produced.
E:femp22X>f90 /c /real_size:64 /warn:all /check:all /check:nobounds Input_Output_Subroutines.f90
E:femp22X> ..."
Steven_L_Intel1
This forum is for user-to-user discussions. Please send support requests to [email protected] Attach a ZIP archive of your sources or project, and include a copy of BUGREPRT.TXT (found in DF98BIN) completely filled out, including your Visual Fortran serial number.
An internal compiler error is always a compiler bug, and we'd like to fix it. We need to see your source in order to do so.
Steve
elf
Hi, jorgenj! Have you got your problem resolved? How? I'm facing the same problem as you did so I hope you could give me some ideas or suggestions. Thanks in advance.
Alvin
Steven_L_Intel1
Alvin,
Your problem is probably not the same. I tried to respond to your e-mail to vf-support, but Hotmail bounced it saying your maibox was full. I also replied to your post in comp.lang.fortran.
This is a generic error message with many possible causes, but in ALL cases you should report it to vf-support as we're the only ones who can tell you what went wrong.
Steve
