Software Archive
Read-only legacy content
17060 Discussions
phonegap-plugin-push failing build
Mike_C_4
I have been using version 1.2.3 version  with no issues, however I need a new feature that only available in version 1.4. When I update to 1.4 I now getting a build failed errors?
 however 1.2.3 compile just fine any help would be great.
Version
XDK:2611
CLI : 5.1.1
Plugin version: 1.4 plugin link
John_H_Intel2
Not all plugin versions are going to be compatible with the build system and other plugins. The plugin link that you provided shows that the author made changes this week. I am guessing that is what is causing it to fail with the newest version.
PaulF_IntelCorp
Version 1.2.3 is the latest version that will work with our build system. The problem is these two lines in the plugin.xml file:
<framework src="com.android.support:support-v13:23+" />
<framework src="com.google.android.gms:play-services-gcm:+" />
See this post for details: https://software.intel.com/en-us/forums/intel-xdk/topic/595059
Mike_C_4
Hi Paul,
Yes I remember this now thanks for the link. The developer had a special version to get around this let me contact him and see if he will be willing to give me a modified version
Thanks again.
