Software Archive
Read-only legacy content
17060 Discussions
pixel shader
mistypup
I have purchased a game called paws& claws pet vet 2 it says a pixel shader is unavaliable I have updated my drivers and not sure what else to do I did all the things that valusoft said to do my grapics card is Intel 82845G/GL/GE/PE/GV graphics controller does anyone have any suggestions to help with this matter thank you.
davidc1
Intel 845G/GL/GE/GV graphics controllers do not have pixel shaders. If a game specifically requires pixel shader support to run, you will likely not be able to run them. The versions that support pixel shaders are 915G and up.
belltrix
I've had the same problem, too. Pixel shaders are needed for the game I am trying to run in my computer.
davidc1
I told you. Intel graphics based on 845 chipsets DO NOT HAVE PIXEL SHADERS. You can't enable something that doesn't physically exist. 915 and up chipsets have pixel shaders. If the game requires them, you can't run them, period.
jack470
You could always download 3d-analyzer fro the following website: http://www.tommti-systems.com
You have to tick this boxes Hardware Limits:emulate hw tnl caps
emulate other dx8.1 caps(optional)
emulate pixel shader caps
emulate bump map caps(optional)
Performance:Force software tnl( Fps problems in the game)
Hope this is really helpful to you all!
