Software Archive
Read-only legacy content
17060 Discussions
onRecognition of PXCMSpeechRecognition.Handler dose not fire in WCF Service when hosted in IIS
Priyank_T_
 onRecognition of PXCMSpeechRecognition.Handler dose not fire in WCF Service when hosted in IIS. The handler is called in development environment but it is not called when deployed in IIS.
See Below Code.
        bool HasSpeechRecognised = false;
        string SpeechText = string.Empty;
       public string GetText(Byte[] value)
            PXCMSession session = PXCMSession.CreateInstance();
            // session is a PXCMSession instance.
            var FileName = @"D:\Test\ServiceInput.wav";
            System.IO.File.WriteAllBytes(FileName, value);
            PXCMAudioSource source = session.CreateAudioSource();
            // Set the audio fie
            PXCMAudioSource.DeviceInfo dinfo = new PXCMAudioSource.DeviceInfo();
            dinfo.did = FileName;
            // Set the active device
            source.SetDevice(dinfo);
            PXCMSpeechRecognition sr;
            session.CreateImpl<PXCMSpeechRecognition>(out sr);
            PXCMSpeechRecognition.ProfileInfo pinfo;
            sr.QueryProfile(0, out pinfo);
            sr.SetProfile(pinfo);
            // Set handler
            PXCMSpeechRecognition.Handler handler = new PXCMSpeechRecognition.Handler();
            handler.onRecognition = OnRecognition;
            // Start recognition
            var Status = sr.StartRec(source, handler);
            while (!HasSpeechRecognised)
            sr.StopRec();
            sr.Dispose();
            session.Dispose();
            return SpeechText;
  private void OnRecognition(PXCMSpeechRecognition.RecognitionData data)
            HasSpeechRecognised = true;
            // Process Recognition Data
            var d = data;
            if (d.scores.Length >= 1)
                SpeechText = d.scores[0].sentence;
            else
                SpeechText = "Invalid Audio";
Michail_S_Intel
Hello.
Do you have RS SDK installed on IIS machine(or runtime only)? Could you provide versions?
Mike.
AndreCarlucci
Is the IIS machine the same as the development one?
What user running your application pool?
Priyank_T_
1. RS SDK is installed on IIS machine  (Windows 8.1 , IIS 8, RS 4.0.0.112526)
2. Yes this  IIS machine the same as the development one.
3. Application pool identity is LocalSystem
