Software Archive
Read-only legacy content
17060 Discussions
missing libscif.so.0 object file?
King_Crimson
Hi all,
I'm trying to install MPSS on Ubuntu 12.04 (I understand that only redhat and suse are well supported). I convert the .rpm files into .deb using "alien", and install them by the command dpkg -i *.deb. No error is reported in the installation process. But as I try to invoke micctrl or other mic utility such as micinfo, one message pops up:
error while loading shared libraries: libscif.so.0: cannot open shared object file: No such file or directory.
What does this error mean? When and where is that shared library supposed to be installed? Thanks!
TimP
Normal location of that library is /opt/intel/mic/filesystem/base/lib64/libscif.so.0
and it gets copied to /lib64 on the coprocessor in a default (no mounts) installation.
Peter_F_1
Who copies this library there?!
Which software?
This library is nowhere to be found under the directory from intel.
And I asked my administrator to install it!
BelindaLiviero
this gets installed as part of the MPSS (latest package: http://software.intel.com/en-us/articles/intel-many-integrated-core-architecture-intel-mic-architecture-platform-software-stack  )
make sure your system administrator has installed it properly (and using the latest?)
more specifically this rpm in the mpss has it (example here was what I had installed recently on an RHEL system)
rpm -ql intel-mic-gpl-2.1.5889-16.el6.x86_64 | grep libscif.so
/opt/intel/mic/filesystem/base/lib64/libscif.so.0.0.1
/usr/lib64/libscif.so
/usr/lib64/libscif.so.0
/usr/lib64/libscif.so.0.0.1
/usr/linux-k1om-4.7/linux-k1om/usr/lib64/libscif.so
/usr/linux-k1om-4.7/linux-k1om/usr/lib64/libscif.so.0
/usr/linux-k1om-4.7/linux-k1om/usr/lib64/libscif.so.0.0.1
Frances_R_Intel
I'm wondering if the micctrl --initdefaults got run. The easy way to tell would be to look in /etc/sysconfig/mic. And look in /opt/intel/mic/filesystem to see if there is a mic0.image file. Even if the file is in /opt/intel/mic/filesystem/base/lib64/libscif.so.0, it won't make it to the coprocessor unless it is in the image file.
Kevin_D_Intel
It is host-side commands (micctrl, micinfo) that are not working. The missing file resides on the host under /usr/lib64. From a RHEL6.3 install, here's what exists:
$ pwd
/usr/lib64
$  ls -l libsci*
lrwxrwxrwx 1 root root    16 Jan 29 02:15 libscif.so -> libscif.so.0.0.1
lrwxrwxrwx 1 root root    16 Jan 29 02:15 libscif.so.0 -> libscif.so.0.0.1
-rwxr-xr-x 1 root root 20434 Dec 17 04:58 libscif.so.0.0.1
