Software Archive
Read-only legacy content
17060 Discussions
print vector graphics
Intel_C_Intel
What is the best method for getting vector graphics printed from a visual fortran program. The documentation only discusses bitmaps which are not good enough for our applications. Our old mainframe system used a program that converted the stream to a postscript format and sent it to the printer. Is there something like that for the AC that will work with visual fort ran. I am new to the AC programming environment. Any help will be appreciated. TX
isn-removed200637
I don't know about postscript, but have you considered HPGL formatted output?
If you can draw to a window, then you can easily translate the draw commands to
HPGL format. These consist of PU X,Y (move to x,y with pen up, i.e. do not draw line from present position) and PD X,Y (move to x,y with pen down, i.e. draw line from present position). ALong with SP (select pen), PT (pen thickness) and a suitable header/preamble (stolen from a good HPGL-formatted file, see below), you can
easily create a text file of commands which is importable into any document with a half-decent HPGL filter or HPGL viewer and then print from there. You have to do your own scaling, but this is straightforward - the example below
shows the size of the numbers - the first few PU and PD's draw a rectangular box
around the plotting area.
 IN;IP;IW;PS4;PU0,0;PT0.1;SP1;DT;
 PU1100,1100;PD1100,7475
 PD9600,7475;PD9600,1100
 PD1100,1100;PD
 SP1;LT2;
 SP1;LT4;
 PU4961,4875;PD5001,4840
 SP1;LT2;
 PU5001,4840;PD5044,4808
 PU5044,4808;PD5091,4781
 PU5091,4781;PD5140,4758
 PU5140,4758;PD5191,4741
 PU5191,4741;PD5244,4728
Just sign off with the commands
 PU0,0;SP0
In my experience, some import filters like/demand only one PU or PD command per record. Decent ones will take several commands per record, each seperated by semi-colons.
HTH
Intel_C_Intel
I spent a great deal of time getting vector graphics working under
WINDOWS. I would be happy to zip it all up and send it to you if I had
an email address. You would strip out all the things you don't need. The interface routines handle output to the screen, hpgl, calcomp and a few
other odd packages by setting a device string.
Bill
Intel_C_Intel
Thanks for the replies. I would like to get your zipped files. You can e-mail them to me at [email protected] or at [email protected].
Intel_C_Intel
Bill, If possible I too would like to look at your graphics routines. My email is [email protected].
If one is working with source code which has CalComp calls I recommend they look at the page given below at Southhampton Fortran Support. The public domain routines listed here work well in producing HPGL, and PostScript files.
http://www.soton.ac.uk/~fortran/libraries/calcomp/convert.html
Bob
