Software Archive
Read-only legacy content
17060 Discussions
less file not work every change page
Randy_S_1
intel xdk 3088 and jquery mobile.
i want to change the index.html page to second.html page by clicking buton. i hafe 3 file :
1.index.html
2.second.html
3. change .js
i using this code on index.html
div class="widget-container content-area vertical-col"><a class="widget uib_w_1 d-margins" data-uib="jquery_mobile/button" data-ver="0" data-role="button" id="chb" href="ra.html">Button</a>
                        <span class="uib_shim"></span>
                    </div>
in my chage.js i using this code
$(document).on("click", ".uib_w_5", function(evt) {
document.location = "second.html";
in emulator that work but if i clik the buton  the second.html come without less file, its come with standard desing ..how to fixt hat... please help me....
Chris_P_Intel
Look in to the jQueryMobile docs.
jQueryMobile has a special ajax page-loading feature. What it does is rather than going to another html file, JQM "loads" the DOM of that page in memory, and dynamically switches the content. In other words the head of the page is not loaded.
You can read more about it here: https://demos.jquerymobile.com/1.2.0/docs/pages/page-links.html
If you don't want that behavior, read the "Linking Without Ajax" section of that page.  I'm not exactly sure how to defeat it with Javascript.
Hope this helps,
Chris
Chris_P_Intel
Also  https://demos.jquerymobile.com/1.2.0/docs/pages/page-scripting.html
