Software Archive
Read-only legacy content
link error
Intel_C_Intel
I have a program needed to be run using Fortran 95, there's no error when compiling but got the following error when debugging:
project4.obj:error LNK 2001: unresolved external symbol _LOWER@8
Debug/project4.exe: fatal error LNK 1120: 1 unresolved externals
Can anybody help me to fix that ? Thanks.
There is a mismatch between the call to LOWER and the declaration of the routine LOWER. Make sure the arguments are of the same type and number.
Steve
Intel_C_Intel
Also, you might be using LOWER as an array, but never have dimensioned it such as
REAL, ALLOCATABLE(:) :: LOWER
for a dynamic array or
REAL, DIMENSION(15) :: LOWER
for a static array. This will give you the exact same error message if you have not dimensioned LOWER as an array prior to using it as an array.
Tom
