Software Archive
Read-only legacy content
mic0 reset failed
Riazuddin_K_
Hello!
I am trying to make coprocessors work on Ubuntu 14.04 but I got stuck with error: mic0 reset failed. I have tried several methods noted in this form but I was not able to make it work. So, I am seeking help to make my mic work. Please, find my micbug as attachment.
Thank you.
Sunny_G_Intel
Hello Riazuddin,
Can you please let us know which specific forum posts you followed? We are in process to get the system prepared with Ubuntu and Intel® MPSS and will be able to update you shortly with the correct recipe.
Thank you for your patience.
Riazuddin_K_
Hello Sunny,
Thank you very much for your reply; I really appreciate your effort. I have read several forum articles but at the end, this is what i have done:
https://github.com/neel9102/michack/blob/master/michack_ubuntu_14.04_mpss_4_3.sh
Hope that helps. Thank you
Frances_R_Intel
While Loc is diligently working to get an Ubuntu system up in our group's lab, I took a look at your micdebug file. The POST codes from the coprocessor (in host_dmesg.txt) end with F2 which, according to the chart in the MPSS user's guide, means that the GDDR memory training on the coprocessor failed.
I also compared your full_lspci.txt against a machine I have access to and saw some things that don't look right to me. For example, in the section for the coprocessor, your output says:
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
but I have
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR- FastB2B- DisINTx+
There are a few other differences like that in the lspci entry for the coprocessor. Curious - and not in a good way.
