Software Archive
Read-only legacy content
link error
Jay_Dowling
I can compile my application in debug mode but when I try a release compile so I can use Parallel Amplifier I get 2 link errors:
LNK2019: unresolved external symbol ___intel_sse2_strlen
LNK2019: unresolved external symbol ___intel_new_proc_init
How do I fix this?
Yang_W_Intel
Looks like there are some problems for your icl environment setting. You may clean everything and make a fresh rebuild for you application.
-Yang
Brandon_H_Intel
I had a phone call with Jay last week where we spent an hour or so triaging this, and we figured out that the link errors were from using the -nodefaultlib linker setting in the Microsoft project prior to being converted to Intel. I will be submitting a feature request for the project conversion log to emit a warning when -nodefaultlib is set to ensure the user is aware of the setting and that they know they need to manually link in any Intel libraries in the event this is set. Let me know if you need anything else, Jay.
Brandon_H_Intel
The project conversion process now gives this warning in both Parallel Composer 2011 and C++ Composer XE 2011 updates 6 and above:
Warning(s): /NODEFAULTLIB has been enabled in the linker settings for this project in the "Debug|Win32" configuration. Note that any Intel C++ Compiler runtime libraries or Intel IPP runtime libraries will need to be explicitly specified in the linker settings.
