Software Archive
Read-only legacy content
17060 Discussions
lmgrd.intel.exe not working on Windows 7
WILFRID_C_
Hello
I have 2 floating licenses of Intel® C++ Composer XE for Linux* (formerly Intel® C++ Compiler Professional Edition for Linux*) version 2011
The Flexlm daemon lmgrd.intel.exe worked well when the Flexlm license server was on Microsoft Windows XP.
But since I had to migrate it to Microsoft Windows 7 SP1 32 bits, I can't get it working.
The dameon lmgrd.intel.exe claims that there are         MULTIPLE "INTEL" license server systems running, whereby a "lmutil lmstat ..." before that states that lmgrd is not running (Log file provided for more details if needed)
Is this a known issue of lmgrd.intel.exe on Win 7 ? Is there a workaround ?
Thanks for any help
14:37:47 (lmgrd) pid 3820
14:37:47 (lmgrd) Done rereading
14:37:47 (lmgrd) FLEXnet Licensing (v11.6.1.0 build 66138 i86_n3) started on BLNTLIC01 (IBM PC) (7/21/2015)
14:37:47 (lmgrd) Copyright (c) 1988-2008 Acresso Software Inc. All Rights Reserved.
14:37:47 (lmgrd) US Patents 5,390,297 and 5,671,412.
14:37:47 (lmgrd) World Wide Web:  http://www.acresso.com
14:37:47 (lmgrd) License file(s): ../licenses/COM_L__CPP_9SCN-B5ZJGF85.lic
14:37:47 (lmgrd) lmgrd tcp-port 28158
14:37:47 (lmgrd) Starting vendor daemons ...
14:37:48 (lmgrd) Started INTEL (pid 4088)
14:37:48 (INTEL) FLEXnet Licensing version v11.6.1.0 build 66138 i86_n3
14:37:48 (INTEL) EXITING DUE TO SIGNAL 32 Exit reason 9
14:37:53 (lmgrd) INTEL exited with status 32 (Exited because another server was running)
14:37:53 (lmgrd) MULTIPLE "INTEL" license server systems running.
14:37:53 (lmgrd) Using Task Manager, stop INTEL and run lmreread
14:37:53 (lmgrd)
14:37:53 (lmgrd) This error probably results from:
14:37:53 (lmgrd)   1. Another copy of the license server manager (lmgrd) is running.
14:37:53 (lmgrd)   2. Another copy of the vendor daemon is running.
14:37:53 (lmgrd)   3. The locking mechanism(s) were removed by an
14:37:53 (lmgrd)        outside program.
14:37:53 (lmgrd)
Hubert_H_Intel
Hi Wilfird,
As the error says, there are 2 lmgrds running. Depending on how you started the Intel(R) Software License Manager (as service or user app) you need to check on the Task Manager wheather there are more lmgrd tools (under Details) or Intel(R) Software License Manager (under Services) running. You may shut down them all and restart one via Start menu > Intel(R) Software Development Products > Configure Intel(R) Software License Manager.
Did you also modify the host info in the licese file for the new server? Is the the host id included in the license file identical with one of the physical addresses of your new server?
Regards, Hubert.
