Software Archive
Read-only legacy content
17060 Discussions
open google maps navigation
giuseppe_s_
prejudice are new 'm doing tests can tell me how I can open the browser from my app using XDK intel ? I have a lot of confusion
if there is a source code would be perfect thanks
 thanks
John_H_Intel2
You need to know an external apps protocol handler to be able to launch it. If you want to open google maps, you can use a function such as this. It uses the intex.xdk.device plugin, so you would need to include that (by checking a box) in the project settings. There are probably other ways, but this works :)
function launchGoogleMaps()
        //var url = "http://google.com/maps?saddr="+currentLatitude+","+currentLongitude+"&daddr=5700+Linglestown+Rd+Harrisburg,+PA+17112";
        var url = "googlemaps://?center=40.765819,-73.975866&zoom=14&views=traffic";
        //alert(url);
        //console.log(url);
        intel.xdk.device.launchExternal(url);
John_H_Intel2
        //alert(url);
        //console.log(url);
PaulF_IntelCorp
If you simply want to launch Google Maps in the device browser, you can use the inAppBrowser plugin. See the doc page for details: https://github.com/apache/cordova-plugin-inappbrowser
giuseppe_s_
you can explain to me to come work is the plug-in Cordova ?
the source of Example dove goes Put In which part of the program
for example
navigator.camera.getPicture(onSuccess, onFail, { quality: 50,
    destinationType: Camera.DestinationType.DATA_URL
function onSuccess(imageData) {
    var image = document.getElementById('myImage');
    image.src = "data:image/jpeg;base64," + imageData;
function onFail(message) {
    alert('Failed because: ' + message);
This part of the code which is placed inside js .. ??
where you call this function ???
I am new and nn know where to get information one can help me thanks
PaulF_IntelCorp
I recommend you take a look at some of the samples to figure out how things work. In particular, there is a "gelolcation demo" that might help. Try "Start a New Project" then "Samples and Demos" then "General" then "HTML5+Cordova"
PaulF_IntelCorp
I'm sorry, but I don't understand what you want us to do with that link... Please note that we keep track of a large number of developers and threads, so providing some context always makes it much easier to help answer your questions.
giuseppe_s_
HIS plug That allows you to recall the navigator google
example
launchnavigator.navigate (
"London, United Kingdom",
"Manchester , UK "
function () {
alert ( " success Plugins " ) ;
function ( error ) {
alert ( " Plugin Error : " + error ) ;
can you help me on how to how to use google gcm " notidiche Pusch through intel XDK are some examples???
PaulF_IntelCorp
You referred to a specific plugin in an earlier post. That plugin has an example that you can use (I don't know if it helps with your question regarding push). That example can be found here: https://github.com/dpa99c/phonegap-launch-navigator-example
In general, when you find examples for plugins, one way to try that code is to create a blank HTML5+Cordova project from a template and then copy the example code into that new blank project.
Sorry, but we do not have examples for the large number of third-party plugins that are available. The plugin authors are your best resource for those examples. Also, The Intel XDK creates a Cordova application, so any examples you find that are for Cordova or PhoneGap apply to the Intel XDK.
