Software Archive
Read-only legacy content
mic frequency
kvs
I am trying to get the phi to run at its fastest clock,
after looking at the following , it seems the phi is not running at its fastest clock.
~ # cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
1238094
~ # cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq
1333332
~ # cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies
619047 666666 714285 761904 857142 952380 1047618 1142856 1238094 1333332
Can anybody how I can get this to running at the highest available clock.
best regards
kvs
kvs
Here is some more information
~ # cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
1238094
~ # cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
619047
~ # echo 1333332 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
1238094
~ # cat /sys/devices/system/cpu/cpu0/cpufreq/stats/time_in_state
619047 0
666666 0
714285 0
761904 0
857142 0
952380 0
1047618 0
1142856 0
1238094 181873382
1333332 0
TimP
Did you check the turbo boost setting in micsmc-gui?
kvs
Hi Tim,
I just tried to set the turbo mode but got the message
"Turbo Mode not supported on one or more devices"
regards
kvs
TimP
That likely means your model isn't capable of the higher frequency. Turbo is pricey, and boosts power consumption much more than performance.
kvs
Hi Tim,
It is a 7120P and is supposed to support turbo mode. Is there any other way to turn turbo ON.
Please see the attached micinfo dump .
thanks
kvs
TaylorIoTKidd
Turbo is only available on the highest end SKUs (pricey and actively cooled). If you didn't intentionally look for the highest performing coprocessor, you don't have turbo capability.
Have you used the micsmc tool to check and modify your power management functions? (See attachment) P-states are normally enabled. If you having disabled them, it might cause your frequency to drop.
(To use micsmc to modify the coprocessor PM settings, you need to be root.)
Taylor
kvs
missed attachment
kvs
Hi Taylor,
Looks like that was the issue, the p-states were disabled. Now turbo can be turned on.
Your screen shot was very helpful.
Thanks a lot to you and Tim for the valuable inputs.
regards
kvs
TaylorIoTKidd
One more note: In the micinfo dump you gave us, it says
        SMC HW Revision          : Product 300W Passive CS
I'm pretty sure this means that your coprocessor is passively cooled. It may not have all the features (e.g. turbo) available.
Taylor
TaylorIoTKidd
Here's where you can get some marketing product specifications:
https://www-ssl.intel.com/content/www/us/en/processors/xeon/xeon-phi-detail.html
http://ark.intel.com/products/series/75809
If you click on the product name, you can see the specifications, including if it has turbo boast technology.
Taylor
