Software Archive
Read-only legacy content
micctrl bugs in --addnfs and --pm
Xiao_peng_W_
I found two bugs in micctrl commands:
1. micctrl --addnfs=<nfs server>:///nfs/a --dir=/opt/a mic1
This command can only set nfs server to be the mic host node. That means specifying <nfs server> for --addnfs does not work.
2. micctrl --pm=set  --cpufreq=off
This command cannot set cpufreq to be 'off'
Xiao_peng_W_
Then I found I could not set the attribute to 'on' after setting to 'off'.
Original state in mic0.conf
    PowerManagement "cpufreq_on;corec6_off;pc3_off;pc6_off"
I run command to turn them on
    # micctrl --pm=set --corec6=on --pc3=on --pc6=on mic0
Then in mic0.conf, did not see any change
Was I using micctrl command in incorrect parameter formats? Or it's a bug of micctrl command?
Sumedh_N_Intel
Hi Xiao,
It seems that your usage of the power management options is correct and I have been able to reproduce the issue. On your behalf, I have filed a bug against micctrl for the power management options. The reference number for the issue is 6000034235.
Sumedh
