Software Archive
Read-only legacy content
17060 Discussions
offload error: buffer set state failed
shiva_rama_krishna_b
when i was running my code. i am getting error offload error: buffer set state failed.
what does this error means? When this error can occur? Please let me know if you have any idea on this.
Note: If i see the memory used by the application it is consuming around 5.1GB. I have 8 GB on my MIC.
sivaramakrishna
Kevin_D_Intel
I have only seen this offload error appear once in the past and in that case there were other offload errors preceding it.
We need more information about any other run-time warnings/errors the app might have received and more details about what the app is doing in terms of offload (e.g. offload from multiple threads, using signal/wait, the offload directives used, etc.)?
If you can provide more details that may help offer some other insight. If you can provide a small reproducer that would really be most helpful.
