Software Archive
Read-only legacy content
problem in setting threads at MIC
aketh_t_
hi all,
This a program, I had written in fortran.
!dir$ offload begin target(mic)
call omp_set_num_threads(240)
!dir$ end offload
!$omp parallel
print *,The number of threads are',omp_get_num_threads()
!$omp end parallel
!dir$ end offload
However in the final output I still get
The number of threads are 1
why? How do I set more threads?
aketh_t_
I did not compile with -openmp option as well
Sunny_G_Intel
Hello aketh,
Can you please clarify what are you trying to achieve. You mentioned you want to setup the openmp number of threads to 240 but you are not compiling with -openmp flag.  Can you please try the following:
program testset
include 'omp_lib.h'
!dir$ end offload
!$omp parallel
        print *,'The number of threads are',omp_get_num_threads()
!$omp end parallel
!dir$ end offload
end program testset
Compile with
ifort -openmp -o testSet testSet.f90
and execute
./testSet
Let me know if you still do not see number of threads set to 240.
aketh_t_
It worked. thank you. what I meant was I forgot to use -openmp option.
James_C_Intel2
A slight side issue, but... explicitly forcing 240 threads is a bad idea on multiple grounds.
  1. In offload one core is heavily loaded by the system transferring data, and your code would be better not using it
  2. Forcing the number of threads makes your code non-portable (what if you try to run it on a card with fewer cores?)
The system uses sensible defaults, so until you really understand what you're doing, don't change them! (And, when you do, use the envirables (KMP_PLACE_THREADS, KMP_AFFINITY), don't hard-wire these things into your code).
