Software Archive
Read-only legacy content
17060 Discussions
jquery ui draggable
brian_a_1
does anyone have a recipe for including jquery ui, touch-punch etc into a project to get draggable available?
I tried, but I get a message in the design mode "loading..." that never goes away.
tia.
Chris_P_Intel
Well, you can add those things to your project, but you won't be able to test them in Design mode. It disables user scripts.
And, further, the Design mode already adds jquery UI for you to enable its own drag and drop. So, the double inclusion might be causing the problem you are seeing, I'm not sure.  Also, if I recall correctly, jQuery Mobile is super sensitive to the order in which it is included, and jQuery UI may be similarly finicky.
If I were you, I'd first focus on getting everything working outside Design mode, and then worry about Design mode after. If you get the first step working, let us know and I can help consult about re-enabling the Design mode. And, with any luck, we can identify the exact problem and get a fix in for any future users who want to attempt the same.
brian_a_1
Thanks for the reply Chris.
"I'd first focus on getting everything working outside Design mode"
that should take me a year or so.. speak later :/
regards
David_G_4
Just a note I wanted to add on this issue:
If you try to include the jQuery UI library in the <head> tag of your index.html it will keep the Design mode of XDK from working (Some type of conflict)
But as a solution, just add it to the <body> instead.  It allows Design mode to work and will work the same in your app.
Just wanted to pass on the info.
Example:
<body>
        <script type="application/javascript" src="lib/jquery-ui.min.js"></script>
</body>
SithLord
I include draggable in the head without issue but i'm using "app_framework/2.2/af.ui.jquery.min.js"
<script type="application/javascript" src="lib/drag-ui.min.js"></script>
<script type="application/javascript" src="lib/jquery.ui.touch-punch.min.js"></script>
